(2011-01-09) Elelinux-6.2.0-RC0-Hero
dimabilan89
1 bản rom mới mình đã test thử mọi thứ đều ổn định
NOTE ALWAYS MAKE BACKUP BEFORE FLASHING A NEW ROM
Installation
1: Wipe off all including ext partion if used
2: Flash rom
3: Reboot after first start reboot.
4: Reboot to recovery and flash the new ADWLauncher (if you want)
Here > http://grabbarna.se/~elelinux/Elelin...0-RC0-Hero.zip
Bugs
The built-in feature to bring frequencies do not work, shall troubleshoot, install setcpu so long until I found the problem.
Options
OpenGL ES 1.1-CM Only for this rom
Here > http://grabbarna.se/~elelinux/libGLE...0-RC0-Hero.zip
HTC IME
Here > http://elelinux.se/6.2.0/htcime.zip
ADWLauncher 1.3.6
Here > http://www.elelinux.se/extra/adwlauncher-1.3.6.zip
There are a lot of different options in my other thread here, among other things if you want to change the launcher, etc.
But flash not any themes for it will not work
Thread > http://forum.xda-developers.com/showthread.php?t=767886
Enjoy
Nguồn:forum.xda-developers.com
