AntiTheft 1.20 Final by gabika318 (Update 31/08/09)
AntiTheft 1.20 FINAL - Update 31/8/0
AntiTheft 1.20 FINAL - Update 31/8/09
[By gabika]
Feature:
When the cellphone is lost or thief somewhere, or the SIM card is replaced this app send informations thief or founder SIM card.
!!!Use only 5 KB RAM!!! tested my SE M600i
Usage:
Before: Uninstall m Runtime Environment and previous AntiTheft version
1. Install SIS
2. When install finished - go to Control Panel and start Anti-Theft Configurator (Default PIN Code: 12345)
3. Now, the application some information read and stored your SIM card
4. Check the Options menu
(and set protection etc...)
5. Enter your phone number to which to send the information to the program
Todo - before change SIM card :
1. Go to Control Panel start Anti-Theft Configurator
2. Disable Protection
3. OK and exit
4. Change SIM crad
5. Now, turn back to
6. Enable Protection
7. OK and you see this:
Functions:
Enable-Disable protections
Auto send SMS when the SIM card is replaced and Send IMSI information
Autostart application
Send Cell ID
Obtain some entries from the address book
Application install only C:\ drive (phone memory)
New: Anti-Theft Configurator application
Add Passord Protection
The Anti-Theft appl. run hide and more speed (0,5 sec) when boot your phone
(After immediately closing the Anti-Theft appl.)
Support more SIM card
Autostart default, non selectable
IMSI:
What is IMSI - International Mobile Subscriber Identity - Wikipedia, the free encyclopedia
Analyse - International Numbering Plans
IMSI number format - 123 12 1234567890
123 = Country
12 = Operator
1234567890 = SIM card unique ID
Cell ID:
What is Cell ID - GSM localization - Wikipedia, the free encyclopedia
Version: 1.20 Final
History:
0.10 beta
First version
0.30 beta - http://www.persian-forums.com/f76/an...457/#post68774
Add autostart function
Fixed Status Info
Some bug fixed
0.60 beta - http://www.persian-forums.com/f76/an...457/#post68849
Send by SMS: Cell ID and some SIM contacts (15)
0.80 beta - http://www.persian-forums.com/f76/an...457/#post69839
More Stealth - More Security
Add this app to Control Panel
The Anti-Theft script run hide and more speed (0,5 sec) when boot your phone
0.90 beta - http://www.persian-forums.com/f76/an...html#post71071
Fixed Installation pack
Fixed some application bug
1.00 FINAL
Add About and History menu
1.20 FINAL
Fixed: Support empty SIM card
Fixed: Change Password menu Cancel - when cancel this menu set default code: 12345
!! TURN OFF CAPS BEFORE MODDING !!
!! PLEASE TEST AND WRITE HERE RESULTS !!
!!! BIG THANKS FOR ALL TESTERS !!!
Mình cài vào bộ nhớ của máy, capswit off rồi. Khi mở chương trình lên bị lỗi 'corrupt' là sao vậy các bạn. Bản 1.0 và 1.2 đều bị như vậy. Ở control và tool đều ko được
bạn gở bỏ cái m Runtime Environment cũ đi cài cái mới vô là được mình cũng bị thế.
