Biến XP thành Mac OS Leopard
bác nào có thể giúp mình cách làm không.mình không biết tiếng EN nên chịu chết.hoặc dịch hộ mình cũng được.cám ơn.
Important Note !!!
- Please make backup before replace your system files.
- Also create restore point for easier to us to change back to normal.
- These files can only work in Windows XP SP2 (English version ONLY).
- Only do in SAFE MODE...
Use 'replacer' (which is include in replacer folder to change system files.
Instruction;
1. Open 'replacer'. Then drag original 'explorer.exe' (%windir%\explorer.exe)
into the 'replacer'. Follow the instruction. After that, replace it with
the new 'explorer.exe' files with it include in this pack.
2. Open 'replacer'. Then drag original 'shell32.dll' (%windir%\System32\Shell32.dll)
the new 'shell32.dll' files with it include in this pack.
3. Open 'replacer'. Then drag original 'xpsp2res.dll'(%windir%\System32\xpsp2res.dll)
the new 'xpsp2res.dll' files with it include in this pack.
4. For My Documents GUI, Open 'replacer'. Then drag original 'mydocs.dll'
(%windir%\System32\mydocs.dll) into the 'replacer'. Follow the instruction.
After that, replace it with the new 'mydocs.dll' files with it include in this pack.
5. Open 'replacer'. Then drag original 'msgina.dll'(%windir%\System32\msgina.dll)
the new 'msgina.dll' files with it include in this pack.
Then, restart your pc. You will see some changes in your system. That's all.
