UIQ3 Custom Firmware making guide
gabika318
SE PDA CUSTOMIZER v2.5 FINAL
UIQ3 Custom Firmware Guide
by gabika
SE PDA Customizer decrypt, unpack, repack and encrypt your Sony Ericsson (SEUS) firmware files .
Easy way to make UIQ3 Custom Firmware.
Supported phones: P990 M600 W950 P1 W960 G700 G900
Version History
1.0 First version
1.1 Added help menu
1.2 Small fixes, Added "Make More Free Space" menu
1.5 Small Fixes, Added Mods menu
1.6 Added FW file checker component
2.0 Total reprogrammed, fixed all component, easy menus
2.1 Fixed and add mods to Mods Collection menu
2.2 Small bugfixes, added Log window and other mods
2.3 More Mods, Some bugfixes
2.4 Small bugfix (check byte bug)
2.5 Fixed Decrypt/Encrypt function, FINAL VERSION
How To Use:
Uninstall SEUS and reinstall latest SEUS version
Flash your phone with latest ver. SEUS
Find your phone customisation fw file
This file 5-10 MB
Place: \Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\ folder
M600i example: c:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\FILE_275195397
P1i example: c:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\FILE_275808810
RUN SEPDACUSTOMIZER.EXE
Select fw file...
After select fw: fw file copied to SPC2 folder
Firmware checking component
If you select correct customization FW file
immediately proceed next step
NOW COPY OR MODIFY YOUR FILES IN ROFS-FILE*** FOLDER
If you select any other FW file
Application restarting and auto deleting all selected FILE_* files and folders
OR USE MODS COLLECTION MENU
Ready to Firmware Repack and SEUS Encrypt
How To Use - SE PDA Custom Firmware
http://www.youtube.com/watch?v=g5LTuSGlWbA
how-to-use-se-pda-cfw.mpg - 67.4 MB
[MPEG-1 format]
If you need CDA number modding
start tutorial from OPTIONAL STEPS
Any other
start tutorial from REQUIRED STEPS
!!!USE AT YOUR OWN RISK!!!
Custom firmware making guide
Sony Ericsson M600i Custom Firmware
M600i contvert W950i (Custom Firmware)
M600i contvert P1i (Custom Firmware)
Đây là thành quả nghiên cứu của một số thành viên cấp cao và đam mê UIQ3 bên aioboards.com(persian-forums.com ngày trước). Gabika318 là một trong số đó, nên không có tiếng Việt là bình thường. Bạn có thể sử dụng tính năng Translate của google để tham khảo bài viết này, hoặc VDict.com cũng dc.
hình như là có FW mới cho uiq3 hả. tò mò quá. không có tý tiếng việt nào. chờ chủ thớt update
Admin! Plz, translate my post... Thanks........
Vì em đã dùng Google dịch rồi nhưng không hiểu gì cả.:(
SE PDA CUSTOMIZER v2.1
by gabika
SE PDACustomizzer là phần mềm giúp mã hóa, giải mã, nén và giải nén
những file Firmware của ĐT SE.Hỗ trợ ĐT: P990,M600,W950,W960,P1,G700,G900
Version History
1.0 First version
1.1 Added help menu
SPC21.rar - 10.7 MB
How To Use:
Sử Dụng:
This file 5-10 MB
Gỡ bỏ SEUS(Sony Ericsson Update Service) và cài lại SEUS bản mới nhất
Chạy lại FW cho ĐT với FW mới nhất.
Tìm file FW tùy chỉnh của ĐT, file này khoảng 5-10MB trong\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\folder
Ví dụ như M600 thì file sẽ là: FILE_275195397 theo đường dẫn: c:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\FILE_275195397
Sau dó chạy file:
SEPDACUSTOMIZER.EXE
Select fw file...
Chọn File FW...
Sau khi chọn FW: FW sẽ được copy vào thư mục(của) SPC2
SEUS FW File Decrypt
Decrypts all FILE_*** to FILE_***.gz and renames FILE_*** to FILE_***.old
and Firmware Unpack
Unpacks all FILE_***.gz files and extracts to rofs-FILE_*** folders
Giải mã file FW của SEUS
Giải mã tất cả các file FILE_*** thành FILE_***.gz và đổi tên thành FILE_***.old
và giải nén file FW
Mở tất cả các file FILE_***.gz và bung vào thư mục rofs-FILE_***
Phần mềm sẽ tự động kiểm tra thành phần file FW, nếu bạn chọn đúng file FW, phần mềm sẽ tự đọng chuyển sang bước kế tiếp ngay lập tức.
Bây giờ bạn sẽ chép hoặc mod nhưng file này trong ROFS-FILE*** FOLDER( mod miếc các thứ)
Application closed and auto deleting all FILE_* files and folders
Nếu chọn không đúng FW( FW khác với dòng máy của bạn) thì ứng dụng sẽ tự đóng lại và tự xóa hết những file FILE_*** và các thư mục.
Bạn có thể mod thủ công hoặc sử dụng Menu mod được cung cấp sẵn trong SE PDA Cutomizer
Firmware Repack
Forms rofs2r.img files for contens of each rofs-FILE_*** folder and renames to FILE_***
SEUS Encrypter
Packs each FILE_*** to GZIP archives FILE_***.gz and encrypts to FILE_*** files
Đóng gói FW
Sắp xếp lại các file chứa trong thư mục rofs-FILE_*** và đổi tên thành FILE_***
SEUS Mã hóa
Đóng gói mỗi file FILE_*** thành định dạng GZIP(FILE_***.gz) và mã hóa thành những file FILE_***
(Optional) Folder Cleaner
Delete rofs-FILE*** folder and FILE_*** files
(Tùy chỉnh) Dọn dẹp thư mục.
Xóa thư mục rofs-FILE_*** và những file FILE_***
Start SEUS, select your phone and start flashing
When show download complete and flashing started,
Copy modded FILE_xxxxxxxxx to c:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\ folder and overwrite original fil
Khởi động SEUS, chọn ĐT của bạn và tiến hành Flash.
Khi SEUS hiển thị hoàn tất quá trình Download và bắt đầu Flash, chép đè file đã được mod FILE_xxxxxxx vào c:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\ folder
Wait 5 min and SEUS stop with error...
DONT PANIC!!!! Turn on your phone, and make a hard reset....
Đợi khoảng 5 phút, SEUS sẽ báo lỗi và dừng Flash....
Đừng lo gì cả nhé!!! Mở ĐT và thực hiện thao tác Format ổ C
Enjoy!!!
Before flashing make GDFS Backup!
TRƯỚC KHI THỰC HIỆN NÊN SAO LƯU GDFS
CÓ RỦI RO KHI THỰC HIỆN, MONG ANH EM NGHIÊN CỨU KỸ TRƯỚC KHI THỰC HIỆN.
YOUTUBE VIDEOS:
watch
UIQ3 Custom Firmware Making
Mình dịch lại theo đúng nguyên văn của chú Gabika318, có sự trợ giúp của Vdict.com và LacViet MTD. Nếu có sai sót gì thì do vốn tiếng Anh ít đụng tới nên bay biến đi nhiều ít :D, mong anh em bỏ qua cho.
Cái này em vẫn chưa hiểu lắm. Tóm lại là tác dụng ntn so với FW nguyên bản hả bác?( Sr vì em mới chơi nên còn hơi ngu )
Có thể hiểu như thế này: Sau khi update FW bạn phải mod, hack lại máy, nhưng sau khi thực hiện custom FW thì bạn sẽ không phải mod và hack lại máy ngay cả khi Format ổ C, thậm chí bạn có thể lược bỏ một số ứng dụng không cần thiết trên máy giúp lấy lại nhiều bộ nhớ trống hơn. Tuy nhiên quá trình này có một số rủi ro nhất định khi thực hiện. Bên forum aioboards vấn đề này cũng khá hot. Bạn có thể tìm và tham khảo theemnhes. Đi rước thèng Nokua con.....:D:D:D....
by gabika
Version History
1.0 First version
1.1 Added help menu
Many thanks to the software. There are problems with this page aioboards bro? I can not access anymore.
