[29-01-2010] PDAVIET - I8000 WM6.5 ROM (23518.5.5.0) - SB05
Những vấn đề trên là nhược điểm của WM 6.5.5. Chờ Microsoft!
MobiTV xem phà phà!
Một số vấn đề khi up bản ROM SB05 update này : (theo nhận xét riêng của mình)
Giao diện rất OK, có xem thời tiết Titanium, vuốt nhẹ chạm nhanh. RAM + ROM trống nhiếu hơn SB 04 và SB05
Vẫn không xem được Mobi TV . Phần mềm Vietmap chạy trên bản ROM này rất chậm. Pin có vẻ tụt nhanh hơn.
battery issue is related to the version of phone part, not the ROM. try DXIJ1 instead and u'll notice the big difference! flashed my phone with 62% battery last night, with one hard reset after, about 1 hour for setup and installation, 1 hour for playing around and many softresets. now, after 10 hours i still have 49% left.
@SB
i'm sorry to say that ur 28008 is not the best 6.5.x anymore, coz i just discovered that ur SB05 23518 is the best out there. =)) thank u so much.
Thank you so much for your opinions about ROM 23518, Lancez!
I think that you're so happy on the road to Ohio??? :D
Now, I had XHook and XTask with new version from XDA for changing next time. It's version 2.18RC1 release on Jan 28, 2010. It's best solution for WM 6.5.x up to now! :D
the XHook is develeped by a chinese guy, not member of XDA. and the one that i gave u is the latest version. personally, i think Xhook alone is the better choice, but it is ur call, coz u r the master.=D> yes, the trip to Ohio is kinda fun, if its not so damn cold, lol. one other thing i like ur ROM so much is because u listen to our complains/opinions and make improvements on everyone of ur ROM. not like some ROM cookers over Modaco, very stubborn. :)) i am grateful to have someone like u to cook wonderful ROMs for us. thank u, a thousand times thank u. =D>
YES, you're right! It's developed by chinagb from xbeta.cn (see here: http://bbs.xbeta.cn/thread-30497-1-1.html). I'm also member of this forum. :D
I make the roms for me first and share them for everybody here. I have to listen to every one here for improving them better day by day. :D PDAVIET cookers and I like so for our members.
This is work I like after working hours in my company.
Once again, many thanks for your complains/opinions about my roms and my work, I'm so happy about this. :))
One more question, Lancez! How do think about original diapad of Samsung I fixed for suitable this ROM and more?
Hi Bro SB
Bro cho mình hỏi sao bản SB05 cũng như mấy bản trước, lúc mình soft reset màn hình khởi động đều báo lỗi " MortScript V4.3b5" ?
Thanks
Hi Bro SB
Thanks
Đã nói nhiều lần về điều này. Đây không phải là lỗi mà là thông báo của MortScript mà thôi. Nó phải chạy để hỗ trợ tốt cho CHome Weather trong việc hiển thị icon và cập nhật thời tiết cho CHome ở màn hình Today.
Bạn cần phân biệt đâu là thông báo lỗi và đâu là là thông báo của một chương trình đang chạy nhé! Đọc kỹ cái thông báo đó đi sẽ thấy chẳng có gì!
a Sơn làm phát cho Swype vào đi bên modaco cấm nhưng vn thì đâu cấm đâu, hehehee
Nếu liên quan đến bản quyền thì không cho vào trong ROM được vì sẽ ảnh hưởng đến sự tồn tại của forum!
well, i couldnt find any bug of ur fixed samsung dialpad, or maybe i am blind? :-? lol. guys over modaco r itching to get this. but no one, i mean no one could figure out how to fix that so far, u rule lol. u can read chinese?
I can't read Chinese but I use Google in order to find out what I'm interested in! :D Today, I focus in to make new rom for Sony Ericsson X1 because I posted the new rom at that box 2 weeks ago.
A Sơn ơi có cách nào cho start về trên cùng bên trái ko ? E dùng SPB Mobile Shell mất mất chỗ start ở dưới...
Chỉ có các build 21xxx thuộc WM 6.5.0 mới có menu Start như ý bạn muốn thôi! Các build khác đều theo giao diện mới với nút Start nằm ở góc dưới bên phải! Người build rom không thay đổi được. :))
sao bản này mình dùng bàn phím tiếng việt Vnkeyb ko dc vậy bạn
Ấn giữ nút bàn phiếm cho nó hiện lên danh sách bàn phiếm rồi chọn bàn phiếm sử dụng, buidl này không có nút mũi tên chỉ lên trên giống các phiên bản trước
Bác vào samsung setting\System\Input Method chọn bàn phím VNkeyb
Tôt nhất là bác cài luôn cái Set Keyboard của tác giả để chọn bàn phím mặc định sẽ tiện hơn
