TNT 5.0
RClub
It's Right:
TNT 5.0 Series the new Wizard WM6.0 generation
Last Update: 13-9-2007 11:00 AM (+0GMT)
new foundations added on the 3rd post
Last Update: 12-9-2007 6:00 PM (+0 GMT)
Add Ons Added
Intro:
After more than 15 days of continuosly work on a new base rom for the wizard, but this time solve the most issues found on all WM 6.0 roms, the issues solved:
- When you call someone and he didn't answer you get connected instead of call ended.
- When you call a busy number also you will get connected instead of busy
- When you have GPRS Connected and someone called you and you didn't answer this calling will shown as recieved call instead of missed
- When you have a call and recieve a call (waiting) and you didn't answer, this calling will shown as recieved call instead of missed.
- When you open start/settings/Phone then directly press ok button, your personal tone will change to the default
- Some of roms have the issue with cannot open the wifi from the first time
- When you change the notification to vibration, then change it again to ring mode, the device still on vibration till you play your ring again or change your ring
- some roms can't start the wifi directly
- MMS 4.2.8.1 sounds and files pluging error (if you right click on the file don't show send via MMS)
The thing make this a good base rom, all the time spent was testing and focusing on the last wizard WM 5.0 official releases to see what are the missed files and registries, and what are the added without need.
and then we have many of porting roms after testing found they are not a true porting, because some of them using OS version changing method to show the new OS version (maybe some of them not).
more details will shown down.
Base Rom:
5.2.1620 build 18125
which is official releases and tests came from many of devices, so you can deal with is as an Official release.
there are 4 roms and Add ons to match all the needs:
Note: All The roms are 6 MB Page Pool (more page pool = more perforamnce = less program memory, less page pool = less performance = more program memory)
Official:
Apps:
- camera app
- 1-calc.
- Office latest version with zip view and OneNote.
- 11 buttons commmanager.
- ArcSoft 4.2.8.1 with plug-in and full features.
- Modem Link (DUN)
- Network Wizard 1_0_29982_7 support many of networks (Auto run disabled, go to start/settings/connection to set you network settings)
- SmartKey 0.56 (the best settings)
- SoftKeyAppletEx (to change Home SoftKeys)
- Streaming Video 2.1.1025.621
- Windows Live Messenger 10.6.31.2600 (the newest build)
- WM5torage 1.75
- SIM Manager 6.25 (the newest)
- STK Service 4.40 (the newest)
- TimeZone Tab on the phone settings (set to automatic update the time)
- All Help files as the official
- Internet Sharing
Registries (for all)
- IE Temp files to SD
- End button will not end GPRS connection
- Disable Error reporting
- Disable Security Warning
- Enable 802.11g
- Disable start menu sounds (if you want it, its written with the notes)
- Some Performance tweaks (exactly like Faria, thanks faria )
- EDGE icon and slide-out keyboard capsdot
- Hide SIM Contacts
Memory:
Free Storage= 44.06 MB
Free Program= 31.62 MB
Professional:
Apps:
- camera app
- 1-calc.
- Modem Link (DUN)
- WM5torage 1.75
- Internet Sharing
- Advanced Config Tool 1.0
- BT_FTP 1_2_30234_2.
- BT_SAP 2_02_b0925_r3.
- BtIO (to hear sounds via the BT Headset)
- Call Firewall (to reject the unwanted calls)
- Dr.Yar 1.6 (to show the BT sender name and set the recieving folder).
- MJConfig
- Event Countdown 1.0 (timer)
- GroupSMS
- GSFinder+
- black keyboard
- HTC Audio Manager 1.2.614.712
- Esmertec Java 20070802 (Full Screen no trial periods)
- Pocket RAR 3.60 (zip and rar files already set)
- Pocket Screen Capture.
- Mobile Justice
- Network Plugin 1_0_29714_1
- Notepad
- ClearTemp
- CloseApps
- Hibernate
- Peek Pocket (WiFi networks manager)
- TCMP 0.7 (the best media player with advanced configuration like equalizer).
- RealOne (rm ram ra player, files set to it)
- RunEveryDay.
- SMS Backup 1.1
- SMSService
- Total Commander
- WinXplore 0.3.2.0
- HTC Voice Recorder 1.10.611.711
- TaskManager 2.7.0.1 (with reg app shortcut)
Memory:
Free Storage= 44.04 MB
Free Program= 30.90 MB
Professional+HTC Home (my favorite) :
Apps:
- same Professional edition plus:
- HTC Home 5 tabs with settings plug-in (you can make it 6 = start/settings/today/items)
Memory:
Free Program= 29.83 MB
TouchFLO
Apps:
- camera app
- 1-calc.
- HTC TouchCommmanager 9 buttons
- Modem Link (DUN)
- WM5torage 1.75
- PIMBackup 2.5
- AltTab (to switch between opened Apps)
- Select All Contacts (to select more than one contact to delete, send,...
- HTC Touch Dialer
- Windows Media Player Skin
- HTC TouchFLO (the best settings).
- Wizard TouchFLO Settings (special edition for Wizard)
- black keyboard
- Internet Sharing
- SMSService
- BtIO (to hear sounds via the BT Headset).
- Call Firewall (to reject the unwanted calls).
- Event Countdown 1.0 (timer).
- GSFinder+
- black keyboard.
- WinXplore 0.3.2.0
- Notepad
- ClearTemp
- CloseApps
- Hibernate
- Biotouch Settings.
- HTC Cube
- TouchFLO (scroling using finger)
Memory:
Free Storage= 44.05 MB
Free Program= 29.32 MB (Yes 29.32 MB)
General Notes: (Please Read before updating)
- "Official Edition" maybe after the first restarting will hang, nevermind, it is just the first time (becuase of smoe removed apps).
-Remove SD card while updating.
- the two bluetooth icons on the tray launch, you can open their menus by double click or click and hold.
- Before asking, get us your edition (professional or TouchFLO...)
- Camera has a bug, when you get video recording then stop it, sometimes go to desktop, just press the camera again, all WM 6.0 roms have this bug (working on)
- if your rom has PIMBackup older than 2.5, install PIMBackup 2.5 and do the backup via it.
- SMSDrFix not activated, you have to open it to replace the numbers with their contact name on messages.
- If you open Advanced Config, the battery icon on the tray launch wii disappear, you have to reshow it using Advanced Config.
- There is no IPL, SPL, ... JUST OS and splashes, so i think its safe for G4 users.
- Radio 2.19.11 UK more stable and fewest issues and no missed calls.
- You MUST have an IPL and SPL at 2.xx or higher (BOTH not just one or the other).
- High recommend to reflash an official rom before flash this one.
- there are two update utilities on the rar file, one for XP and the other for Vista. But if you have Vista you have to visit this thread, then use Vista utility (Worked for me "i have Vista").
- If you want to improve A2DP; edit it by any Tweaking app like this: http://forum.xda-developers.com/showthread.php?t=291770 or search for that
- If you change some thing, you have to wait for a minute before restarting to make sure the device get your changes.
- If you have any issue with A2DP visit this http://forum.xda-developers.com/showthread.php?t=308752, (previous rom version dosn't contain any issue).
- Are you beginner?? go to Howto flash a Wizard... a little tutorial! (Sticky Thread).
- Are you an arabic user?? go to the wonderful arabic forum which is www.ce4arab.com
Downloads:
Official:
http://rapidshare.com/files/55126710/TNT_5.0_Wizard_Official.zip
Professional:
http://rapidshare.com/files/55116086/TNT_5.0_Wizard_Professional.zip
http://rapidshare.com/files/55105496/TNT_5.0_Wizard_Professional_HTC.Home.zip
TouchFLO:
http://rapidshare.com/files/55082789/TNT_5.0_Wizard_TouchFLO.zip
RClub:
Mình đang dùng rom này và thấy tốc độ chạy rất nhanh và mượt, để ở 6mb pp nhanh hơn hẳn WRCX1 ở mức 8mb pp!!! Mình sẽ nhận xét về tiêu thụ pin sau vài ngày. Nhược điểm là có 1 vài xung đột với ứng dụng như Spbweather, conduits player 3.2, 3.1....(official general notes)
Link gốc
http://forum.xda-developers.com/showthread.php?t=328917
bản này không dùng ổn đâu, mod dell dùm anh em cái không member nào up nhầm lại sống dở chết dở bây giờ!
Chẳng biết bác có dùng Winzard hay là dùng cái gì thì không biết :-??
Chỉ biết rằng tôi đã dùng qua rất nhiều các loại ROM rồi nhưng hiện nay chưa thấy bản nào qua mặt được bản Rom này. Giao diện cực đẹp, tốc độ cực nhanh. Chỉ tiếc không có sẵn Over Clock CPU Ti OMap và X-buton. Nhưng không sao không có càng sạch ai thích cài cái gì vào thì cài. Đang loay hoay với octaivoi chưa hoàn chỉnh. WCRX quá khó up... phải Up lại Rom gốc WM05 của Tmobi thì thấy bản Rom này thật là may mắn. Cho đến hiện nay tôi thấy chỉ có vấn đề khởi động hơi chậm ra còn lại khi vào Win rồi thì Rom này chạy rất nhanh và ổn định. Thích cái là PIN dùng khá lâu, không hiểu có phải cảm tính không nhưng thấy chất lượng cuộc gọi khá tốt tiếng người đầu dây bên kia nói nghe thật giọng hơn, Wifi, bluetooth dễ bật và Rom khá sạch cho ai thích cài thêm gì vào thì cài.
Chả biết thế nào là đúng:))
Cứ down về up đại dùng cho thỏa chí tang bồng =D>=D>=D>=D>=D>
Mình không hiểu ý của bạn lắm, ý bạn là bản này có lỗi gì à? Nếu có lỗi gì thì show lên để anh em biết
Mình dùng bản này thì thấy nhanh kinh khủng ngay cả để ở mức 4mb pp, ram còn thừa rất rất nhiều, pin thì chưa test kỹ nhưng nói chung khởi động thì cực nhanh và mất khoảng 3 - 5% pin. Có điều là nếu cài spb weather vào thì nó sẽ khởi động cực lâu(khoảng vài phút), Conduits player thì lúc cài được, lúc không. Nói chung nếu ai không dùng 2 phần mềm đó thì nên dùng bản rom này, các bạn nên test thêm và feedback thẳng cho người cook để họ ra bản rom khác mới tốt hơn, như thế cũng là có trách nhiệm với những người làm rom cho ta dùng
ROM này chạy OK , nhanh , chưa thấy lổi gì hết , có vẻ good hơn cả octavoi của bác BOY
Tôi đang kiếm cái OverClock CPU để chạy với ROM này. Ai có bản Over Clock CPU nào pro post lên cho mọi người cùng sử dụng với nhé. Có thêm bản đó đi với ROM này thì đúng là nhất. Tạm thời yên tâm không cần dòm ngó gì tới up iếc cho đỡ mệt.
Bạn dùng cái nì hay hơn nè,theo dõi được RAM, PIN,sóng,có cả OverCLock dành cho dòng WIZARD đó. Chúc vui.:D
bạn có thể cài cái BatteryStatus có chức năng overclock, search trên diễn đàn cũng có. Cái này hay ở chỗ nó có luôn CPU scaler: thay đổi xung của CPU khi chạy nhiều hoặc chạy ít ứng dụng => tiết kiệm pin hơn 1 chút
Bản rom này đúng là tuyệt vời, tốc độ nhanh nhất trong tất cả những rom mình up từ trước tới nay. Giao diện cũng đẹp. Test từ hôm qua tới giờ chưa gặp lỗi gì.
Bản pro sms bị lỗi có khi không gởi tin nhắn được , phản hồi phấn nhắn tin rất chậm
Bản office chạy nhanh nhưng không biết đụng với soft nào màn hình cảm ứng bị lệch , pbar 1.4 báo lỗi
Bản official không có vấn đề gì với sms
Mình cũng chưa thấy bị lệch cảm ứng vì đụng soft
Mình thấy bản này chạy rất nhanh nhưng có 1 vấn đề là mỗi khi khởi động lại thì rất lâu mới có sóng,sóng cứ chập chờn rồi tắt.Có khi để 1 tiếng mới dc.Nhưng sau đó dùng rất ok.Và còn điều này nữa mình ko lên mạng bằng AS dc.Trc dùng octaivoi lên bình thường
Hiện tượng khởi động lâu là do có cài chương trình của SPB
Sóng chập chờn thì là do bản rom radio hoặc là mạng thỉnh thoảng có vấn đề thôi
Muốn vào được net qua AS bạn vào Setings - Connections - Connections - Advanced - Select Network - chọn My Work Network -> OK
Mình ko hề cài SPB,đã cài lại các bản radio nhưng ko ăn thua--->ko phải do radio,trc đó dùng rất tốt với octaivoi--> ko phải do phần cứng.Ở đây máy mình khởi động ko lâu mà là từ kúc ko có sóng đến lúc có sóng là rất lâu,điều này làm mình rất e ngại khi SR .Sau khi có sóng rồi thì rất ổn định.Còn việc ko kết nối dc qua AS mình đã làm hết cách kể cả cách như bạn nói nhưng ko ăn thua.
Mình đoán là do đụng soft nào đó. Mình đã từng bị khi cài spb weather rồi. Thực ra có thể nó vẫn có sóng do đèn báo vẫn nhấp nháy, nhưng nó cứ đứng ì ở màn hình welcome head.
Bạn thử khắc phục thế này xem có được không nhé
Thử hardreset và cài lại lần lượt các phần mềm và softreset từng lần đến khi thấy máy ì ra tức là đã đụng soft cài gần nhất. Khi máy có hiện tượng ì sau khi khởi động thì nó sẽ đứng ở màn hình welcome head, lúc này cứ đợi đến khi nào đèn màn hình tắt thì lại chọt vào màn hình để đèn sáng, độ 2 lần là máy nó sẽ khởi động xong. Tất nhiên vì đụng soft nên nó khởi động cực chậm, thậm chí đứng yên, nhưng chọt màn hình như thế thì nó sẽ hoàn thành quá trình khởi động nhanh hơn. Mình cũng không biết tại sao nó lại như thế, thử thì thậy như vậy
Sau khi biết soft bị đụng rồi thì tìm phần mềm tuơng tự khác cài dùng tạm vậy.
Nhưng bác ơi khi e mới up rom xong chưa hề cài phần mềm nào nó đã vậy rồi.Ở đây ý e muốn nói là nó nhận sóng rất lâu chứ khởi động ko hề lâu
Lạ nhỉ! Mình cài Rom này tốc độ ban đầu là cực nhanh, thậm chí mình còn cảm thấy không cần phần mềm tăng tốc chíp nữa. Sau khi cài thêm một số phần mềm rồi mới cảm thấy nó bắt đầu chậm đi một chút.
Bạn đã cài thử radio 2.47 chưa. Mình đang dùng nó và thấy rất ổn, ổn hơn cả 2.69 là bản mới nhất.
Em này dùng ngon nhể:O
Cơ mà cái Touch Flo dùng thế nào các bác nhể, nếu để standart 4.1 thì làm thế nào để nó ra giao diện TF, bác nào biết chỉ hộ em cái:((
E đã up đủ các bản radio rôi 2.26; 2.47 ; 2.69 và đã HR và up lại rom rất nhiều lần nhưng vẫn ko dc,ko biết tại sao nữa
