ASUS P535 - ROM WM6.1 PDAVIET (Build 21014.1.6.0)
Just installed this ROM yesterday ,with Asus today.
Works fine till now.
I used with SPB Phone and SPB Mobile Shell.
Fast boot, best ROM i tried until now.
Thanks man for a great job!
Hi, this might not be a bug or feature with this rom or how the windows mobile works.
I received an mms and read it, but i wanted to reply that mms but using normal sms text, is there a way to do it without manually going back into text message folder to create a new sms?
Sometimes like reading the MMS and reply via SMS
Khắc Duy ời trong phần asus today làm thế nào để chỉnh thời tiết nhỉ.
Ko thấy có việt nam :D
Hơn nữa khi chọn update nó cứ hổi proxy, chọn cancel là nó báo update fail ngay???
Bạn đang dùng Asus Today build sẵn trong Rom hay là file gửi kèm. Nếu là build sẵm trong rom thì có sẵn. Nếu là file gửi kèm thì thiếu phần Việt Nam, mình sẽ up lên lại sau do file đó mình down trên web của Nga.
Very fast boot time!!! I really enjoy this ROM. Thanks for your great work!
Just one comment. As I know GPSCatcher doesn't work with P535 because its GPS reciever couldn't be handle .ee data. I tested it many times but there was no big difference.
