XDA mini S chạy được chuẩn wifi G chứ không phải chuẩn B ai đã thử chưa??
truong_online
xem ở đây thấy bài này http://www.handheldvn.com/forum/showthread.php?t=32786
WLAN G in all Wizards - It works!
THANKS DJVW! It works great!!
I had to soft-reboot twice. It just hung the first time I rebooted, but I was still connected on ActiveSync. The second time I rebooted and disconnected the USB/sync cable. So I don't know if two reboots were needed or it just needed to be rebooted while disconnected from ActiveSync. REGARDLESS, it is REALLY faster than before.
BEFORE LOADING:
I went to http://text.dslreports.com and got the following scores:
600k : 403 kbit/sec
200k : 381 kbit/sec
AFTER LOADING:
600k : 818 kbit/sec (TWICE as fast)
200k : says this: "unstable/too fast a result (3.04s) please choose a larger file" -- interesting that it is now too fast for the 200k test. But at 3.04s, that is 200kB*8bits/byte = 1600kb/3.03s = 528 kbit/sec (almost 2x fast again)
I really like the keyboard notification as well (for Caps and the Function-key [the circle/dot])
Highly Recommend!!
