WM6.1 Professional(build 19213.1.0.4) RAMDisk-32MB Pagepool_32MB for Hima
swampy395
Supported Device's
O2 XDA II, T-Mobile MDA II, Qtek 2020, iMate Phone Edition, TSM500, and other PH10 variants
2 versions HTC Style and Blue Silk HTC Style
Other Info
Media player 10.3
Pictures & Video (Full directory options)
Lots of reg tweeks
Added
HTC dialer skins
HTC calc skins
HTC 6 button comms manager
HTC Media Player skins
New programs folder icons
Tweeked internet settings faster searches and instant back
Screen OFF when playing music
Perfect bluetooth stereo playback
SD WIFI Card Compatable
Removed
Welcome Centre
Customer feedback Crap
Apps
FTouchFlo
FTouchFlo config
Clear temp
Netwowk Wizard (auto launch turned off by default)
Mode SMS
PHM Traylaunch
Quick Menu (You will need to set this up for Clear look set background image to Default_stwater_240_320.gif)
SyncroTime
FDC Taskmanager
WM5 NewMenu
WM5 Storage
WM Player 10
SoftKey Appalet
Adcanced Config
PIM Backup
Total Commander
Eten Zoom SMS
(plus all the standard stuff)
There still some room left in the rom (8f)free sectors, Will add some more stuff give me some idears please
ExtRom package
ArcsoftMMS4.2.8.1.CAB
HTC Home.2.1_1005.722v2b.CAB
HTC Audio Manager Today Plugin.CAB
MMS_enable.CAB
Office_6.1.AdobeLE.CAB
PacMan2.Invaders.CAB
UltimateLaunch.CAB
spb_gprs_v2.20(build487)_magician_wwe_1007_cid.CAB
Tcmdpocketarm.CAB
TcpmpFlashVideoBundle.CAB
Windows_Live_10.6.0034.0800.CAB
zHimaExtSetup.CAB (some ring tones and reg Tweeks
ADDED 16/09/2008
SAP_Settings (Required for Car Kits hands free audio systems)
BlueTooth ON/OFF (A quick toggle ON/OFF)
New_SMS shortcut
CamRecSvc.cpl icon
PHM Font Changer.cpl
Pocket Tweak.cpl
Removed
FTouchFlo shortcut from startup menu
Both roms are the same spec and have 5 sided cubes pre set by extrom
Download HTC Styled rom
http://www.4shared.com/file/6338130...219213104SY395_32PP_6128Prog_32_RD_FINAL.html
Download Blue Silk HTC Styled rom
http://www.4shared.com/file/6325703...219213104SY395_32PP_6128Prog_32_RD_FINAL.html
Download EXTrom
http://www.4shared.com/file/56711973/3b8a3bb4/ExtROM_19213104B.html
Also A big THANKS to Sonblack for the base ROM and all the others how share there work on these sites
THANK you ALL
On behalf of PDAVIET forum, thank you so much for your sharing about this ROM. Welcome to PDAVIET.
It look nice and strange. :D
bản rom này khá hay đấy nhưng khi sài thì cái phần refresh nó k hoạt động nên những thay đổi hệ thông nó không hiểu liền mà phải đợi khởi động lại máy.! và thêm phần fone nữa nó hiện ra nhưng thanh taskbar thì k thay đổi thành chử call và k có nút gọi bạn à. bạn có thể sữa lại nha.
chào bạn ! bạn có thể cho mình đường dẩn code của mediaplay trong bản rom này k vậy.Mình thấy nó rất hay vì nó chơi được nhiều định dạng không cần dùng phần mền nào khác.! thanks bác trước nha.!!!
Help please can someone translate the above replies By tiensylao ?Sorry I can only read English Thanks in advance swampy395
Translate into English:
Hi! Would you like to give me the link of mediaplay on this ROM? I think it very well because it can plays so many format without using other softwares. Wait for your answer. Thanks much.
Sorry It would only be of use if you could cook rom's But you can copy the reg entries to some other device with regedit hope this helps
PS Thanks "hibiki" for your translation
thank you to who translated service share of question answering own!
can you snub phantom ROM upper that it be when change then it can freshen spruce system neither so himselfs ?
