ASUS P535 with WM 6.5 - first time EVER
hmm. im using this rom now but sometimes my device turns off itself what can i do?
off like p535 switch off... or screen go sleep mode... ??
have you installed a program to watch battery, use sleep parameter ?
first time it screen go sleep but next times it switchs off i haven't íntalled something yet
First,thanks gxg for this ROM.
It's been now more than one week(exactly from the day that you posted the first version) that I am trying it.
And even with some glitches it is not bad for a beta.
The only thing that I miss is the wi-fi and it is showing that there are no drivers or maybe I am missing something.
If there is a way to activate it,please help.
I also noticed that it uses a lot of memory because it only minimize the progs.I tried WKTask(Wich I am not a fan) but it was giving a shell error.
Also is there a way to free memory without using a task manager program?
I like my PPC to be light.
Thanks in advance.
@ ForceField...
1 - Wifi works without problem ! i can connect at all wifi point secured or not !
2 - WM6.5 still doesn't close prog... WKtask is good solution but i search how to exclude Shell... because some times i close Wm6.5 interface when i need use start menu... i have created my shell with Wisbar on this build !
3 - For memory consumption, in rom included : Oxios hybernate => thsi prog send a message to close inactive prog...
or you can try Sktools with FreeUp Ram and the Ghost mode to free ram auto... very usefull - i use the third method... with wktask...
ánd no problem about memory...
@LeSScro
Thanks for the infos now I have about 23-21 MB free all the time and my P535 is a lot faster.
But I didn't managed to make wifi work and the OS is reporting that there is no driver.From your words,it should be enabled.Is there a way to enable it?
It seems to appear... you have a Wifi Driver Problem...
Make a backup files... Try to reflash your Asus then test in Clean ROM : wifi access...
what settings did you mean to I must do?
Start Menu\Settings\Power...
Then backlight...
Start Menu\Settings\WakeUp source\
If nothing works... i can share a SPB backup files...
It erase all your settings by mine... it works...
@ ForceField...
I can share too a SPB Backup file... Some programs won't work but you can clean Programs after backup... then i think WIfi must be res:-? tore !
WM6.5 News !
@ GXG...
Have you seen the new leaked release... WM6.5 build 21169... with some improvement and stability... I hope you can make an upgrade...
After some dáy with this ROM, i think it s beautifull
I have play a little bit with this ROM and i found a way to change some colors (specially the BLUE)
Preview... Menu, Pop Up, Change scroll Bar and Start Menu Tweak grid and background...
Repsted all,
i like thí solution plese can you reupload rom any other uploader like rapidshare bcoz i cant able to dơnload from mediafire other wise write me mail rk19801@gmail.com
i hope you repply me sôn.
Lại có rom mới để test. Dùng 6.5 cũng thấy thích, nhưng máy không được nhanh lắm!
Jut Reflashed with build 21014 and I am waiting for a good version of wm 6.5.
I think that the current 6.5 builds needs some work.
I also heard about the new 21169 and will try it when it will be available;)
@ Forcefield...
New version available in PDAclan but need some works...
I read problem with Titanium skin but much better response...
I see too SergeyLar, russian, work on new release 21169 and solve some problem... maybe in few week... a new version available...
i think GXG work too on new release... some ROM DUMP are downloadable !
@LeSScro
I noticed that more new builds are available and more ram is used.My device is only 64 mb RAM and I am thinking to upgrade to a 128 mb device or 256 mb soon if not tomorrow.The response of these new builds is made at the expense of the memory.
Anyway the P535 is still a good device and I will continue to use it as a test platform.
Hello to all,
I came back with some bad news... I'm a proud owner of HTC Diamond...
And I will not work anymore to develop new ROM's for Asus, because now my old P535 is in my wife hands, and she have to have some stable and working Phone/Gps/Games platform.
So.. I will read, I will post, but I will not work anymore to another release. Because I have to give explanations, to restore back the P535 and stuff... and I don't want to argue with her base on my work and test.
Sorry... if I can help.. please PM or write me.
Thanks GXG,
I also just bought an HTC Touch HD.No more ram problems with this one.Don't have to mention that now I have a money problem at least till the end of the month.:D
