biteSMS v6.1 [bài 244] - Ứng dụng nhắn tin số 1 trên iPhone
Cập nhật biteSMS v5.2.1 Fix
(30/03/2011)
Mình ko sử dụng nên ko có thuốc.
Link tải:
Mã:
http://www.mediafire.com/?7j1dode2zvt0565
Cập nhật chóng cả mặt,chẳng biết nó fix cái gì,xài bản 5.1 tới giờ chả buồn câp nhật :))
(30/03/2011)
Link tải:
Mã:
Trên trang chủ tại thời điểm này (21h_30-3-2011) chưa thấy update v5.2.1
[SIZE=+3]biteSMS v5.3[/SIZE]
Version 5.3
14 June 2011
  • Quick Reply now shows MMS picture(s).
  • Quick Reply pull-down curtain also shows MMS pictures.
  • In Quick Reply, for MMS pictures simply tap to view in full screen (on lock and unlock screens), tap to return. zoom in, out, scroll etc.
  • Improved Quick Reply, such that the text field grows as you type more lines.
  • Added 'Auto-Forward SMS' feature, redirect your incoming SMS messages to another phone!
  • Added 'Repeat Alert' option in biteSMS > Settings > Ringtones (Once, Twice....10 Times).
  • Added 'Open to List' feature (when pressing biteSMS icon, the conversation list only will open).
  • Added 'Auto Show Recents' feature in Quick Compose. See biteSMS > Settings > Quick Compose.
  • Added 'Quick Switch' menu feature when long holding on the [send] button.
  • Added 'Mark all Read' feature in Quick Reply and Compose for the pull down Previous Messages feature.
  • biteSMS now properly supports the 'Large Text' feature in Apple Settings > Accessibility.
  • When long holding a bubble to show the timestamp we show the text in orange for TextFreek sent and received messages (for new messages only).
  • Added a new Quick Reply setting 'Show MMS'. This is to allow those users on carrier networks (e.g. AT&T) to turn off MMS in Quick Reply as it causes an issue with Group messaging.
  • Added a paste feature to Quick Compose in the 'To:' field.
  • Send from command line (log in as mobile user):
    /Applications/biteSMS.app/biteSMS -send [-carrier|-bite] to_address text_msg
    For example: /Applications/biteSMS.app/biteSMS -send -bite +6151846910 "hello mum"
  • Performance improvements inside the biteSMS application.
  • Fixed a bunch of bugs.
Mã:
http://apt.thebigboss.org/repofiles/cydia/debs2.0/bitesms_5.3.deb
Cập nhật BiteSMS v5.3
(Đã thuốc)
Mã:
http://www.multiupload.com/8GSGF79SYM
Mã:
http://www.mediafire.com/?4857sm2r4i86blw
Bản 5.3 này vẫn còn bị safe mode mỗi khi mình reset network bạn ơi. Mình đang dùng IP4 4.3.3 world và bitesms bản quyền.
Có lẽ là reset sẽ xoá bỏ thành phần nào đó của mobilesubstrate hoặc preferences nên bị lỗi safe mode bạn ạ
Bản này có gì mới không Aquasta ơi.
Mình cũng ko đọc changelog tuy nhiên bản 5.2 bị nhiều lỗi trên firmware 4.3.x ví dụ như có tin nhắn đến call không được. Bản này có vẻ fix nhiều lỗi cho 4.3.3
cho mình hỏi là mình đang dùng IP4 bản FW 4.3.3 và mình dùng mấy bản bissms rồi nhưng không hiểu sao mình không thể tap vào biểu tượng hình camera trong phần điền icon để đính kèm vào tin nhắn ảnh của máy hay ảnh chụp . trong khi đó mình có cài một bản cho con IP3GS của bạn mình ( không nhớ dõ phiên bản ???? ) thì lại có thể tap vào biểu tượng đấy và máy hiện ra mục photo của máy cho mình chọn ảnh . bạn có biết thì chỉ mình cách cài với .thank
Bản bạn nói trên 3gs chắc cũ rồi!
Bản mới này bạn tab vào dấu + nó sẽ đưa ra 1 số smile và tùy chọn thêm danh bạ, hình cái máy ảnh thì bạn tab vào đó nó sẽ đưa ra lựa chọn lấy ảnh từ máy hay nguồn khác!
Ví dụ cụ thể:
Khi tab vào hình máy ảnh!
Chúc vui!!!
Ví dụ cụ thể:
Chúc vui!!!
mình đang dùng bản 5.3 đây . nhưng mình có thấy cái dấu + nào trong đấy đâu . chỉ thấy một khung trắng để viết thôi chứ có thấy + nào để tap vào đâu .
Bạn Remove đi cài lại xem!
Mình không tùy chỉnh gì mà cài nó có luôn!
Các cài đặt của mình đây:
