Tweaks2K2 .NET for ARM & XScale (WM5/VGA supported) v3.24.1 updated 16/10/2006
huydn25
Tweaks2K2 .NET, WINNER of SmartPhone and Pocket PC Magazine 2005 Awards, is the ultimate easy to use software for hacking your PDA Registry, the biggest collection of hacks with 116 different registry tricks and 2 screens with important information about your pda. With tricks that nobody have seen before in any other tweaks application for PocketPC.
Hacks in this version:
1-Use Cleartype as System Font
2-Italic System Font
3-Bold System Font
4-Select a system font from fonts installed in your device
5-Animated Windows
6-Speed up the Display
7-Card battery warning
8-Low WMP background quality
9-Start Menu Animation
10-Admin Password
11-Show Network Folder
12-Battery Warning Settings
13-Date and Time in the top bar (Now you can pick from None, Time, Date and Both)
14-Transparent iPaq (36xx series)
15-Change the long date format in Today's screen
16-Change the wake up power off time to 60 seconds
17-Change the system font size
18-Narrow the scroll bars
19-Increase Inbox Font
20-Contrast Control for Toshiba e740
21-Identify PIE as IE 6.0
22-Use Cleartype in PIE
23-Move PIE temp files to any of your storage cards
24-Max TCP windows size
25-Letter Recognizer as Default
26-Block Recognizer as Default
27-Wordlogic as Default
28-Show Letter Recognizer in the list of Input Methods (keyboards)
29-Show Block Recognizer in the list of Input Methods (keyboards)
30-Show Transcriber in the list of Input Methods (keyboards)
31-Show CE-Star (www.mobem.com) in the list of Input Methods (keyboards)
32-Show PenPower (www.mobem.com) in the list of Input Methods (keyboards)
33-Change the color of Today lines
34-Change the color of Today font
35-Change the color of the font in the top bar
36-Change the color of bottom bar
37-Change the color of top bar (left)
38-Change the color of top bar (right)
39-Change the Start Menu font color
40-Change the Tap Hold Dots color
41-Change the identity of NetFront 3 from www.access.co.jp to MSIE 6.0 (this only works with the registered version of this software)
42-Change the tart time of the working day in the calendar
43-Change the end time of the working day in the calendar
44-Change the free days in the week
45-NanoPad as Default Input Method (http://www.outofnoware.freeservers.com)
46-Enable BlueTooth HeadSet support for HPiPaq 5400
47-Creates a Wireless Ethernet Icon in Settings\Connections (only for WM2k3)
48-Hide Admin Password (Policy) (2k2=<)
49-Hide About Icon
50-Hide Owner Icon
51-Hide Buttons Icon
52-Hide Menus Icon
53-Hide Today Icon
54-Hide Password Icon
55-Hide Connections Icon
56-Hide Beam Icon (only WM2k3)
57-Hide Network Icon
58-TenGO as Default Input Method (http://www.tengo.net)
59-Download up to 8 files simultaneously
60- 6 Suggested words in SIP
61-Caching SSL Pages
62-Reset Soft Reset Counter to 0
63-Alarm Fix for Windows Mobile 2003
64-Wake Up PPC in full Power Mode
65-Change the identity of Netfront 3.1 to MS Pocket Internet Explorer
66-Save the email attachment in the selected storage card.
67-Enable ClearType in Landscape WM2003SE)
68-Turn Off ActiveX Controls
69-Turn Off Scripting
70-Show Scripts errors
71-Force SSL Off in Inbox
72-Enable/Disable Zero Configuration
73-Change the default keyboard skin in Windows Mobile 2003 using English or Spanish ROM.
74-Screen Rotation for Toshiba e310 and iPaqs 5400 and 5500 series.
75-Double Pixeling deactivation for individual programs in VGA Devices.
76-Allows you to move dlls from \Windows to any Storage Device
77-Allows hx4700 users to select any folder to keep the Dockware pictures.
78-Allows hx4700 users to rotate the screen in 180 degrees. That allows to use Control Remote software more efficiently.*
79-Disables the ATI BitMap Cache, this feature is known for causing error message in hx4700 when owner try to use a program made in .NET.
80-Clean the Recent Program List
81-Allows to change the default Terminal Service Client Port in your Pocket PC to any desired port.
82-Allows to disable the 'hold'-function of the hardware buttons which usually allows you to assign a second function/shortcut to a button in Loox 720s. This function causes a significant lag in button hit registration when playing games.
83-Smooth scrolling in Pocket Internet Explorer
84-Allows users to synchronize the device clock with NIST Internet Time Service (ITS).
85-Show AM or PM in the top bar clock
86-Small letters in Pocket Internet Explorer
87-Allows hx4700 owners to disable the TouchPad
88-Allows hx4700 owners to Turn OFF/ON the WiFi/BT LED
89-Disables BT/WiFi LED in HTC Blue Angels
90-Disables Power LED in HTC Blue Angels
91-Increase keyboard light time in HTC Blue Angels
92-Allows hx4700 owners to Turn ON/OFF the Power LED
93-Allows hx4700 owners to set the Power LED to Blink
94-Disables all LEDs in HTC Magician
95-Enables an editor in the Album application of HTC Magician
96-SMS Delivery Notification always ON
97-Unlimited 3gp recording
98-Allows to change registry mode in WM5
99-Allows to hide the rotation icon in i-mate JAMs
100-Change the location of NetFront Cache Folder
101-Increase the PNP Unload Delay
102-GPRS always ON
103-Enables the keyboard status indicator in HTC Wizard/QTek
104-Allows to select Microsoft Voice Commander as default dialer in Jasjar and other Phone Edition devices from HTC.
105-Remapping of Today Soft Keys
106-Optimum Cache Size for WM5
And more....
* - Move dlls to the faster Storage Device, if it's possible to ROM Store. SD Devices are slower and in some cases they could cause some problems with this trick.
Now Windows Mobile 2003SE, full VGA and Windows Mobile 5 Compatible ..
Note: This version only works in English, German, Spanish, Portuguese, Italian, French, Japanese and Chinese ROMs. XScale Compatible.
.NET Compact FrameWork from Microsoft is required in PPC2000 and PPC2002 Pocket PCs.
Link dùng thử đây các bro
http://www.pocketgear.com/software_detail.asp?id=2724
Cần thì PM nhe
trùi, bác cho e tí tiếng việt đi, nhìn đống tiếng Anh hoa mắt rùi...hic
Túm lại nó là phần mềm chỉnh sửa Registry, với 116 cách sửa registry như tăng tốc độ hiển thị, GPRS,v,v,v
Bạn chịu khó vọc một lúc là hiểu ngay thôi mà.
