Xin hướng dẫn cài driver ổ cứng Sata SZ72B/B
arigatoo
Số là mình cài lại windows XP bản tiếng Anh từ máy mua về từ Nhật. Do đó phải cài lại driver cho ổ cứng SATA, nhưng khi cài xong thì vào BIOS không biết làm thế nào để Enable cái SATA đó :(. Mong mấy huynh chỉ giáo. Thanks so much.
Tiện thể mình chia sẽ luôn hướng dẫn
Here's how:
1) Download the Intel Matrix Storage Manager here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101&lang=eng
2) Once you download the file, run it with a -a switch:
iata76_enu.exe -a
This will NOT install the Matrix Storage Manager. What this will do is
run the installer, and ONLY EXTRACT the files to C:\Program
Files\Intel\Intel Matrix Storage Manager. Again, this does NOT install
anything.
3) Your drivers are now located in C:\Program Files\Intel\Intel Matrix
Storage Manager. They will be found in either \Driver, or \Driver64,
depending on whether you're running a 32-bit or 64-bit OS.
4) Go to Device Manager --> IDE ATA/ATAPI controllers. Double-click on
the Intel ICH8M 3-port SATA Controller - 2828... remember, *ONLY*
click on the device that ends with 2828.
5) Go to Driver tab, and choose to Update Driver.
6) Tell the Wizard prompts:
- No, not this time
- Install from a list or specific location (Advanced)
- Don't Search. I will choose the driver to install.
- Click the "Have Disk" button. Point it to C:\Program
Files\Intel\Intel Matrix Storage Manager\Driver (or Driver64).
- The driver you want to install for WinXP 32-bit for the Dell XPS
M1330 is Intel 82801HEM/HBM SATA AHCI Controller
- After you install the driver and click OK out of every menu, reboot
the laptop.
7) During reboot, go into BIOS and turn on AHCI mode and Flash Module
8) Voila! WinXP will boot up with no BSOD!
1. bác kiếm ổ mềm USB và 1 cái đĩa mềm
2. bác vào trang chủ Down driver SATA về rồi bung ra đĩa mêm. Cắm đia mềm cúng với cài win .Khi bắt đầu cài thì ấn F6 lúc bắt đầu chuyển màn hình sang nền xanh XP . để load driver SATA . Chúc bác thành công
Nếu bác cài ko dc và bác ở HN thì mang qua chỗ e cài giúp bác. Số 56 ngõ 178 thái hà
Cảm ơn bác dichvulaptop nhiều. Rất tiếc là mình đang ở TP HCM. Tuy nhiên, theo hướng dẫn trên thì sau khi đã cài win rồi, sau đó cho ổ cứng nhận driver SATA sau. Mình làm được đến đây nhưng vào BIOS của máy SONY thì không biết làm thế nào để Enable cái SATA ấy được.
