[16-04-2010] PDAVIET - I8000 WM6.5 ROM (21647.5.3.0) - SB19
Sonblack
Super V.I.P
PDAVIET WM6.5 ROM - I8000
CE OS 5.2.21647 BUILD 21647.5.3.0 PV
Lời cám ơn - Special thanks to:
Admin Kawaguchi (for his tools), Manager PhamQuang (so much), Super Mod Batkid (so much), Adv Mod NhatToai, Adv Mod TranMinhMan, S Vip Tom_codon (all of them are from PDAVIET)
Member huyentrangallery (from Samsung Vietnam, supported I8000 device for cooking)
Wes58 (Modaco) for his tool (the best support for me)
JHML (Xda-Developers) for his application, JMLToday
contable (Modaco) for his skin/mod of JMLToday, his opinions and more supports about this, his donations and so on...
Lancez (Modaco) for his opinions which I need to know and his big donation.
tacchan23 (Modaco) for Taskbar Icons, theme and S2U2, Showcase Skin
Henrie, koperko, wkmmx500, Ah Huat Low, fattmatt
, Macarov Gelu from Modaco for their donations
Thông tin ROM - ROM Informations:
Basic ROM: XXJD1
ROM Date: 15 Apr., 2010
Language: only WWE
Pagepool: 16MB
Sử dụng chuẩn nén LZX để tăng Free Storage
LZX compress standard is used
Version: i8K21647JD1SB19
Hỗ trợ hiển thị font tiếng Hoa
Support to display Chinese fonts
Hình minh hoạ - Illustrative images:
Chức năng chính - Main functions:
- Core 5.2.21647 Build 21647.5.3.0
- Tất cả các button ở màn hình chính JMLToday hoạt động tốt
All buttons at Today of JMLToday operate well.
- JMLToday sẽ tự động cài đặt ở lần khởi động đầu tiên, các bạn chỉ việc chọn nơi bạn đang ở (Một số nơi là không có sẵn trong danh sách hiển thị).
JMLToday will be installed automatically in first boot, you only choose your location (some locations are not available).
- .NET Compact Framework Version 3.5.9198.00
- Office Mobile (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile)
- PowerOptions v1.22 (Removed)
- e-Natives Technology Showcase v1.1.0 (Dusk Skin by tacchan23)
- Orientation Detection v1.0.3584.9343 for Omnia II
- MSN Money
- MSN Weather
- Marketplace
- SRS WOW HD for OMNIA II (Removed as requirement, not fault)
- FlashLight
- TCalendar
- JMLToday OMNIA II mod RC120 (thanks contable)
- Tacchan23_WhiteBlack_6.5.x_VGA_v7 theme (thank again tacchan23)
- VnKeyb v2.2.0 by ntd (Skin from hanoiwap, included Set Keyboard in English - Thanks Super Mod Tmap)
- Check New ROM (thanks Admin Kawaguchi)
- Java_JblendPackage_2_1_2_1_20090429_2_1_R6 from Topaz II
- AdobePDF_2_5_1_0_404840_03
- CHome Editor v1.6beta (thanks Showaco)
- S2U2 v2.34 (Added, thanks A_C)
- Soft Reset (Added, written by Sonblack)
- Opera Mobile 10 (Added)
- Các ứng dụng cần có của PPC với các version mới nhất bao gồm:
Basic applications for PPC with its latest version as follow
CleanRAM (v2.1), ClearTemp (v1.3), Total Commander (v2.52 beta 2),PIM Backup (v2.8), Synchro Time (v0.95), Advanced Configuration Tools (v3.3)
- Loại bỏ nhiều ứng dụng không cần thiết mà tôi không thích
Removed more unnecessary utilities which I don't like! (see the list)
Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Face Book, Podcast, QIK, RSS Reader, Cube, MainMenu, OnlineWidget, Samsung Today, Video Editor, Digital Frame, Smart Search, Unit Converter, Video Editor, Application Store, Communities (Share Pix), Connected Home, Midomi, Task Switcher, SPlugin Favorites, Google Maps, Smart Memo, Smart Reader, Smart Sync, Youtube, My Files, Adobe Reader, Java, Opera...
Ai không thích icon nhỏ của Start Menu có thể làm như sau để xoá toàn bộ Registry dưới đây và Reset
Anybody don't like small icons of Start Menu can do as follows in order to delete all following Registry and Reset
[HKEY_LOCAL_MACHINE\Security\Shell\StartMenu]
"CustomGridForm"="StartMenu_Sonblack"
Nên up rom với Octans Downloader version mới nhất. Mới nhất hiện nay là Octans Downloader v2.14
Please flash the ROM by latest Octans Downloader version. Its latest version is 2.14
Tải ROM - Download link:
Link download đã có sẵn - The link is available now
I8000 ROM XXJD1 21647
Password for uncompressing: Sonblack
Chúc vui
Enjoy it!
Sonblack
Hi Sonblack!!
Thank you the new ROM!But why JML contable today????:-?
The "old wm7" was much better!!And more memory was available...
Thank you again the hard work!!
Dạo này chỉ có PV Award SONBLACK ra ROM đều đều! Chỉ I8000. Quên hết mấy con kia rùi hỉ!!
mơi up bản 18 mà opera mobile bị lỗi wa .giờ rang up bản này xem sao thanks anh sonblack
ah cho em hỏi sau khi up xong trên ct octans nó hiên lên tap reset thì mình có cần click vô đó ko?
Click hay không thì nó cũng Reset mà thôi! :D
Đang định lên down bản SB18 thì đã có SB19 rồi, bác Sơn đúng là làm việc năng suất thật. Thanks bác
Bảng này ok chạy ngon.Máy cái lỗi cũ đã được fix.Chỉ có cái giao diện màng hình chờ nó không chuyện đổi nữa mà là mạc định 1 hình.(mình khoái chuyển đổi hơn,nhìn nó đẹp và không nhầm chán)
Sory anh Sơn .Em mới thấy nó chuyển hình rồi .Thế là quá ngon
Chưa kịp test SB18 đã có SB19, rất rất cảm ơm anh Sơn. \-/
Chúc anh luôn có sức khỏe để luôn ra ROM đều đều. \-/
Giúp mình
Mình up bảng sb19 này bị cái lỗi xoay ngang màng hinh khi xem phim không được.Khi quay ngang hay để thẳng đứng thì không thể mở full màng hình lên xem được.Khi ấnn full thì màng hình nó đen thui
Ai giúp mình với
Bác Sonblack cho em hỏi, Cái S2U2 của em đã chọn "Slide to Answer (S2A) = Alway" nhưng khi có cuộc gọi đến thì vẫn phải bấm để nghe. Cả bản SB18 em cũng bị như vậy.
cho em hỏi làm sao để chuyển giao diện icon trên taskbar và menu về mặc định của WM vậy?
Cứu em với ........
Em vừa up lúc trưa, sử dụng bình thường, nhưng vừa rồi em cài mấy phần mềm xong reset thì máy không khởi động được. Chỉ hiện chữ Samsung omnia II.
bản này 19 này vào opera cảm ứng ko đươc mượt cho lắm ko biết tại sao vậy ?
Mình thì luôn bị treo khi gữi sms bằng hình thức chat của SS.
Một vấn đề nữa là muốn coi phim thi tốt nhất nên soft reset mới coi được.Không thì khi full màng hình sẽ bị 1 mầu đen
Anh Sơn ơi cái lỗi SMS nó bị nặng lắm.Thường xuyên bị treo cho dù mình vô bằng cách nào đi nữa nó vẫn bị.
Rom chạy ngon lắm nhưng bị cái lỗi SMS thôi.
Em mới phải up lại bảng SB17b xài nè
Anh xem lại giúp
