Bản chính thức của Ranju's - v7.6] WM6.1 Pro - 5.2.19209 (Build 19209.1.0.2)
DucLong
Super V.I.P
Core mới của WM6.1 Pro - CE OS 5.2.19209 (Build 19209.1.0.2) with "12.5 MB Flashdisk".
Thông tin về ROM
Changes and Features of v7.6:
-- New WM6.1 Core + OS (Build 19209)
-- New SIM manager
-- New Network Setting tool
-- New 12-button CommManager
-- New WMP Skin
-- ArcSoft MMS Composer 4.2 (max. MMS size set to 2MB)
-- TCPMP Media Player 0.72
-- BT FTP explorer
-- WkTask 1.1.7.3c (by waku) Task manager
-- Camera Application (Build 25626)
-- TodayAgenda 1.10 today plugin
-- WM5torage 1.78 (USB HDD Emulation)
-- Total Commander 2.5
-- Adobe Reader LE 2.0 (optimized)
-- OxiosHibernate 1.3 (no dialog, for memory release)
-- Performance/overclocking applet (default 624 MHz)
-- DF's PIM Backup 2.8 (for contact, sms/mms etc. backup)
-- DF's Task Manager / Registry Editor 2.9
-- SynchroTime (by Grachov) for Internet time sync
-- PocketRAR 3.71 (with .zip/.rar association)
-- NetCF 3.5 and SQLCE 3.5
-- SD/SDHC driver
-- SD/SDHC driver switch-over tool (thanx OllieD for coding support)
-- File-Dialog changer (for file browser enhancement)
-- Voice notification & ringtones
-- Improved Video renderer (game play should be OK now)
-- Improved Phone response
-- PIE hi-res support
-- Source filter issue resolved
-- SMS mode set to standard (for Threaded SMS, set "SMSInboxThreadingDisabled"=dword:0)
-- Image size and compression issue of MMS Composer resolved
-- Managed Program applet removed (due to Class not registered error)
-- STK srvice and all the common utilities
-- SMS delivery fix (by Saman)
-- Set default search to Google (desktop) search
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- Enhanced wifi driver with WPA workaround
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Disabled today plugins - Date, Appointments & Tasks (replaced by TodayAgenda)
-- Almost all the Today item set to hidden (Unhide from Today settings, if needed)
-- Exe's & Dll's transformed to module (wherever possile)
-- Registry type set to file-based (instead of buffer-based)
-- Some performance tweaks
-- Unlock/Unhiding tool for extROM
-- Should work on G3/G4 both devices
-- 12.5 MB Flashdisk (for G3/G4 both devices)
-- Increased PagePool - 5.6 MB
-- 128 MB RAM Support (may need to set PP => 0)
*Trong flashdisk có hai files cab, người dùng có xóa đi nếu không dùng đến
-- Windows Live
-- Transcriber
link tải rom v7.6 và file khắc phục lỗi cho extendrom
Lưu ý: Link tải các phiên bản của Tomal (Ranju) đã die hết rồi nhé!
[hide]http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_v76_WM61_19209_19209_1_0_2.exe
file làm trống extendrom: http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_ExtROM.rar[/hide]
Hình như bản ROM này Bác TLV cũng đã giới thiệu ở Topic trong cùng chủ đề rồi mà bác Longnguyen ?!:D
Hay để mới là bản chính thức , còn bản Bác TLV giới thiệu chỉ là bản Beta?
bản này là bản chính thức, còn bản của TLV là bản beta đó bác. theo nguyên tắc thì bản beta mình không nên post lên cho cộng đồng sử dụng mà chỉ giới hạn số người dùng thôi. mình post bản beta của người ta thì nếu họ phát hiện thì phiền. bản này có chỉnh sửa cho ổn định rồi.
mình đang xài bản 7.4 của ranju thấy rất tốt. trước giờ theo mình nhận xét thì các bản rom của ranju rất ổn định và tốc độ khá nhanh, các chức năng, kết nối hoạt động tốt.
bây giờ lại có rom mới để up.
CAN'T STOP UPPING ROM!!!
để load về test thử cái đã.bản beta up được 4 ngày có cuộc gọi đén là máy treo lun và rung không dừng
thanks ...
Link download ROM bị die rồi Bác Long Nguyên ơi !
Em kích vào nó báo File not found!
Các bác ơi, link die rồi. Bác nào down được rồi thì up lại lên host khác cho tui với.
Thanks
THÊM LINK CHO ANH EM
[HIDE="http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_v76_WM61_19209_19209_1_0_2.exe"]http://vidmes.com/xda/Uni/ROMs/Tomal/Ranju_v76_WM61_19209_19209_1_0_2.exe[/HIDE]
Các bạn đừng có kích vào, mà hãy xem địa chỉ, rồi chịu khó đánh lại tới phần Rom thôi và vào tìm phiên bản mới của Ranju sẽ có nhé.
bản beta test thấy cực ổn, bản này chắc sẽ good hơn, he, lại có rom để test roi, mình có ấn tượng rất tốt về rom của ranju, buitl rất tốt
tối qua mới up bản beta do TLV up chả hiểu sao đang cài soft nó tắt ngủm luôn kinh quá sáng nay hì hục mãi mới vào được boot giờ có bản này tải vìa test luôn
thanks man
khác nhất là ở chỗ bác ranju đã cho nó trở thành chính thức và đã test hết hộ chúng ta rồi, k làm hại tới thiết bị của chúng ta nữa thôi, mình thấy cũng chưa có gì khác lắm
Thử bản beta mà thấy ưng ý ghê, bản chính thức này thì còn gì bằng... down và tét thui.
Cảm ơn.
Vài hình ảnh của bản ROM này để anh em tham khảo:
Chưa thấy gì mới cả, ngoài vụ pin có thể khá khẩm hơn một chút
Có cách nào có thêm cái hàng tray bar ở dưới mà ko cần cài soft ko nhỉ :-?
Dùng registry thôi.
Tìm đến HKCU\Software\Microsoft\Today\Keys\112\
Đổi tring (Default) = thành tên soft cần hiển thị
Đổi tring Open = thành đường dẫn chứa soft chú ý có dấu "" vd: "Windows\Calendar.exe". Xong SR lại máy.
