Anh em cho hỏi có ai biết cái này bán ở đâu kg ạh (audio to A2DP bluetooth)
TNT8N8
-Product Description
-Jabra Stereo adapter plug, Bluetooth A2DP profile adapter, model A120s/ 100-61210000-02 pairs with all Bluetooth A2DP profile enabled cell phones, computers, PDA, etc.
-Jabra Bluetooth stereo adapter plug model A120s lets you listen to your favorite music without the hassle of wires, and still stay in touch through your Bluetooth cell phone.
-Simply plug the Jabra A120s stereo adapter into your PC or music player's 3.5 mm stereo output jack, pair up with the any Bluetooth stereo headset, and - PLAY - you're good to go!
-If you're waiting for an important call, or just want to stay in touch, you can also pair your optional Bluetooth stereo headset with your Bluetooth enabled cell phone at the same time.
-The Jabra A120s comes with a standard 3.5 mm plug and is compatible with most stereo music players.
-Provides up to 10 hours music time before you need to recharge with the included USB charging cord, making recharging the internal battery fast and easy from most computers.
-Charging time is up to 6 hours
-Stand-by time is up to 250 hours standby time before recharging.
-Weight is only 20 grams.
-Bluetooth A2DP profile is supported on this Bluetoth version 1.2, class 2 device for better connectivity up to 30 feet away.
-Click here to determine if your cell phone model is Bluetooth enabled, AND which Bluetooth profiles it can support.
-Limited A2DP profile compatibility, as the Jabra A120s only supports pause (mute) function.
-Jabra factory original one year warranty applies.
Ai biết ở đâu bán chỉ giúp em nhé...,kg nhất thiết y chang cái này nhé...,chỉ cần có chức năng tương đương là đc ạh !
Anh vào Google gõ lần lượt các từ khóa:
Jabra 120 - Jabra a120s - Jabra a125s - Jabra a320s là sẽ biết chỗ nào bán ngay thôi mà :))
Ảnh của anh đưa lên là Jabra a120s.
anh LS khéo đùa nhĩ...,em đang tìm ở VN bán mà..hichic ,có 1 chổ bán mà là mono..:-<
Có em này Creative HeadPhone SE 2300
Nhưng cái khó là bác phải mua cả bộ gồm 1 em tai và 1 em Bluetooth Adapter như bác mong muốn.
Thôi thì mua xong bán em Headphone đi cũng được! :D
Giá cả bộ là $157 thì phải!
Chỗ bác Lam Sơn chỉ hết hàng lâu rồi.k biết còn chỗ nào nữa k
Bạn có thể chọn DC800 của Motorola (gọi cho nhà phân phối Motorola accessories - VNCTC, 39250161)
Em dc800 này to quá.Đang xài itech blucon 35-ii mà k vừa ý lắm vì chỉ pair đc với tai của itech và khoảng cách ngắn lắm (4m), lại k xuyên tường,nhưng đc cái âm thanh tốt.
Em có cái này còn mới 100% chưa dùng lần nào, hôm trước mua ở Sing, nay bác nhắc mới nhớ.
cái DC800 của bác PHP và hah giới thiệu củng đc mà to thế nhĩ..., giá của nó bao nhiêu lận ,các bác cho em tham khảo với
-còn A120s cua anh Loxa thì để em coi sao...,cần gì em liên hệ với anh
Bạn gọi cho số ĐT mình đã cho đấy. Lúc trước giá khoảng 1.5t, bây giờ chắc giá đã hạ rồi! Trả giá thử xem sao :>
Con này là bluetooth class 1 phủ sóng đến 100m, nếu bác dùng 1 tai nghe BT nào cũng class 1 thì có thể khoảng cách sẽ tốt hơn là class 2 (10m)
anh PHP cho em hỏi cái ngớ ngẩn chút...,bluetoot class 1 khác với class 2 chổ nào ạh...,giống như thẻ nhớ có class 4 và class 6 hay sao anh ?
Cho dễ hiểu là công suất thu phát của chuẩn Class 1 là lớn nhất nên tầm hoạt động giữa hai thiết bị rộng hơn (trên lý thuyết là khoảng 100m). Chuẩn này có thể bị cấm sử dụng ngoài trời ở một số nước vì có thể gây nhiễu (ví dụ ở Pháp). Còn Class 2 có tầm hoạt động là 10m, Class 3 là 1m.
Tôi đã thử 2 thiết bị có cùng Class 1 là DC800 và S705 (cũng của Motorola). Tầm hoạt động có xa hơn, nhưng nếu bị chướng ngại vật nhiều thì cũng dễ chập chờn lắm. Nếu bạn thích thử thì PM cho mình.
