[21/12/2012] Sabsa Bliss v3.0 | 4.0.4 | Sense 3.6 | Fully Working | Ultra Fast&Smooth
hacbaoklhh
image.php
Android Version: 4.0.4 (IceCream Sandwich)
Based on: Incredible S 4.10.405.1
Sense Version: 3.6 With Full Bliss UI
Supported Devices: Desire HD / Inspire 4G
First ICS Rom With Bliss UI
[video=youtube_share;QRIJ2PdgN4Y]http://youtu.be/QRIJ2PdgN4Y[/video]
image.php
Code:​
v3.0
- Rebased to Latest Incredible S RUU & Bliss RUU
- Updated Kernel to 3.0.56
- Fixed Headset Button
- Updated Driver
- Updated Aderno Driver
- Updated Some Apps
- Added more init.d Tweaks
- Added Internet Speed Tweaks
- Added Sabsa Prime Wallpaper
- Added Google Plus
- Added Compass
- Fixed Increasing Cpu Usage After Turn Off Bluetooth
- Updated Bravia Engine To v2.0
- Added Project Butter To Aroma Installer
- Added Keyboard With Arrow to Aroma Installer
- Fixed Small Bugs
- ZipAlign With Latest Android SDK
- SomeThing More That I Can't Remembered
v2.0
- Kernel Updated To PachaRX 3.0.43 Thanks To XxXPachaXxX
- Fixed Beats Audio
- Added Sound Enhancer To Music
- Added Sound Enhancer To Video
- Added SRS
- Added Dolby
- Fixed Inspire 4G Patch
- Added Super Smooth Rosie To Aroma Installer Option
- Added Ultra Smooth Rosie To Aroma Installer Option
- Fixed Long Sms Thanks To XxXPachaXxX
- Added init.d Tweaks
- Fixed Increasing Cpu Usage After Power Off Bluetooth
- Fixed Ril
- Added More Location
- Added Bliss Dock Mode
- Updated Busybox
- SuperCharged As Default
- VR io scheduled
- memcpy and memmove fix
- Improved Performance
- Improved Battery Life
- Improved Smoothness
image.php
Download v2.0
MD5 Sum:8954bc04a7efdc8a560bda39540e3419
Download v3.0
MD5 Sum:e8b235364cb7b981d4d5b4bf26d50a7b
image.php
- HTC Desire HD
- S-Off or Unlock Bootloader
- CWM Recovery or 4EXT Recovery
image.php
Download The Rom
-Put Rom in Your SD Card
-Do Full Wipe
- Flash The Rom
-Reboot
image.php
HTC
Virtous Team
Blackout Team
XxXPachaXxX
Football
Đã test và thấy khá nặng, làm máy chạy chậm khi truy cập vào các ứng dụng hoặc lật trang.
cái dưới đây có nghĩa là gì các bác nhỉ
MD5 Sum:fcb6cd610674bf29abdd3265c5f4760f
Bạn khởi động lại máy 1 phát là mượt ngay. Mình cũng đang test ROM này, mọi cái đều đc nhưng apps Locations bị lỗi: Không thể kết nối đến server. Mod biết khắc phục ko giúp với :D
Bản này so với IceColdSandwich hoặc CyanogenMod10 thì cái nào good hơn mượt hơn ta ? Ai test bản này rồi cho biết ý kiến so với 2 cái kia giúp với
Bác này chụi khó up Rom nhỉ.
Nghịch Test nhiều ROM tự dưng mất bản quyền điều hướng ở VN-Locations gần 30$ rồi :((
Chả hiểu sao lần này up ROM lại mất mọi khi up xong vẫn có. Giờ mất hẳn luôn up lại vẫn mất. Đi toong 30$.
Bạn biết những bản Rom nào hay share link cho mình với.
Theo mình thời điểm hieenjt ại thì với sense 4 là ROM Sabsa Prime v6.0
ROM này mình thấy ko còn lỗi gì cả. Có 2 lỗi thì có bản mod để fix rồi :D
Kể cả wifi hot spot cũng ok.
Còn bạn muốn trở về giao diện cũ Sense 3.0-3.5 thì dùng Revolution v6.3.3 hoặc v7
Update Tweaks cho ROM.
Rất nhiều tùy chỉnh như : wake up volume, change backgroup, clock.....
DOWNLOAD
Copy vào SD Cart
Up qua Recovery
Reboot
xai ok k bac!! co hay bi mat song k? mih ghet nhat cai mat song ah!! co chien gap chac chet
Rom này ổn định nhất từ trước đến nay mới thấy đó, free ram nhiều, ít hao pin...nói chung ok. Các bạn cứ thử...;;);;);;)
Chẳng những lỗi không tải được data location mà còn thêm lỗi không tải được app ở google play bằng cách chia sẻ kết nối với máy tính mà chỉ tải được bằng 3G
Rõ chán!!!
