TTPod v3.80 Beta2 CN [27.11.2010]
pekuon
Lại có thêm bản beta nữa, chắc sắp có Final rồi, cái này chờ CaoMinh EN và VI thôi
Change log:
1, increased one hundred volume, music is more arbitrary;
2, optimal sound fade, support fade;
3, support for AAC audio real spectrum display;
4, support for AAC audio built-in cover display;
5, support long press the volume side buttons to switch songs;
6, the list of performance optimization;
7, optimal spectral display;
8, adjusting the left menu;
9, DIY function to remove the splash screen;
10, the repair part of the BUG.
Note:
1, N73, E50 and other MR models default is ten volume set to open in the sound volume thinning, the volume switch to one hundred;
2, long press the volume side key the song is disabled by default, open in the General Settings.
http://www.mediafire.com/?ptmq7wnivamjtv1
- Nên xài china cho rồi khi nào có Final việt hóa luôn chứ beta mãi mãi beta mà update mệt rsc luôn.
