dinhtuandung2012
Manager
(Android 4.0.3)(AOSP ICS ROM for HD2)NexusHD2-IceCreamSandwich Beta10 by Tytung (xda-developers)
Đây là bản Rom ICS (Android 4.0.3) Beta10 của tác giả Tytung bên XDA dành cho HD2. Thanks Tytung!
Tham khảo thêm tại http://forum.xda-developers.com/showthread.php?t=1354267
Hình ảnh minh họa:
![NexusHD2-IceCreamSandwich_Alpha1_%28Android-4.0.1%29_01.png](https://lh3.googleusercontent.com/-surDPwgTnYc/TsiPQUbbTTI/AAAAAAAAUTY/nypAo74TweQ/s400/NexusHD2-IceCreamSandwich_Alpha1_%28Android-4.0.1%29_01.png)
![NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_02.png](https://lh5.googleusercontent.com/-TbhBR2fSscw/Ts09PJKr-8I/AAAAAAAAUXM/QMn_DJKLloU/s400/NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_02.png)
![NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_04.png](https://lh5.googleusercontent.com/-7tXkGiJ2Y8I/Ts09QBG6pLI/AAAAAAAAUXU/PUXPP70upSs/s400/NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_04.png)
![NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_05.png](https://lh5.googleusercontent.com/-2RyeBk16O-M/Ts09SaYgXYI/AAAAAAAAUXo/N3exBY-RaVE/s400/NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_05.png)
![NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_08.png](https://lh5.googleusercontent.com/-p16rUhKKQO8/Ts09kHJdr1I/AAAAAAAAUYQ/X6kaJbchioc/s400/NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_08.png)
![NexusHD2-IceCreamSandwich_Beta3_%28Android-4.0.1%29.png](https://lh5.googleusercontent.com/-nMBh6glEYdc/TtkK3jnav8I/AAAAAAAAUeE/wgyLgAq7kK4/s400/NexusHD2-IceCreamSandwich_Beta3_%28Android-4.0.1%29.png)
![NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_07.png](https://lh5.googleusercontent.com/-_9k8AfeBwaw/Ts09Rq1msuI/AAAAAAAAUXs/oN3qFqQen8I/s400/NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_07.png)
![NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_03.png](https://lh5.googleusercontent.com/-Nf0SFQavWcQ/Ts09M0QwN6I/AAAAAAAAUW8/1FtJFs1SICs/s400/NexusHD2-IceCreamSandwich_Beta2_%28Android-4.0.1%29_03.png)
Video:
[video=youtube_share;LChoaaLBTDQ]http://youtu.be/LChoaaLBTDQ[/video]
Đã hoạt động:
- Phone Calls
- Audio (Credit to firesnatch and texasice.)
- SMS
- Data: 3G/HSDPA (RMNET for MAGLDR) or (PPP for cLK)
- Wi-Fi
- Bluetooth (in-call works)
- GPS and AGPS (Credit to all AGPS devs.)
- Touchscreen
- Vibration
- Charging
- All sensors
- BMA150 3-axis Accelerometer
- AK8973 3-axis Magnetic field sensor
- AK8973 Orientation sensor
- CM3602 Proximity sensor
- CM3602 Light sensor
- Wired earphone/headphone (Credit to zivan56.)
- Data usage (i.e. Network Stats and Quota) (Credit to tytung.)
- Hardware Acceleration OpenGL (Credit to rapmv78 and so on.)
- Hardware Acceleration OpenMAX codecs (Credit to ankuch.)
- Software video codecs (Credit to ankuch.)
- WiFi signal strength icon. (Credit to rmcc.)
- USB Mass Storage (Credit to tytung.) (Full working)
- Camera (Credit to rapmv78.) (Still buggy. Visit rapmv78's camera thread for more info.)
- Native WiFi Tethering
Chưa hoạt động:
- Native USB Tethering
- VPN (Not test on 4.0.3)
Downloads:
- ROM: NexusHD2-IceCreamSandwich_Beta10.zip
| mirror
| (Please don't mirror. Thanks.) | md5sum: C65A80D7C15180105FF32FAE867143C9
- cLK kernel: NexusHD2-Kernel_2.6.32.15_tytung_ICS_Beta8-v2-cLK-update.zip.
- MAGLDR kernel:NexusHD2-Kernel_2.6.32.15_tytung_ICS_Beta8-MAGLDR-update.zip. (This is included in the ROM in default.)
Cách cài đăt:
- Please use at least 190MB system partition and at least 2MB cache partition.
- Please refer to ksubedi's HD2 NAND Toolkit and/or mskip's guide.
- Cache partition (/dev/block/mtdblock4) is only used by CWM.
- Cache partition size is not important because the data partition (/dev/block/mtdblock5) is used as the cache space when running Android.
- If your HD2 has bad NAND blocks, you may need larger partitions.
- Wipe
- Wipe Data/Factory Reset while doing a fresh install.
- Advanced -> Wipe Dalvik Cache while upgrading and wanting to retain data.
- Flash the ROM.
- MAGLDR: Flash NexusHD2-IceCreamSandwich_Beta10.zip, then reboot.
- cLK : Flash NexusHD2-IceCreamSandwich_Beta10.zip and NexusHD2-Kernel_2.6.32.15_tytung_ICS_Beta8-v2-cLK-update.zip, then reboot.
Lựa chọn khác:
- Enable/Disable the virtual soft keys (i.e. the on-screen virtual button):
- Flash framework-res.apk_v403_without_softkeys.zip (Default in the ROM.)
- Flash framework-res.apk_v403_with_softkeys.zip (To fix the overlay of the softkeys and the keyboard, install ICS keyboard from the Market or get the apk here.)
- Two tutorials about how to enlarge your internal storage.
- About the mobile data connection types: RMNET V.S. PPP.
- Bootloader MAGLDR supports RMNET and PPP. I set RMNET as default for MAGLDR ROM since beta 9 because stock Android only supports RMNET.
- Bootloader cLK only supports PPP.
- RMNET is more stable than PPP. (Some PPP users have data drop issues.) However PPP may be faster.
- Flash RMNET_to_PPP_update.zip if you prefer PPP on MAGLDR.
Những thay đổi:
- Beta 10 (Jan. 3, 2012)
- Included ics_camera_fix_from_rapmv78.zip (Big thanks to rapmv78)
- Fixed USB Mass Storage for Android 4.0.3. (Credit to tytung)
- Fixed Facebook Contacts Sync. (You may need to delete contacts database or do a clean install.)
- Fixed Google+ FC for some users.
- Fixed native WiFi Tethering. (I think it was fixed since upgraded to Android 4.0.3.) (Please confirm.)
- Beta 9 (Jan. 1, 2012)
- Upgraded to Android 4.0.3 (Built from N1 source code with HD2 device configurations by tytung. Thanks to the Evervolv team. git://github.com/Evervolv/android.git -b ics)
- Included the latest Google Apps from stock Nexus S ROM v4.0.3 (IML74K). (Deodexed and zipaligned by tytung.)
- Set RMNET as default mobile data connection for MAGLDR.
- Added Facebook Sync. (Credit to Paul and Romanbb.)
- Added back some stock AOSP settings which are disabled by the Evervolv team, e.g. CRT off effect. (By tytung)
- Included reboot and screenshot options in the Power menu. (Credit to the Evervolv or CM team?)
- Included new 3way style Lockscreen. (Credit to the Evervolv team)
- Beta 8 (Dec. 28)
- Included 2.6.32.15 ICS beta8 kernel: (credit to tytung)
- Added InteractiveX and set it default
- Updated the ramdisk (initrd.gz) to support USB Mass Storage.
- Fixed USB Mass Storage. (credit to tytung)
- Fixed Bluetooth in-call. (please confirm)
- Included ankuch's alpha camera fix.
- Updated su binary v3.0.3.2.
- Updated Google+ v2.3.0.
- Removed Thinkfree.apk, VideoEditor.apk, Videos.apk to save space.
- Added new framework-res.apk for USB Mass Storage fix.
- Flash framework-res.apk_v401-UMS_fix_without_softkeys.zip (Default in the ROM.)
- Flash framework-res.apk_v401-UMS_fix_with_softkeys.zip (To fix the overlay of the softkeys and the keyboard, install ICS keyboard from the Market or get the apk here.)
- Beta 7 (Dec. 18)
- Upgraded Google Apps and some system apps and libs from the latest stock 4.0.2 (ICL53F) ROM. (No 4.0.3 ROM at the moment.)
- Included rapmv78's new EGL fix. (No more "unable to dequeue native buffer" errors in logcat.)(It seems more stable and no Maps FC for me). (Credit to rapmv78, rmcc, TwistedUmbrella, etc.)
- Updated to Market 3.4.4.
- Updated to Google Maps 6.0.3.
- Beta 6 (Dec. 14)
- Included 2.6.32.15 ICS beta6 kernel (Credit to tytung):
- Supported "Data usage" (i.e. Network Stats and Quota) (Backported xt_qtaguid and xt_quota2.)
- Updated the WiFi driver. (Backported bcm4329 from tuna 3.0 kernel.)
- Improved the read speed of the SD card. (Set VM_MAX_READAHEAD to 1024 kbytes.)
- Included the new system apps from the latest ITL41F ROM. (Compiled from the source code by tytung.)
- Showed the WiFi signal strength icon in Status Bar. (Replaced with wpa_supplicant v0.8.x.) (Credit to the CM team.)
- Beta 5 (Dec. 8)
- Included EGL v6.1 (Credit to Ankuch)
- Hardware Acceleration OpenMAX codecs (still software render but cpu usage drop from ~100% to ~70% while playing video, better CPU Quadrant scores).
- New EGL hack can improve stability.
- Removed wpa_supplicant_adhoc_fix_v0.6.10ah_update.zip (It seems to cause WiFi issues for some users.)
- Beta 4 (Dec. 6)
- Included SystemUI.apk_v401_with_HSDPA_icon.zip to be able to see H (HSDPA) icon in the status bar.
- Included wpa_supplicant_adhoc_fix_v0.6.10ah_update.zip to be able to see Ad hoc WiFi.
- Included Galaxy Nexus Gallery to be able to sync Picasa / Google+ Albums
- Included 2.6.32.15 ICS beta5 kernel
- Rebase to .32.15 and include the wired earphone/headphone fix.
- No SD message bug.
- No Data usage (i.e. Network Stats and Quota) support so far.
- Included EGL v.5.1 (Credit to Ankuch)
- Fixed builtin software video codecs (Credit to Ankuch)
- Due to software rendering & color conversion leads to high cpu usage & drops frames.
- But now working built in player, YouTube, Quadrant & possibly others programs.
- Beta 3 (Dec. 3)
- Included the latest Google Apps from stock Galaxy Nexus ROM ITL41F. (ROM dump by paul. Deodexed and zipaligned by tytung.)
- Included the latest 2.6.32.45 ICS kernel Beta3 for HD2. (Upgrade from r14 (2.6.32.15) kernel and add something by referring to this android-tegra-2.6.32-ics.) (Credit to tytung and rmcc.)
- Added EGL v5 for hardware acceleration. (Credit to ankuch.)
- Added dictionaries to support spelling correction. (LatinImeGoogle.apk from stock Galaxy Nexus ROM.)
- Added Live Wallpapers.
- Added the latest hosts file (November-23-2011) for blocking ads.
- Added Camera.apk. (Camera doesn't work yet.)
- Fixed the wired headphone issue by using the new kernel. (Credit to zivan56 for the patch.)
- Fixed data usage (i.e. Network Stats and Quota) features by using the new kernel. (Credit to tytung.)
- Fixed the color banding issue. (Credit to ankuch.)
- Removed Chinese and Japanese IMEs.
- Beta 2 (Nov. 24)
- Included the real audio fix. (Sound is perfect now.) (Credits to firesnatch and texasice.)
- Fixed Calendar Sync (Used Calendar.apk from Paul's leaked ICL23D dump.)
- Removed the softkeys. (Only framework-res.apk is modified.) (Credits to texasice (aka drewis).)
- Changed ro.sf.lcd_density to default 240 and included Nexus One Gingerbread 2.3.6 GRK39F release-keys in build.prop for best Market compatibility.
- Changed to Desire Gingerbread's stock default.acdb (129,346 bytes) (CRC: B0DCA53A)
- Added PPP data connection support to MAGLDR and set it default. (PPP is stable than RMNET under ICS ROM currently.)
- Added Superuser.apk v3.0.7 and updated su and busybox.
- Added the latest hosts file (October-13-2011) for blocking ads.
- Removed Camera.apk.
- Improved the performance.
- Beta 1 (Nov. 20)
- Added gapps (Google apps and libs) from Paul's leaked ICL23D dump.
- Added Gmail, Google+, Maps, Market, GoogleMessager, News&Weather, GoogleSearch, GTalk, Youtube, etc.
- Fixed the audio (Replaced audio.primary.default.so and audio_policy.default.so) (Credits to rapmv78. And thanks Cruonit.)
- Fixed "0 dBm" signal strength. (Show the correct dBm value now.) (Added ro.telephony.ril.v3=1 to build.prop)
- Changed ro.sf.lcd_density to 220 to fix the overlay of the softkeys and the keyboard.
- Side effect: You cannot install some apps from the Market.
- Solution: change ro.sf.lcd_density back to default 240.
- Alpha 1 (Nov. 19)
- Initial release.
