Bản FW mới của N70: 5.1003.3.0.1 v14
Lan truoc em co dung pcsuite up FW nhung chang thay dc gi van la V5.0638301
18-09-06
RM84
(moi nguoi thong cam em on =dt nen ko post dc tieng viet.Xin dung xoa bai cua em)
Mún up lên thì phải down fw về, up offline với jaf hoặc phoenix. Vì trên trang nokia vẫn chưa cập nhật đc. Nên up ol với Nsu ko đc.
JAF version 1.98.62
Detected PKEY: 9000BC25
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.17.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.V01
APE Variant file: ?
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.V22
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_51003301.UDA
Backing up CRT...
Detected P-KEY: 9000BC25
Init usb communication...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\355720026263362_CRT_backup_630222.pm
Done!
Backup CRT OK!
Searching for phone...Found
Reading SW version...05wk07v48.1 5.0737.3.0.1
Reading battery value...4104 mV
Init usb flashing...
Reading flashid...
CMT: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
APE: 00360098 <=> SAMSUNG -> Type not in database
Verifing ADL communication... Status byte 2
Scanning selected flash files...
ADL -> Loader: C:\Program Files\ODEON\JAF\Flash\ADLREVC00.adl
ADL -> Sending loader...
Loader sent...
ADL -> Loader: C:\Program Files\ODEON\JAF\Flash\ADLREVA00.adl
Waiting for the phone to boot...
Fail to reboot the phone...
Searching for phone...Detected P-KEY: 9000BC25
Found
Error reading full info...
Found
Found
Error init usb flashing...
Found
Mình check thử CHK và INF thì nó báo như trên nè
JAF version 1.98.62
APE Variant file: ?
Backing up CRT...
Reading IMEI...
Done!
Backup CRT OK!
Reading flashid...
Loader sent...
Found
Found
Found
Found
Thử flash chế độ Dead USB đi, nếu vẫn bị thì chắc phải flash = box.
Check sao hướng dẫn dùm mình luôn đi
bạn qua bên s60v3 mà tìm hiểu, ở đó có box riêng về update fw bằng phoenix và jaf nữa
:D
mình đã up thành công, nhưng hình như trước tiên là inf trước, khi hiện imei thì mới click flash thì phải
sau 1 tuần sử dụng FW này mình thấy tốn pin hơn, còn lại gần như ko thay đổi :(
mình thấy pin vẫn bình thường ah,còn chạy nhanh hơn thì ko thấy vậy,chắc có lẽ là do cảm tính của mấy mems khác
Hay ma hoc hoi co ji .Vi dam me up thu the nao thoi. Kaka .Rat tuyet sau khi up thi may minh thay doi nhu sau:
v5.1003.3.0.1
20-01-10
RM-84
EM DUNG DT MOD DUNG XOA BAI EM NHE.
Ặc!Up F.W xong mà vẫn là ngày 1.1.07 thì chắc là thất bại rùi.Máy chạy nhanh hơn do toàn bộ data tro máy bị xóa hết.
Nhanh hơn khoảng 2o lần trước kia. Máy trước kia play game ko nhanh khi mà đã up fw này. Ko biết up fw online như thế nào nhỷ
em thấy nó cũng bình thường được cái load nhanh hơn mấy bản trước và hình như khi vào gallery nhanh hơn thi phải hình load rùi ko phải load lại :-??
Ai biết giúp mình với.tại sao mình up online bằng nokiaupdate.thì FW 5.0705.3.0.1 là fw cuối chứ khg fải là fw 5.1003.3.0.1? Cảm ơn trước
trên web của nokia chưa có bản fw này mà
mình mới up xong, chưa thấy có gì khác cả, hình như vào menu nhanh hơn
bây giờ mình mới thấy fw này hỗ trợ xem youtube tốt hơn (bằng realplayer của máy)
bạn hãy down bản FW ở bài đầu tiên về mà up offline đi.Trên web bản 5.0705.3.01 thui là đúng rùi, chắc nokia chua cập nhạt đc ấy mà;;)
