XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20273) Ver. 2
Sonblack
Super V.I.P
PDAVIET ROM WM6.1
CE OS 5.2.20273 Build 20273.1.3.3 PV
(Update, fix...)
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20273 Build 20273.1.3.3 PV
- Pagepool: 6M
- Rom date: August 16, 2008
- ROM Version: 20080816C2WWE
- High Speed ROM.
- Based on the 20273 ROM but some changes
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20273
- Adobe Reader LE 2.5
- PHM TrayLaunch
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.49
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080610.2.1
- Pocket Screen v1.3 by JJM. Roseboom
- Total Commander CE v2.5 by Christian Ghisler
- SMS Display Mode by Sonblack (change message display on PPC)
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- Change some icons and sound effect menu.
Hướng dẫn - Guides:
Chỉ cần tải file .exe chứa ROM và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it, then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn.
The link is available now.
ATOM ROM 20273 Ver 2 - PDAVIET
PASSWORD for unpack: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Up cả ExtendRom để có được giao diện màu đen của
Wireless Manager.
Flashing with option "Update Item" is "OS+EXtendedROM" for having black skin of Wireless Manager.
Cuối tuần vui vẻ!
Have good weekend!
Sonblack
thanks Mr.SonBlack !
Ver 2 chắc chỉ sửa cái keypad VÀ chuyển tone màu đen thôi hỉ pác ? :d
bản này anh sơn làm lại mấy cái icon kìa.... lại được up rom rồi. Thanks anh Sơn
Hi A Sơn đã hứa với em là khi nào em sử xong cái Atom thì anh mới upROM mà sao hôm nay lại up rồi, làm em Downd Rom mà không có máy để test nà, ngứa tay không chịu nổi, mai mốt phải xử anh chầu cafe mới được .THANK ANH NHIỀU./.anh phẻ hông
Làm xong thì share cho mọi người chứ giữ thì cũng đâu được gì đâu em! Không thì chán lắm, máu me mà làm gì =))=))=))
Còn một số thay đổi nhỏ khác và cập nhật Version mới của 2 ứng dụng, nói chung test mới thấy :)):)):))
ANh SƠn quả không hổ danh ROM Developer .. hix .. cục ghiền lại chạy lên chạy xuống .. em nôn wá .. muốn test cái ROM mới nì .. thanks anh lần nữa
Em là em "cật lực" "yêu cầu" bác Sơn add cái này vào cho anh em. Em đã test 2 ngày nay, cải thiện tốc độ hiển thị đồ họa đáng kinh ngạc. Dễ thấy nhất là đối với các ứng dụng "vuốt" ! (FtouchSL, VietMap, PMContact, các soft S2xx ...). Các chức năng khác không bị ảnh hưởng vì nó chỉ là file dll Direct3D thôi.
{Bác nào đã uprom rồi thì cũng install cái này vào bình thường)
Bên cạnh đó ... hix, em cài nhiều soft quá rồi, bác Sơn có cách nào hướng dẫn em sửa cái dial pad lại như thế mà không cần phải uprom lại không ?!!!!
Cái này hình như chỉ là Driver hổ trợ cho chip samsung thôi mà bạn, mình test cũng chẵng thấy nó xi-nhê gì
Ặc ặc, đúng là được voi đòi hai bà trưng!!! Pó chúi mấy anh em nhà Atom luôn...:)):)):))
Cái Driver đó hem có tác dụng gì đâu =))=))=))
Anh là anh "cật lực" "đề nghị" tự xử thôi :)):)):))
Báo các anh em, em vừa up xong bản này .. để em test xong rùi báo cáo cho các anh nha.. hix.. mừng húm vì có ROM mới để dọc ..
Thanks anh Sơnblack nhìu nhìu.. chúc anh dồi dào sức khỏe :D
Chào bạn Son Black.
Mình chưa từng up ROM nên khi thấy rom mới có thể cài cho con ATOM đã đắp chiếu từ lâu ( nó vẫn chạy ngon nhưng chỉ vì pin hư ) mình vui lắm .
-Cái bản ROM này của bạn là cài từ PC hay thẻ nhớ vậy ? (hướng dẫn của bạn chưa cụ thể lắm ) có thể hướng dẫn chi tiết hơn một chút, để cho những người mới như mình VỌC với
Thanks.
"Hướng dẫn - Guides:
The only thing you have to do is download the .exe file including ROM and perform a double click on it, then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset."
trong phần Multimedia có bổ sung thêm đồ chơi => wá đã hì,
Đã test FM, bluetooth,.. rất good- GPRS bắt mượt mà, nhà em chưa có wifi nên chắc mai test típ hi`..
ngoài ra còn dc support speed voice dial ... kool .. bản ROM này good wá anh SƠn ơi.
@ Axing : bạn chỉ cần down về rùi double click cái file.exe của anh SOnBlack rùi đọc hướng dẫn mà làm theo .. cái ROM này bạn có thể cài từ PC hay thẻ nhớ đều được.
Cách trên chỉ dành cho PC -> PPC còn up bằng thẻ nhớ, bạn vui lòng đọc các bài trước trong PV nhé.
Thân :D
Mình tự test đâu có thấy hết. Có nhiều người test phát hiện thêm nhiều thứ vì vậy ROM sau phải tốt hơn ROM trước đúng hem?
Đó là lý do cần phản hồi từ mem.
Mình tham khảo ở XDA cũng biết là nó không dành cho ATOM, nhưng mình thấy bảo có máy khác (không dành cho nó) install vào cũng chạy tốt hơn nên cũng làm liều (sau khi full backup) install vào ATOM. Quả thật là về chất lượng hình ảnh mình không dám nói có hơn hay không (vì nó cảm tính quá). Nhưng về độ mượt mà của các soft vuốt thì bảo đảm ít nhất "ngọt" hơn 50% ! Không phải tự cảm giác đâu! Tiếc là không có soft kiểm tra (mình biết mỗi SKtool , nhưng sktool không chấm điểm cái này, chỉ chấm liên quan CPU).
Lúc trước mình thấy iPhone vuốt nhẹ nhàng thì thích lắm, giờ ATOM mình có thể nói đạt 70-80% iPhone về khoản vuốt mượt rồi ấy ! ;)
Edit:
Nói thêm xí, cái này là tối ưu cho chip Intel giống chip máy ATOM chứ không phải chip Sámung.
D3D Driver (Intel XScale Optimized D3DM Software Driver), this should work on most roms/devices. Go here for details http://forum.xda-developers.com/showthread.php?t=416474
this is only software optimization (Intel XScale Optimized D3DM Driver).
It only installs one file to your device: D3DMXSc50PB.dll and only import functions from 2 modules: COREDLL.DLL, DDRAW.DLL. So I guess it should work on most roms/device.
Just try it guys, you can uninstall it to go back to previous driver.
Cái ver 1 vẫn đang xài tốt ,hồi chiều ko hiểu sao bị lỗi dữ liệu gì đó ( "database error" ), khởi động chậm chạp và hư phần Wireless Manager nên có cớ up Ver 2 thử xem ( ko hiểu sao pác Sơn ra Rom mới thì máy móc lại nảy sinh nhiều vấn đề =))=))=)) ).... Và cảm nhận đầu tiên sau 1h vọc :
Hài lòng : mượt mà, đã sửa một số lỗi ( keypad ...) + thay đổi hiển thị một vài nơi ( Start Menu ...) + một số Ringstone + Một số ứng dụng mới và ver mới , Wifi , Bluetooth , Beam , GPRS ... đều tốt =D>=D>=D>.
Không vừa lòng : âm thanh khi khởi động (Startup) ... ( có thể thay đổi dễ dàng ) , nhưng không hiểu pác Sơn lấy đâu ra cái âm thanh quái dzi đó để thay vào nhỉ >:)>:)>:), + giá như có một trình đọc .PRC kèm theo thì quá tốt ! ;;);;);;)
Bản này kế thừa bản 20273 (Ver1) đã ổn định , chắc này còn ổn định hơn !
Khi ko chạy Plugin HTC Home thì ở chế độ chờ pin có thể lên gần 2 ngày ... Không hiểu do pin mình good hay Rom đã cải thiện phần pin nhỉ :p:p:p
Đã giải thích rồi vậy mà cứ "được voi đòi Hai Bà Trưng" là sao? :-?:-?:-?
Ứng dụng khác thì tự cài đặt, không phải làm ROM để rồi mọi người lại chờ mọi thứ có sẵn, càng nhiều soft có sẵn trong ROM, ROM chạy càng chậm đấy.
Yêu cầu này không chính đáng à nha :D
