[12-09-2010 UPDATE] PDAVIET - I8000 WM6.5 ROM (21914.5.0.93) - SB30
Sonblack
Super V.I.P
PDAVIET WM6.5 ROM - I8000 (SB30 UPDATE)
CE OS 5.2.21914 BUILD 21914.5.0.93
Lời cám ơn - Special thanks to:
Wes58 for his tool as my requirements (always the best support for me)
contable (Modaco) for his skin/mod of JMLToday version 3.00, his opinions about this, his more donations and all what he did for I8000 community and me...
omarjunior (Modaco) for graphical support in general and what he'll do for me in the future.
Admin Kawaguchi (for his tools to build sbr file), Manager PhamQuang (so much), Super Mod BatkidSuper Mod NhatToai (so much), , Adv Mod TranMinhMan, S Vip Tom_codon (all of them are from PDAVIET)
Member huyentrangallery (from Samsung Mobile Vietnam, supported I8000 device for cooking)
JHML (Xda-Developers) for his application, JMLToday
Gary Crutcher (Modaco) for his chicks wallpaper section.
Lancez (Modaco) for his opinions which I need to know and his big donation
dinik (XDA) for taskbar and lockscreen icons
jeffrey2000 for bubble icon support
Onderduiker, Jazz8, Henrie, koperko, wkmmx500, Ah Huat Low, fattmatt, Macarov Gelu, Monyozt, at_some, TemplarNeo from Modaco for their donations
Thông tin ROM - ROM Informations:
Basic ROM: XXJG5
ROM Date: 6 September, 2010
Language: only WWE
Pagepool: 8MB
Version: I8K21914JG5SB30
Hỗ trợ hiển thị phông chữ tiếng Hoa.
Chinese basic fonts are available in the ROM
Lưu ý: Trong trường hợp có vấn đề kết nối, vui lòng sử dụng Restore Connection trong Samsung Settings
Note: In case of data connection problems, please Restore Connections in Samsung Settings
Một số thay đổi ở phiên bản Update ngày 12.09.2010:
- Thêm lại SMS-MMS.
Add SMS-MMS again.
- Task panel đã được fix.
Task Panel is fixed.
- Loại khỏi ROM Arcsoft MMS.
Remove Arcsoft MMS.
- Tab SIM Access của hộp thoại Bluetooth đã fix.
Tab SIM Access of Bluetooth dialog is fixed.
- Thêm Extended FileExplorer.
Add Extended FileExplorer.
- Thay đổi một chút về hiển thị của LockScreen cho thích hợp.
Change a little about displaying for LockScreen.
Chức năng chính - Main functions:
- Core 5.2.21914 Build 21914.5.0.93
- JMLToday contable OMNIA II mod/skin version 3.00, chưa hỗ trợ màn hình ngang (cám ơn sự hỗ trợ của contable)
JMLToday contable OMNIA II mod/skin version 3.00, not supported landscape mode yet (thanks so much contable for his support)
- .NET Compact Framework Version 3.5.9198.00
- Office Mobile (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile)
- ING Change Font version 1.08 (thank Luigi.ING, www.mobilehtc.net)
- Orientation Detection v1.0.3584.9343 for Omnia II
- MSN Money (Removed)
- MSN Weather (Removed)
- Marketplace
- SRS WOW HD for OMNIA II
- FlashLight
- VnKeyb v2.2.0 by ntd (Skin from hanoiwap, included Set Keyboard in English - Thanks Super Mod Tmap)
- Java_JblendPackage_2_1_2_1_20090429_2_1_R6 from Topaz II
- AdobePDF_2_5_1_0_404840_03
- XDA SIM Show Hide
- Soft Reset (new version by Sonblack)
- SB ROM Settings (by Sonblack, support for installing more option applications after flashing with more improvements)
- Các ứng dụng cơ bản cho PPC với các phiên bản mới nhất gồm:
Basic applications for PPC with its latest version as follow
CleanRAM (v2.2), ClearTemp (v1.3.0.1), Total Commander (v2.52 beta 2), PIM Backup (v2.8), Synchro Time (v0.95), Advanced Configuration Tools (v3.3)
- Loại bỏ các ứng dụng không cần thiết mà tôi không thích (xem danh sách)
Removed more unnecessary utilities which I don't like! (see the list)
Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Face Book, Podcast, QIK, RSS Reader, Cube, MainMenu, OnlineWidget, Samsung Today, Video Editor, Digital Frame, Smart Search, Unit Converter, Video Editor, Application Store, Communities (Share Pix), Connected Home, Midomi, Task Switcher, SPlugin Favorites, Google Maps, Smart Memo, Smart Reader, Smart Sync, Youtube, My Files, Adobe Reader, Java, SMS-MMS (loại bỏ cùng với registry) ...
Vui lòng up rom bằng phiên bản Octans Downloader mới nhất. Phiên bản mới nhất là 2.14
Please flash the ROM by latest Octans Downloader version. Its latest version is 2.14
Một vài hướng dẫn trước khi up rom - Some guides before flashing this rom (caution!):
- Chép file SBExternal.sbr vào My Storage trước khi thực hiện up rom.
Copy file SBExternal.sbr to root of My Storage before flashing this rom.
- Tiến hành up rom và thực hiện theo hướng dẫn của SB ROM Settings.
Performing to flash rom and carry out as guides of SB ROM Settings.
- Khi thiết bị khởi động lại một lần nữa, bạn có thể xóa SBExternal.sbr để tiết kiệm dung lượng My Storage.
When your device restart again, you can delete SBExternal.sbr file for saving My Storage capacity.
- Các ứng dụng nhỏ mà tôi cho vào ROM sẽ nằm ở My Storage trong Program Files.
Small applications I added to ROM will be in My Storage from Program Files folder.
Tải ROM - Download links:
Link download đã có sẵn - The link is available now
I8000 ROM XXJG5 21914 SB30 UPDATE
Password giải nén - Password for uncompressing: sonblack
Chúc vui!
Enjoy it!
Sonblack
hehe lâu lắm mới có rom mới của anh SB. Nhìn ảnh đã thấy hâp dẫn oy. THanks anh nhìu nha :D
Cuối cùng thì cũng đã ra lò bản ROM mới của Dr SonBlack!!! Nhưng cô nàng I8 của e lại mất ổ cứng rồi a Son ơi! Làm sao mà "Copy file SBExternal.sbr to root of My Storage" bây giờ??? Buồn quá...E bị mất My Storage cả thảy lần này là thứ 4 rồi. Chán như con gián ko cả muốn đi BH nữa. Có lẽ phải chia tay với I8 thôi!
Không copy thì khi thấy màn hình SB ROM Settings chỉ bấm exit cũng được nhưng chỉ có lite rom mà thôi :D
SB30
@Dr. Sonblack,
congrats for new release !
I think now you should take a break for a while...
Cheers
contable
E cũng mất ổ cứng nữa, dùng thẻ 16g thay thế rùi nhưng k đc up rom của bác Sơn thì dùng i8 cũng mất mấy chục % độ sướng rùi! Mong bác bỏ chút thời gian cho ae lỡ sa chân vào i8. Tha thiết!:((
Cứ down về và hy vọng!
Thanks anh Sơn nhiều. Chưa test xong JH1, đã có JH2. Chưa down JH2 lại co SB30, HEHE 1 lúc ra nhiều quá ko test kịp, up up test test thui pakon.
helo anh Sơn. em có ý kiến 1 chút về cái SMS, anh có file cab để dùng dạng thread-chat không ạ, kiểu hiển thị hiện tại xí quá :p. thank bác :D
hihi em mới up rom sáng nay. Giao diện này em thấy đẹp và tiện dùng hơn cũ nhìu. Nhưng anh có thể chỉ cho em cách update thời tiết của hà nội được không ? EM chọn nó toàn ra của paris với mấy cái khác không có của hn. Thanks anh nhìu nha :D
bác Sơn ơi, bác chỉ cho em cách đổi hình nền bên ngoài với, em muốn nó giống với hình nền trong start menu và hình nền khóa máy lun. thank bác nhiều :)
Đúng rồi anh Sơn ơi.Em thấy sms theo dạng củ dể nhìn và tiện dụng hơn nhiều
Đây là SMS gốc của Windows Mobile, các bạn vẫn có thể dùng kiểu thread bằng cách sau đây:
Dùng Advanced Config có sẵn trong ROM (nó nằm trong folder Tools) để chỉnh Registry như sau:
Trong giao diện của Advanced Config, tap dấu + trước mục Messaging, chọn mục Threaded SMS, chọn tiếp Enabled (default), tap vào Done, máy sẽ khởi động lại. Sau đó bạn có thể dùng như ý.
SMS-MMS của Samsung đã loại ra khỏi ROM để mọi thứ hoạt động trơn tru hơn, được cái này thì mất cái kia thôi mà! Trên đời này có gì hoàn hảo cả đâu! :D
Tôi cài đặt ICON nhỏ trong START MENU, xin anh Sơn hướng dẫn cách trở về ICON lớn. Tôi thử theo cách hướng dẫn ở SB28 nhưng không được, ở ROM này chắc anh cài đặt khác. Xin cảm ơn.
Chỉ có cách hardreset và đừng cài icon nhỏ thôi bạn ạ! :)
ha ha :)) :)) em làm được rồi thx anh Son không die ổ cứng em làm lần đầu vừa up vừa run cũng may hướng dẫn cụ thể bản nì đẹp quá mà tiếc mỗi cái em ở hp mà điện thoại lại hiện thời tiết bordeaux :-? anh cho em cách sửa được không
Thank so much
Cái này là hem biết cách dùng đó thôi, chứ ROM có lỗi đâu! :))
Ở màn hình đầu tiên, bấm Menu, chọn Settings, chọn Modify city, chọn MSN Weather, tìm trong List có sẵn Hải Phòng đó, nhấn OK
Rồi lại chọn Menu, chọn Weather là có đúng thời tiết ngay ấy mà =))
