WM6.1 ROM - PROPHET CE OS 5.2.20748 (Build 20748.1.4.0 PV)
Sonblack
Super V.I.P
PROPHET BLACK
===== Core 5.2.20748 Build 20748.1.4.0 PV =====
Lời cám ơn - Thanks:
Manager PhamQuang (everything)
ROM Dev Dvha79_ddt (others)
Mod Lamson (others)
Mod Hoangdat_vista (others)
Trial Mod Medkid (others)
Trial Mod PhamNhatThanh (others)
Trial Mod TranMinhMan (all skins for Calculator, Windows Media Player, Comm Manager; Theme and Welcome Screen)
Trial Mod nhocbanme (IrDA and Bluetooth)
Trial Mod khacduy1978 (GPRS)
Thông tin ROM - Information:
- Core 5.2.20748 Build 20748.1.4.0 PV
- ROM Version: 2.20.8.48 WWE
- ROM Date: 7/09/08
- No bigstorage.
Hình minh họa - Illustrative Images:
Các chức năng chính - Main Functions:
- CE OS 5.2.20748 Build 20748.1.4.0 PV
- .NET Compact Framework 3.0.7283.0
- Office Mobile 6.1
- Office Note
- Windows Media Player 10.3 Build 20748
- ArcSoft MMS v5.0.31.19
- Advanced Configuration Tool v3.2 by Julien Schapman
- ClearTemp v1.0.3 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.55
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Total Commander CE v2.51 by Christian Ghisler
- PocketScreen v1.3 by JJM. Roseboom.
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun 2.0
- and more ...
Link tải ROM - Download link: Link is available now - Link đã có sẵn.
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
Giải nén file ROM với password:
SONBLACK
Uncompress ROM file with password: SONBLACK
Máy của bạn cần được HardSPL trước khi Up ROM này!!!
Your PPC has to HardSPL before flashing this ROM!!!
Sonblack
Hoan hô anh Sơn đã có rom mới cho prophet, anh em sử dụng prophet lại có rom mới để vọc rồi.=D>=D>=D>=D>
hoan hô bác Sonblack sau mấy tháng ngừng build giờ lại bắt tay vào build cho anh em PV thà hồ vọc =D>
Welcome Mod Sonblack tái xuất box Prophet
thuê chỗ Hoang An chút :)) - Lamson
Box Prophet đông vui nhỉ!;;)
2 bản ROM lên cùng 1 ngày, các mem tha hồ mà vọc!:))
Chúc mừng ROM Dev Sonblack!=D>
Tại TMod TranMinhMan nói làm người ta dang kiện Box Prophet đây này :D:D
sao Box wiza lâu rồi mà yên ắng quá vậy, mọi người sang Box Prophet mà xem, ở đó hôm nay có 2 rom 1 lúc luôn
Lamson
Lamson
:))chết thật bị kiện tùm lum nên vậy:D giao diện của bác sonblack đẹp thật đáng để học hỏi ^^ em kết cái giao diện media rồi ^^
Giao diện trong rom của a Sơn thì không có gì phải chê cả. Luôn luôn cập nhật và làm hài lòng tất cả mọi người . Chúc mừng a Sơn . chúc mừng box prophet có rom mới đẻ test . Mời các mem của prophet sang box atom giao lưu và xem các bản rom của a Sơn
it works good
but htc home item list is empty
any attempt to activate phone profiles the home disapear
Please check again. Nobody here and I haven't a such trouble. Thank you!
cái item đó bị thật đây bác, vào không có mục nào chỉ màu trắng đã lỡ vào rồi khi tắt đi thì cái htc home sẽ không còn item nào cả
1) Vào list các items của HTC Home trong Settings/Today thì chỉ nhìn thấy các ô tick chứ ko thấy nội dung.
2) Nếu cài Battery Status, khi tap & hold vào ô báo pin để xổ menu thì cũng ko thấy tên các mục menu đâu cả, chỉ thấy xổ ra 1 menu bé con con.
cái HTC Home nếu để bình thường xài thì ko sao,nhưng chọc vào phần HTC Home để thêm bớt item là có chuyện ngay,màn hình HTC Home chỉ còn cái khung,mất đồng hồ,nói chung mất sạch :(
Lý do đơn giản là tận dụng khoảng trống của ROM nên dùng phương pháp nén các file dll của HTCHome. Hậu quả là như vậy đấy.
Bản tiếp theo sẽ khắc phục vấn đề này. :D
