A66 MIUI ROM NGÔN NGỮ VIỆT FULL_GINGER BREAD 2.3.4 Update 19/06/2011 v.16
Cái tab khuyến nghị (Bao gồm những lời chúc các thể loại...) trong SMS đó là của Trung quốc và được update trực tuyến . Nên không loại bỏ nó được.
Mình đã lấy rom multilang trên xda cài thêm theme 2.0 của bạn chọn ngôn ngữ US loại bỏ hoàn toàn tiếng tàu nhìn rất đẹp chắc phải xài rom này lun quá (nhất là phải có theme 2.0)
a66_MIUI _1.4.22_ 2.3.3 Gingerbread_Vi_9.0
Base Office Rom 1.4.22
Mã:
[B]Phone:[/B]
 - Optimisation of handling Third Party call handling of records
 - Fixed notification of missed calls and messages, LED color and frequency would not set
 - Fixed force close (FC) when setting call forwarding
 - Fixed the input field box narrow height problem with call forwarding settings
 - Fixed answer button issue where it did not disappear after ending a call
 - Caller ID issues fixed some FC errors
 [B]SMS / Messaging:[/B]
 - Added setting option to enable screen wake when new messages are received
 - Fixed issue sending group messages, could not resend messages again
 - Fixed issue with cursor position when writing messages and using signatures.
 - Optimised Mms preview of images
 - Preview Mms optimisation of use with Gallery functions for viewing photos or video
 [B]Lockscreen:[/B]
 - Optimisation of image resources e.g counters and icons
 - Removed Lockscreen widget from ROM, can be downloaded separately
 - Fixed a problem with music player buttons not pressing correctly first time
 - Fixed problem for some devices seeming to charge slowly due to  inefficient charging animation (Not a real issue but looked like the  phone wasn’t charging quick enough)
 - Fixed messages preview and call info views for previews
 [B]Contacts:[/B]
 - Contacts could not be added to groups (fixed)
- Caller ID FC fixed when selecting a picture from the Gallery application
 [B]Gallery:[/B]
 - Optimisation of user interaction when browsing photos or video items
- Fixed issue where some photos caused application to FC
 [B]Camera:[/B]
 - New full screen UI
- New Anti-shake function
- Fixed issue where pop up menus caused FC
- Auto-focus issues fixed for Milestone
 [B]Music:[/B]
 - New now playing panel added, enter playlists
- Optimised the recently added song, track list sorted by time
- Optimisation of folder refresh speed
- Music desktop widgets re designed to repair a number of bugs
- Optimisation of music panel
- Fixed some issues with album cover quality
- Fixed issue where sometimes albums do not display correctly
- Fixed auto play issue on Milestone
 [B]Themes:[/B]
 - Added view online wallpapers and ringtones
 - Added options to control default audio options within themes
 - Optimisation of user interface for previewing local themes more effectively
 - Fixed default title of theme does not show in local themes
 - Fixed issue where popup window informing of components within a theme to be showing items in incorrect order
 [B]Notes:[/B]
 - Fixed issue where adding a new note to desktop would appear blank on re entering the notes application
 [B]Backup:[/B]
 - Added support for backup and restore of contacts Caller ID
Không phải tại cái apk SMS đâu:D, nhưng đã tìm được lỗi hiển thị Tiếng Trung trong SMS và Backup roài:D
V9.5 Uploading.....
Đã có hàng, bạn nào tải 9.0 rồi thì lên tải lại 9.5 nhé.
Hehe vậy là không còn bản rom nào đáng để thư hơn bản này.;;)
Hình như bản MIUI này thỉnh thoảng khi muốn reboot bị đứng máy phải không và khi chọn debug trong application manager thì máy tự reboot. Không biết có ai bị vậy không?
Bản mới nhất ko còn lỗi này
Bản 2.3 nào cũng gần như là tốn pin lắm
Tốn pin hay không rất khó phân biệt có người xài nhiều màn hình để sáng thì tốn pin có người xài trong đêm tự màn hình để thấp nên ít tốn chỉ có thể biết khi nó stanby. Bản này tôi để đêm đến sáng mất 2% quá tốt Iphone4 cũng chỉ ở mức này thôi.
Em cũng thích nào xài MIUI lắm, mỗi tội hao pin quá nên xài thích mà lại ko dám xài
Sao mình dùng ít thì gần được 2 ngày ... dùng nhiều thì 1 ngày là hết ... pin tạm tạm ..
a66_MIUI 1.4.22_2.3.3 Gingerbread_Vi_v9.5a_Test (25/4/2011)
* Thay kernel Cattleprod mới nhất (v4.3.1)_Tiết kiệm pin
- Các bạn nên dùng ứng dụng SetCPU để set như sau:
Max : 1497600
Min : 122880
Scalling : Smartass
Set on Boot
* Chỉnh sửa từ ngữ dễ hiểu và hợp lý của các ứng dụng : Gallery, Music, Web Browser, YouTube, Contacts.....
* Boot Animated mới.
Đã có trên bài 1
Bac ancola cho em hỏi là bản này đã có đài FM chưa, em nghiền nghe cái này quá mà hình như vẫn chưa có thì phải
Đã có THEME a66_MiuIphone_2.3.3_v.2.5 Tương thích tốt hơn với MIUI 1.4.22. Các bạn tham khảo và tải tại ĐÂY
_ Xin lỗi thì post thắc mắc ở đây. Nhưng dạo này bận quá không còn time để ngồi mò mẫm nên phải post lên mong mọi người giúp đỡ dùm. Mình mới đổi DHD không lâu, và cũng vừa up thử bản Miui của bác Ân (bản trước ngày 25.4 - không rõ tên) vì mới sử dụng nên còn nhiều lạ lẫm + không có time mày mò nên theo không kịp công nghệ. ..hix. ..:(
_ 1 là làm sao để thêm nhạc chuông mình yêu thích :(
_ 2 hình như market bị lỗi, không down app = 3g được, trong khi down = wifi hoặc down 3g = chợ đen thì vô tư. Nhưng chổ làm việc của mình hiện nay thì wifi là hàng khá "hiếm" :((
_ Hình như rom Miui này bị lỗi quay phim, lúc quay thì bình thường, nhưng vào gallery để xem lại thì toàn bị lỗi, không thể xem full screen được.
_ Mình thích giao diện gallery 3d của cm7 hơn là của Miui, hình như app đó có trên market và tên nó là 3d gallery phải không !? Và nếu muốn cho 3d gallery thay thế luôn gallry mặc định được không 8-|
_ Mình chưa rõ cách thay đổi theme cho Miui, có phải chỉ cần down theme được cung cấp về, bỏ vào thẻ nhớ rồi up bằng Recovery phải không !? Sẵn đây cho mình xin luôn theme màn hình khóa nào lạ một chút (Giống iphone một chút cho đủ tông cũng được :ar!), không thích màn hình khóa của miui cho lắm (Không tính việc thay bằng widget nhé).
_ Hix, vì hoàn cảnh trước mắc là đang ở trên núi cả tháng sau mới về nhà, không tiện cho việc tìm hiểu thông tin nên phải post thắc mắc. Mong sớm được giúp đỡ.
MIUI ROM tương đối đơn giản và dễ xài nhưng với người mới thì cũng có chút khó khăn. Mình góp tí kinh nghiệm cho bạn nè:
1. Muốn chọn nhạc chuông vào Setting>Call Ringtone> bấm Menu > chọn Other > Music> chọn nhạc chuông tùy thích
2. Không biết có lỗi không vì mình toàn vào bằng wifi cái này chắc phãi đễ bác Ân trả lời :D
3. Quay phim xong xem bình thường không bị gì nhé. Bạn thử Fullwipe và cài lại xem sao?
4. 3d Gallery có thễ down trên Market. Muốn chọn 1 Program nào làm Defaut thì khi bấm chọn vào nó sẽ hiện lên 1 bảng cho bạn chọn. Tick chọn vào ô bên dưới 1 chút rồi chọn Program bạn thich là xong
5. Muốn thay Theme thì down theme về rồi vào SDCARD> MIUI> THEME bỏ vào đó. XOng ra màn hình Home chọn Theme Manager rồi chuyễn Theme. Không cần phãi Recovery.
6. Muốn thay LockScreen thì lên Market down cái LockBotPro về. Nó cũng thay được nhiều LockScreen cho bạn tùy chọn
Chúc vui !!
Vụ này đã trả lời RẤT NHIỀU LẦN . Muốn down từ Market với 3G vào ứng dụng Tải về/Menu/ Sử dụng Mạng di động
Quay lại dùng bản 9.5a coi có tiết kiệ pin ko, con của mình ăn kinh khủng quá..... hiz.
