WM6.1 ROM - PROPHET CE OS 5.2.20765 (Build 20765.1.4.4 PV)
Sonblack
Super V.I.P
PROPHET MANILA V2.6
===== Core 5.2.20765 Build 20765.1.4.4 PV =====
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
herg62123, poorlyduck from xda-developers
Thông tin ROM - Information:
- Core 5.2.20765 Build 20765.1.4.4 PV
- ROM Version: 2.20.8.51 WWE
- ROM Date: 7/31/08
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- XIP & SYS from latest original ROM for HTC Iolite.
- Compress "LZX" standard.
- No bigstorage.
Hình minh họa - Illustrative Images:
Các chức năng chính - Main Functions:
- CE OS 5.2.20765 Build 20765.1.4.4 PV
- Internet Explorer 6 for Windows Mobile
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.81 (Iolite)
- Enlarge Start Menu (Moderate from Iolite)
- Enlarge TitleBar (Iolite)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20765
- Office Mobile 6.1
- HTC Album (Moderate from Elfin)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- and more...
Link tải ROM - Download link:
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
Giải nén file ROM với password:
SONBLACK
Uncompress ROM file with password: SONBLACK
Máy của bạn cần được HardSPL trước khi Up ROM này!!!
Your PPC has to HardSPL before flashing this ROM!!!
Sonblack
Híc, với tốc độ ra lò các bản rom mới như thế này thì chết em O2 Neo của em roài... Thanks bác !
Em đang sài thử rùi có lỗi gì em sẽ báo cáo sau hi hi. Mà bác cho em hỏi có thể thay đổi giao diện của em M2D được không bác!
E phát hiện ra một lỗi là nếu vào web bằng opera mini thì khi thoát ra cái M2D cứ bắt tab vào màn hình để chạy lại?
Mình có tìm nhưng mà chưa thấy nó ở chỗ nào cả bạn chỉ cho mình với!
mình đã test thử rồi, có một trục trặc nhỏ là nó không giữ lại mặc định của volum, mỗi lần nói chuyện điện thoại mình lại phải tăng volum lên thì mới nghe rõ.
best ROM mà tớ đã từng sử dụng.Chạy nhanh, ổn định, hình đẹp
nhầm đang dùng bản mới hơn O2 Xda Neo - Manilla Prophet Rom CE OS 5.2.20769 (Build 20769.1.4.5 PV)
Em không biết các bác thế nào chứ, em xài các bản rom có tích hợp M2D mà xem video bằng WMP hay bị đến giữa chừng thì bị giật và tắt luôn màn hình, muốn xem tiếp thì lại phải ấn nút Power mặc dù đã để mà hình luôn sáng khi xem video rùi, em đã thử các chương trình khác như SmartMovie, CorePlayer,.. mà vẫn bị. Còn chương trình nghe nhạc PocketPlayer thì cứ nghe đc một lúc thì tự dừng, lại phải ấn nút Power rùi click play thì lại chạy tiếp. Còn khi sử dụng bản rom ShadoW 2.0 TE thì lại không bị...
Đúng rồi mình cũng bị lỗi này. Mong mod Sonblack chỉ cách khắc phục!
Phần điều chỉnh Volume được port từ dòng khác sang nên cần được trau chuốt thêm ở các bản ROM sau. Mình đã thấy được vấn đề này lâu rồi và đang tìm hiểu để chỉnh sửa cho phù hợp. Hy vọng trong các bản ROM tiếp theo nếu còn dùng thì sẽ hoàn chỉnh hơn.
Chúc vui.
Bác Sonblack không dùng himalaya nữa hay sao mà không thấy có ROM mới cho hima? Chán thật!!!!!!!
Con Himalaya đó đã rời xa Sonblack lâu ròi mà bạn. Hiện nó đang ở nhà xác của BatKid kia mà! :D
1 điểm nữa là e dùng tự nhiên bị mất đồng hồ to ở ngoài vọc mãi mà ko thấy hiện lên
Chẳng có gì là tự nhiên mà vì bạn "vọc" mà hem biết là trúng chỗ nào khiến nó mất đó thôi :D HardReset lại cho chắc ăn rồi "vọc" tiếp hén, nhớ backup dữ liệu nhé. :))
theo nhận xét của e thi bản 20769 của bác dễ dùng hơn nhanh hơn bản này tuy dao diện ko bằng
Cái gì cũng có hai mặt của nó mà. Được cái này thì mất cái kia thôi. Thích trọn gói, toàn diện tìm đâu ra đây :))
mới up xong bản này rồi giờ ko cách nào sử dụng đc wifi, bác biết nên làm sao bi h ko?
Thử đổi bản rom khác thì nó tắt ngóm luôn ko cho làm gì.
Em dang dùng con O2 neo á
bác sonblack cho hởi có thẻ gỡ bỏ các phần mềm tích hợp giúp máy chạy nhanh hơn ko
Muốn gỡ bỏ chỉ có build lại thôi...việc tích hợp thêm Apps là vậy người muốn thêm vào, người muốn bỏ đi:-?
Mình xài ROM này bị 2 lỗi
thứ nhất : khi có tin nhắn tới thì ko đổ chuông , màn hình sáng lên thôi , đèn ko báo màu cam luôn
Thứ 2 : nhắn tin đi ko dc , chỉ nhận dc tin nhắn từ người khác về thôi
Con lại mọi chuyện OK
có ai xài ROM này bị như mình ko nhỉ ? ko lẽ ko xài tin nhắn luôn >.<
