[14 JUNE][MAGLDR] LeoRCMix S v.1.8 (RCMix S v.2.0) [Sense 3D][RAF 1.9OC]
ntt2006
LeoRCMix S v.1.6
Ace S 2.36.405.8 WWE, Android 2.3.3
by Klendelrus (XDA)
Screenshots:
What's working:
  • Phone
  • Wi-Fi
  • Bluetooth
  • FM radio
  • SD card/USB mount
  • Camera
  • Weather
  • Lockscreen with transparent icons (thanks snq-)
What's not working/bugs:
  • Graphic glitches
  • Power menu works only one time (use included app Quick Boot)
  • Tethering?
  • Camcorder (working with Videocam Illusion app, but very slowly
  • you tell me
Features:
  • Ace S 2.36.405.8 WWE, Android 2.3.3 base with Sense 2.1
  • Multilanguage
  • Stable
  • Sense 3.0 Lockscreen with transparent icons (thanks snq-)
  • Sense 3.0 Camera application with panorama mode (thanks snq-)
  • Sense 3.0 SMS/MMS application
  • Sense 3.0 USB Menu
  • Sense 3.0 Streak and Weather Live Wallpaper (preview not working, apply directly)
  • Sense 3.0 Task manager (even in quick settings)
  • Settings.apk with system, data and ext partition info (thanks m0narx)
  • All widgets/themes from HTC Hub
  • CM-style screen on/off animations
  • Option to enable stock android lockscreen
  • HTC Touch Input with arrows
  • Modified framework - battery with percents and green glow effect
  • Some useful apps preinstalled
  • and more
Changelog:
V.1.6 - reverted kernel back to Rafdroid R1.9OC, added Sense 3.0 camera app (thanks snq-), added GPS libs by tytung
MAGLDR 1.13: EU and TMOUS: 200M system + 1GB EXT partition
DOWNLOAD
Cập nhật các bản rom LeoRCMixS by Klendelrus đã edit thêm Tiếng Việt, loại bớt các ứng dụng ít dùng và ngôn ngữ (để lại Tiếng Việt, Tiếng Anh và Tiếng Nga), thêm bộ gõ Tiếng Việt,..:
- Bản cLK_LeoRCMixS_v1.6_VN_no_glitches_no_camera (Thanks langthang262):
- Bản cLk_LeoRCMixS_v1.6_VN (fix lỗi không hiện thời gian, tên mạng và nhiệt độ ngoài màn hình Lockscreen):
DOWNLOAD HERE
Cập nhật bản LeoRCMixS_v.1.8_by_Klendelrus (14/06/2011)
Bản MAGLDR_LeoRCMixS_v1.8_by_Klendelrus
http://www.multiupload.com/3FZYL57P11
Update bản 1.8
v.1.8 - based on RCMix S v.2.1 test 3, added Sense 3.0 Rosie with 3D widgets (latest pack from seo), new GFX drivers (thanks coolexe!)
Nguồn: http://forum.xda-developers.com/showthread.php?t=1100707
mình vừa cài bản 1.5 hôm qua xong. Giờ lại ra 1.6 . Không biết có gì hay hơn không nhỉ?
Bản này lại quay về Kernel Rafpigna 1.9 OC rồi...\-/
Bác có thể giải thích hộ em sự khác nhau giữa 2 kernel Raf 1.9 OC và tytung r10 được ko ah? Thây các dev cứ quay đi quay lại giữa 2 kernel này ko biết có ưu nhược điểm ntn bác nhỉ? Thanx in advance
Anh em cho hỏi chia bộ nhớ 1Gb là để làm gì vậy? Có cài pm vô phân vùng đó đc ko? Sao em thấy bản Android nào cũng còn ít bộ nhớ quá ko cài pm gì hết đc.
Thanks.
chính xác ban chia thẻ nhớ 1Gb thì khi cai phần mềm thì nó sẽ tự cài vào 1Gb trong thẻ nhớ. Cách mình chia thẻ nhớ như sau:
1. Fomat thẻ nhớ bằng SDfomater: trong option chọn Earn (OFF) và OFF
2. Cho thẻ vào HD2, reset lai đt
3. Cài recovery
4. Vào muc 8. AD recovery: wipe data/factory reset, wipe cahe và vào advance chọn Dalvik cache
* Chia the:
5. Vào mục 8 AD recovery --> Advance--> partition SD card --> 1024MB --> 0 MB
6. reboot system now, tắt đt, gỡ thẻ nhớ, copy rom vào thẻ, gắn thẻ vào HD2 rồi up rom
chúc vui vẻ
Thú thực là mình không rõ lắm đâu nhưng Kernel Rafpigna 1.9 OC dùng ổn định hơn Kernel Tytung r10. Nói chung là mỗi Kernel có đặc điểm riêng của nó mà chỉ có các DEV mới hiểu rõ được thôi...
Thanks.
Để cho các app của rom sang đó bạn ạ...
Kernel Tytung R10 chuyên dùng cho các bản Non sense còn Rafpigna 1.9 chuyên dùng cho Sense.
Gần đây các đ/c thử dùng Tytung R10 cho Sense vì nó hỗ trợ cLK tốt hơn nhưng có vẻ không được tốt lắm lên lại quay về Rafpigna 1.9.
có 2 loại kernel 1.9 OC với 1.9 OC_GB vậy rom này xài loại nào vây
đang dùng bản 1.5, thấy bị sọc màn hình bực quá, với cả cái mình hay nghe FM buổi tối mà FM cũng hư, hix tác giả đáng lẽ ghi là FM not working
Cập nhật phiên bản cLK_LeoRCMixS_v1.6_VN_no_glitches_no_camera trên post 1.
FM dùng bình thường mà bạn...;;)
