[21/12/2012][Sense 4.1] Team Venom presents: ViperS v1.5.2 - Welcome to Future
thaingocduan
Team Venom presents
Nguồn : XDA
...presents you ViperSs rom!
  • First fully workable Sense 4.1 Rom
  • Android 4.0.3 ICS + Sense 4.1
  • Sense 4.5 parts: Gallery, Keyboard, Dropbox player, Music lockscreen, Battery stats, Powersaver, App manager, FM Radio
  • Based on HTC Ville C2 RUU (1.11.401.110 + 2.15.401.100)
  • Aroma v2.0 with my Sense 4 theme
  • Bricked kernel v1.36 by default - but you can download other in hub
  • Deodexed & Zipaligned
  • SuperSU v0.89 - credits Chainfire
  • Persistent ADB enabled
  • init.d support
  • Busybox and bash
  • Memory optimizations
  • sqlLite 3 enhancements
  • Extended Quicksettings with tabs - Yeah, we know you missed them!
  • APM
  • Venom Tweaks - some new goodies! Features listed listed below
  • Venom Hub - direct download rom content and read news
  • Venom OTA - update your rom without PC
  • Venom File Manager
  • Venom Superuser application
  • App installer
  • CM statusbar brightness mod
  • CPU/VDD tables control in tweaks app
  • 20 working eqs + beats + srs + dolby + custom eq
  • All Market apps Updated to latest
  • Ulimited theming support: APK themes for statusbar, APK icons packs(or ADW Launcher icon packs) for HTC Sense, changeable backgrounds and many etc
  • VenomHUB!
Statusbar:
  • Rearrange and hide Quicksettings
  • Quick quicksetting
  • Disable vertical quick settings
  • Horizontal quick settings
  • Disable on lockscreen
  • Hide icons
  • Clock settings
    • Center/hide clock
    • Hide am/pm
    • Choose clock color
  • Battery Tweaks with MIUI Battery bar!
  • Themeable battery icon
  • Custom statusbar caption and second line for more info
    • Add op logo
    • Tap action on carrier label
    • Customizating of settings button
  • Status bar icons theming
  • Custom statusbar background
  • Change internet icon
  • Transparency on home and in other apps
  • CM Brightness
  • Hide date from notification area
  • Recent apps dialog style
Rosie Launcher:
  • Normal/Smooth/Ultra smooth
  • Enable landscape rosie
  • Wallpapper scroll
  • Enable unlock animation
  • Transparent navbar
  • Install icon packs
  • Infinite scrolling
  • Increase app drawer size
Lockscreen:
  • ICS AOSP Lockscreen
  • Rotateable lockscreen
  • Swipe2wake control
  • Customazeable shortcuts
  • Custom carrier lockscreen text
  • Hide time/am/pm/date/operator on lockscreen
  • Menu/Home/Back/Search key to unlock and Slide2Unlock
  • Volume wake toggle
  • Media control: choose pause/play or skip track backwards
  • Long press home to toggle flashlight or start custom app
Buttons:
  • Turn ON/OFF by volume keys
  • Customize 3-finger gersture
  • Backlight mode
  • Long press home, search and menu mapping: recent apps, screenshoot, custom app
  • Long press back mapping: force kill app, recent apps, screenshoot, custom app
  • Hide arrows from keyboard
  • Search button mapping
  • Longpress buttons timeout
Misc:
  • HtcSmart Sync disable
  • 10 Different overscroll colors
  • Different volume and autobrightnes ssteps
  • Toggle cubic animation
  • Custom nav app for HTC Car
  • Camera volume/search shooter
  • Hide camera on screen buttons
  • Screen on on MMS
  • Fast dormacy toggle
  • Toggle Sony bravia and xLOUD
  • Minfree configuration
Advanced Tweaks:
  • Mount system rw/ro
  • Wipe cache/dalvik
  • Fix permissions and zipalaign apks
  • install custom boot/down animation and custom boot sound
  • enable/disable boot sound
  • install custom fonts pack
  • Beta tester team that found a bunch of small glitches!
  • Our whole team, all awesome guys
  • amarullz for his Aroma Installer
  • Baadnewz for great rom base and help
  • Max - my friend - for boot animation
  • Romanbb for the original tweaks mod for the Sensation
  • lyapota for his media control mod on Desire HD
  • cyanogen for the brightness mod idea
Viper 1.5.2
  • Fixed all 5 Chinese keyboards
  • Updated time zone info
  • Fixed messages dont save preview lines setting
  • Added option to remove not needed keyboards in aroma
Old versions
Viper 1.5.1
  • Added vibration level choose for keyboard(in keyboard settings)
  • Fixed chinese keyboard
  • Fixed QWERTZ keyboard was showing Z insteadof Y in landscape
  • Fixed font size not saving in messages app
  • Improved keyboard speed
  • Fixed font size changing in HTC apps
  • Fixed default vibration level for keyboard
  • Fixed removeing of PDF Viewer in full version
ViperS 1.5.2 - for 1.5.x users update avaliabale on OTA
We recommend make full wipe before installing this version, if you come not from 1.5.0.
Please don't report about bug if you dont make it
Old versions
ViperS 1.5.1 - for 1.5.0 users update avaliabale on OTA
cảm nhận cá nhân mình thấy bản rom chạy khá mượt ít nóng máy khi chơi game 1 bản tương đối tuyệt ae nên thử .đặc biệt bản này còn cho phép các bạn cập nhật trực tiếp rom qua kết nối của điện thoại nữa. bản này có tính tùy chỉnh cực kỳ hay thay đổi giao diện nhanh tiện lợi đẹp mắt nữa mình đang dùng rất hài lòng
À máy em đang firmware 1.32 có up đc luôn ko ạ?:-? radio có up đc ko nếu máy em chưa S-OFF?:-?
Bản này pin được lắm( có lẽ tại kernel 1.35). Bộ khung bản này phát triển từ bản PkMn 5.1.0 nên cũng ít có thay đổi.Có thêm VENOM HUB( giống HTC HUB).Mình dùng bản PkMn 5.1 từ lâu rùi nên qua bản này thấy chỉ có chút ít thay đổi( update qua OTA). Trong dòng Sense 4.0 theo ý kiến riêng mình thì nó là bản ổn định nhất rùi đã fix hết các lỗi ngoại trừ lỗi HDMI OUT.
bản này họ làm việc theo team nên sẽ có nhiều cái khác biệt mà
sau 1 đêm sử dụng thật bất ngờ với pin cua bản rom .hôm qua 11h mình đi ngủ pin còn 98% sáng nay 8h mới ngủ dậy mà pin còn tận 92% . mình chưa dùng bản rom nào mà lại có chất lượng tiêu thụ pin tiết kiệm như vậy. chưa kể bản rom này còn mượt hơn cả các bản sen 3.6 mình đã từng dùng nữa.
thật lạ là bản rom này và cả bản rom PkMn cũ ấy ko dùng đc phần mềm tra từ điển MTD. mình thử up insertcoin evolution thì vẫn dùng ngon lành.
Review đây ạ:D ROM mượt, đẹp, tiết kiệm pin. Hinhg như S-ON thì ko up đc Radio đâu ạ:-s
Bản này đúng là mượt thật. Mượt hơn InsertCoin nhiều.
Neu may ban song ko bi yeu thif ko nen up Radio lam gi. Minh up tu hom qua thay song tot nen cung ko up Radio. Sorry vi minh online tren DT nen ko viet tieng Viet duoc,mong MOD thong cam co gi sua gium minh.
ko bít tại sao con sen XE up rom xong chỉ lên màn hình đen có chữ sensation trắng là thôi.ko chạy tiếp dc.bác nào biết cách chỉ giúp em với
Bác nào úp rom này rồi thì làm một bài cảm nhận chi tiết một chút nào, không biết đã úp lên camera HQ-CameraV1.5 chưa nhỉ, mà hình như bản này không có sẵn phần gallery và messages thì phải
bản này tích hợp đầy đủ hết rồi có tất cả cá chức năng thậm chí là nhiều hơn các bản rom khác lúc up rom nó sẽ có mục cho những bạn không thích pm nào thì gỡ bỏ . mình dùng sen xe đây up rom bình thường mày máy mình fw 3.32 up xong nó hiện chữ sen màu trắng tầm 5 phút mới vào được bạn ạ.
Mỗi tội cả bàn này và InsertCoin 2.1 đều sạc rất lâu. Chắc là do Kernel 1.35 :(
Mình cũng ngán cái zụ sạc pin lâu này quá, cứ toàn fai 6-8h mới đầy =.=' (Đang xài bản Rom Elegancia v1.1.0)
