TNT.1437 Series (29/9)
gameland
http://forum.xda-developers.com/showthread.php?t=332544
last update: 29/sep 12:16 AM (+3 GMT)
note.exe has been fixed
Intro:
after testing many of base roms on many of releases, i found the most stable and less issues base roms are listed:
1- OS 5.2.1437
2- OS 5.2.1620
3- OS 5.2.1908
so, i have cooked a new series based on 1437 build, but using OEM Drivers as modules (the first final edition for me using this. By using OEM Drivers as modules you will get more stabilty and performance with less issues, so i think this is will be the best stability.
don't say this an old build and found many weeks before, because this is the first base rom using the OEM Drivers as modules after the last official build 318 build 15342.
one more advantage for 1437 build, it is the last official build released for many of devices which means they trust it.
Base Rom:
OS 5.2.1437 build 17944.0.3.1
like before we have many choices, and because this is always the same i will type the most important edits on the stuff after TNT 5.0:
- Official edition will be good for cookers (.RGU files are there)
- Pictures and videos don't show some of videos (Fixed)
- All issues has been solved like before with some edits.
- USSD issue (Fixed)
- Storage Card2 issue (Fixed by cancelling IE 2 SD, do it yourself)
- some other fixes
- Java application removed, some have bugs with the latest version, i will build many cabs to choose whatever you want
- Task Manager removed (there are many choices like 1.0, 1.5, 2.0, or pBar).
- for proffesional and touchflo editions, the standard calculator has been removed.
- Microphone AGC going back to disable after restart (Fixed)
Official:
nothing, just the base rom and OEM drivers;
no camera, no MMS, no WML, no Office... etc
so don't ask for the kitchen, just extract official build using Core kitchen then use the SYS folder and OEM packages from this, then add whatever you want.
Professional:
Apps:
- camera app
- 1-calc.
- Office latest version with zip view and OneNote.
- 11 buttons commmanager.
- ArcSoft 4.2.8.1 with plug-in and full features.
- Modem Link (DUN)
- Network Wizard 1_0_29982_7 support many of networks (Auto run disabled, go to start/settings/connection to set you network settings)
- SmartKey 0.56 (the best settings)
- SoftKeyAppletEx (to change Home SoftKeys)
- Streaming Video 2.1.1025.621
- Windows Live Messenger 10.6.31.2600
- WM5torage 1.75
- SIM Manager 6.25
- STK Service 4.40 (Fixed)
- TimeZone Tab on the phone settings (set to automatic update the time)
- All Help files as the official
- Internet Sharing
- Advanced Config Tool 1.0
- BT_FTP 1_2_30234_2.
- BT_SAP 2_02_b0925_r3.
- BtIO (to hear sounds via the BT Headset)
- Call Firewall (to reject the unwanted calls)
- Dr.Yar 1.6 (to show the BT sender name and set the recieving folder).
- MJConfig
- Event Countdown 1.0 (timer)
- GroupSMS
- GSFinder+
- black keyboard
- HTC Audio Manager 1.2.614.712
- Pocket RAR 3.60 (zip and rar files already set)
- Pocket Screen Capture.
- Mobile Justice
- Network Plugin 1_0_29714_1
- Notepad
- ClearTemp
- CloseApps
- Hibernate
- Peek Pocket (WiFi networks manager)
- TCMP 0.72 (the best media player with advanced configuration like equalizer).
- RealOne (rm ram ra player, files set to it)
- RunEveryDay.
- SMS Backup 1.1
- SMSService
- Total Commander
- WinXplore 0.3.2.0
- HTC Voice Recorder 1.10.611.711
- TaskManager 2.7.0.1 (with reg app shortcut)
pictures and videos shows many of media types
Memory:
Professional+HTC Home (my favorite) :
Apps:
- same Professional edition plus:
- HTC Home 5 tabs with settings plug-in (you can make it 6 = start/settings/today/items)
Memory:
TouchFLO
Apps:
- camera app
- 1-calc.
- HTC TouchCommmanager 9 buttons
- Modem Link (DUN)
- Windows Live Messenger 10.6.31.2600 (the newest build)
- WM5torage 1.75
- PIMBackup 2.5
- AltTab (to switch between opened Apps)
- Select All Contacts (to select more than one contact to delete, send,...
- HTC Touch Dialer
- Windows Media Player Skin
- HTC TouchFLO (the best settings).
- Esmertec Java 20070802 (Full Screen no trial periods)
- Wizard TouchFLO Settings (special edition for Wizard)
- SIM Manager 6.25 (the newest)
- STK Service 4.40 (the newest)
- black keyboard
- Internet Sharing
- SMSService
- BtIO (to hear sounds via the BT Headset).
- Call Firewall (to reject the unwanted calls).
- Event Countdown 1.0 (timer).
- GSFinder+
- black keyboard.
- WinXplore 0.3.2.0
- Notepad
- ClearTemp
- CloseApps
- Hibernate
- Biotouch Settings.
- HTC Cube
- TouchFLO (scroling using finger)
Downloads:
pagepool for all= 6 MB (high pagepool= high performance+less program memory, less p.p= less perfor.+high program mem.)
Official:
Rapidshare download + some missed Packages (ArcSoft MMS 4.2.8.1 and camera all edited to fix issues)
Professional:
Rapidshare download
Rapidshare download
TouchFLO:
Rapidshare download
TouchFLO Note:
dharvey4651 edited the pagepool size for TouchFLO edition to 10 MB, you can download it from the link: http://www.filefactory.com/file/fa5079/
or http://www.megaupload.com/?d=TM2N1W2R, thanks dharvey4651. and http://www.megaupload.com/?d=RZFKY868 another mirror.
Add ons (install to the main memory) :
there are some new Add Ons will be added after finishing the thread, ask for the needed cabs.
- TNT Task Manager 2_0_30487_2.cab (the newest task manager)
- TNT Adobe Flash Player.cab
- TNT Adobe Reader.cab
- TNT AutoUpdate.cab
- TNT Esmertec Jbed 20070802.cab
- TNT HTC Voice Recorder1.10.611.cab
- TNT Transcriber.cab
- TNT VoIP.cab (if you are VoIP user, go to Schap's thread to download VoIP settings)
- TNT 02082007_Esmertec_JBED.cab
- Tao_Java_10_1_7_575.CAB
- TNT JBED 24052007.cab (will install on the Storage Card, so always keep SD installed to work)
- TNT Cyberon Voice Command.cab new added
- RealOnePlayer_for_PPC_v2.0.0.28.cab new added
- Battery Status last build can be found here (High Recommended, to get faster OS)
- CyberionVoiceSD_for_WM6_v1.2_build_61226_1.cab (thanks neva dinova)
For Official users only:
- TNT camera.cab
- TNT missed Files.cab
- TNT Arcsoft MMS 4.8.2.1.cab
- TNT Office 2007+OneNote.cab
- TNT Default_ieceext.dll.cab
Fixes:
you can't open note application, so the fix:
- TNT Note.exe Fix.cab 29-9-2007 Added
__________________
Donate if you really want to keep the working up. << finally i got a paypal account
__________________
Credits:
- Faria for his base rom (my start base rom).
- bepe for answering many of questions.
- tom_codon helping me on so many things including touchFLO tricks.
- anichillus for his great kitchens.
- mfrazzz for letting me to use some of his packages.
- gullum for helping me on some of TouchFLO tricks.
- Cloudyfa for the new Java application.
- mmeyer4663 for support all old TNT series.
- schen for trying to help.
- famewolf for his PM with the topic "thanks".
- the-equinoxe for some of Touch tricks.
- mattk_r for his efforts on Wizard forum.
- schapes for his commmanager (there is a little edit on it)
- n3rxs for previous mirrors.
- Sleuth255 for answering some questions.
- jwzg for the forum arrangment.
- vijay555 for helping on this page
- nottoosmart for the good discussions.
- boy_de_ghet for using his xip part.
- misar for his great tool
- samery for good supporting on our website (www.ce4arab.com)
- all www.ce4arab.com members.
- every one used my packages and keep the credits.
- All TNT users who help others.
i think didn't forget some one. If I did, forgive me
đã test con rom này.kết wa như sau:
best : tốc độ ngon hơn octaivoi. giao diện khá đẹp,music khá tốt free ram with 6mb pp +> 27-29mb. touch hoạt động tốt
bad: shotcut cho massage lỗi, lỗi với WA và WAD chạy ứng dụng nặng là đứng cứng ngắc.
finally => back to octaivoi ^^
Không biết bạn dùng thế nào chứ mình không thấy lỗi message như bạn nói. Dùng rom này từ hồi đến giờ chả thấy có vấn đề gì.
Có điều là mình không dùng WA nên không thấy đứng máy. Mình dùng Mobile shell và cài thêm nhiều phần mềm khác dùng thấy rất ổn mà.
Rom này cực nhanh, cực ổn định! chưa thấy lỗi gì cả
Bị cái Âm thanh to quá đến độ rè loa nên chỉnh xuống 1 nấc!
hehe hù tui ko tui xài octaivoi vẫn binh thường thui.tai xài bản touch nên ko biết bị sao.anyway rom tốt ^^ no spam anymore ^^
Em cũng thích bản Touch. bác nào up lên giúp bọn em nhé. thanks
Mình không khoái dùng Touch nên không down về máy. Hiện tại đang down về để up phục vụ các bạn. Nếu mạng không vấn đề gì thì chiều nay sẽ có trên 4shared phục vụ anh em:D
Bác nào down được bản TNT 1921 (touch version), nếu được share với mọi người với. Cảm ơn nhiều!
Nếu được, phiền bác up luôn bản mới 1921 HTC nhé! Thanks.
Bản touch mà các bạn muốn đây:D
http://www.4shared.com/file/26495173/6dacd2d/TNT1921_Wizard_TouchFLO.html
Bạn nào up rồi thì đưa ý kiến lên cho anh em tham khảo với nhé! Mình chưa có ý định up bản này, thấy bản .1437 xài ok rồi =D>=D>=D>=D>=D>
em cảm ơn bác. em đang download về nè! em sẽ úp con ROM này rồi nhận xét cho anh em biết luôn.
em đang dùng ROM NDBX, chạy hơi chậm và có lỗi: mỗi lần bật lên là nó báo: Error notificate: cannot execute \Windows\nrdwakeup.exe
Lần sau bạn cảm ơn thì nhấn vào nút thanks đỏ đỏ ở dưới này nhé! Quy định của diễn đàn này là vậy đó :D:D:D:D:D
