DESCRIPTION:
You love your iPhone as much as we do? You text all the time? Want more features? Then biteSMS is for you, with lots of extra features like Smileys, Quick Reply, Quick Compose / Quick Call, Privacy, a Character / SMS Counter and much more! You can use biteSMS as a replacement to the built-in Messaging application, and send messages via your mobile carrier as you normally do. Or, if your mobile carrier charges a lot for sending SMS messages (say texting to overseas), you can buy credits and send them via the biteSMS network instead, which can be much cheaper.
CHANGELOG:
v 4.95 - July 8, 2010
* Fixed all known issues with Drafts and Backgrounder consistencies in conversation list and conversations.
* A nice NEW feature for all those users who have been so patient with the iOS 4 bugs. You can now backspace in Quick Compose to quickly get back to the "To:" field. Makes it much easier to change the recipient name. Settings->Quick Compose->Backspace to "To:" default OFF.
* Fixed Quick Reply issue when there was more than 3 lines of text in landscape mode.
* Cursor no longer disappears in Quick Compose.
* There is no longer any "cannot use Keyboard" delay when Quick Compose is invoked. So now it’s quicker to use.
* Fixed issue, whereby you could touch the "Contact Name" area on Quick Reply and it would incorrectly dismiss the alert.
* Fixed a number of issues with signatures containing special characters, like smileys or brackets.
* Fixed issue where biteSMS Passcode (if set) did not always appear if you opened the native Messaging app.
* Fixed issue where [Open] in Quick Compose and Quick Reply and Contacts (etc) did not prompt for biteSMS Passcode (if set).
* For incoming MMS messages the badge is now correctly shown on the biteSMS icon not the native Messaging one.
The above fixes are all for iOS 4 issues. The only change for iOS 3 is a fix whereby the Quick List icon did not always function correctly for a limited number of users.
