BsB Tweaks - DÀNH CHO HD2 (Leo)
PhamQuang
Manager
BsB Tweaks 1.4​
Ứng dụng rất tuyệt vời, cho phép thay đổi chỉnh sửa chức năng trên HD2 của tác giả makeveral (XDA), gồm các chức năng:
Mã:
* General
          o Power Saving
                + - Enables the power setting options to save some battery.
          o Hidden Camera Modes
                + - Activates hidden camera modes (GPS photo mode & video share) .
          o Auto Lock
                + - Automatic lock the device when not in use.
          o Auto Sync Clock
                + - Automatic sync the clock and time zone.
          o STK Service
                + - Enable or Disable the STK Service (Sim ToolKit).
          o Windows Settings
                + - Show normal settings in start menu
          o SIM Contacts
                + - Show SIM contacts in your contact list.
          o SMS Mode
                + - Change SMS view, between Chat and classic view.
          o HTC Vibration
                + - Enable the vibration in HTC applications.
          o Customer Feedback
                + - Enable or Disable the custom feedback service.
          o Error Reporting
                + - Enable or Disable the error reporting service.
          o Owner Info
                + - Show or hide the Owner Info in settings.
          o Screen Sensitivity
                + - Decrease screen response sensitivity.
          o Polices
                + - Allow install and run unsigned applications.
          o HTC Magnifier
                + - Enable or disable the HTC magnifier option.
          o Phone Slide Cover
                + - Show or hide the incall slide cover option.
          o Windows Notifications
                + - Enable dismiss X time in windows notifications.
          o Radio Deemphasis
                + - Improves radio quality.
    * Performance
          o Glyph Cache
                + - Enable high glyph cache, graphics render for faster graphics.
          o TCP/IP Cache
                + - Increase cache of TCP/IP
          o Startup Animation
                + - Disable the startup animation for faster boot.
    * Graphics
          o System Menus
                + - Enable or Disable the default windows menu.
          o Manila Send Button
                + - Show send button in messaging applications.
    * Led Notifications
          o Message Notification
                + - Enable LEDS when you have a new SMS.
          o Voice Mail Notification
                + - Enable LEDS when you have a new entry in voicemaill.
          o Call Notification
                + - Enable LEDS when you have a missed call.
          o Reminder Notification
                + - Enable LEDS for reminder notifications.
    * Connections
          o Wifi N
                + - Enable Wifi N, to improve network throughput.
    * Opera 9.7
          o Opera Vibration
                + - Enable vibration in Opera browser.
          o Opera ZoomBar
                + - Show or hide the Opera zoom bar control.
          o Opera Visual Back
                + - Enable Opera visual back feature.
          o Opera Link Click
                + - Enable the ability to click links without zooming.
          o Opera Tabs
                + - Allow having 9 opera tabs in browser.
Hình ảnh minh họa:
Để ứng dụng chạy trên HD2 (Leo) cần phải có NETCF 3.5, có thể tải theo link sau:
[DOWNLOAD]http://rapidshare.com/files/318588912/NETCFv35.wm.armv4i.cab[/DOWNLOAD]
Ứng dụng hiện nay là phiên bản 1.4, đưa kèm dưới bài.
Bác Quang ơi,
sao em dùng chức năng rotation và add các application cần xoay màn hình vào, khi check bật chức năng xoay màn hình nó vẫn im re! :-?
đặc biệt là khi close chương trình và mở lại thì nó lại nhớ ở chế độ uncheck!
Đã có bản BsB Tweaks 1.6 rồi, các bác có thể download bên XDA. Không cần remove các phiên bản cũ đã cài.
Em không up được file nên gửi tạm link, các bác thông cảm ạ.
...ttp://forum.xda-developers.com/showthread.php?t=589305
Đưa link kiểu gì thế bạn.
Bản 1.6 kèm theo bài đây.
Những thay đổi cập nhật sửa lỗi ở bản 1.5 và 1.6 :
Mã:
[Ver. 1.6]
[LIST]
[*]Added option to change manila left softkey easily
[*]Fixed problem that rotated apps wouldnt save if a softreset was made just after adding it
[*]Changed some descriptions and names
[*]Fixed Screenshots not working in some ROM Languages
[*]Added tweak to enable wifi in standby (not working in all rom versions... will see if i find a workarround)
[*]Added tweak to change album X behaviour
[*]Added tweak to enable adobe reflow
[*]Added tweak to change sms max recipients to 50
[*]Added tweak to improve video recording in mpeg4
[*]Added tweak to enable hidden video recording formats
[*]Other Minor Fixes
[/LIST]
[Ver. 1.5]
[LIST]
[*]Fixed problem that reg changes wouldnt persist after soft reset
[*]added smswakeup tweak
[*]added 8mp camera tweak (thanks to DAMIEN123_666)
[*]Added soft reset in menu
[*]other minor fixes
[/LIST]
Sao bác nóng thế ạ? Em sợ đưa link từ forum khác nhỡ vi phạm gì, nên bớt chữ "h" ở đầu đi thôi ạ. Cách làm này cũng bình thường ở mọi diễn đàn mà, copy vào rồi thêm chữ h vào là ok.
Thiết nghĩ bác không cần phải nói kiểu như thế đâu ạ. Cảm ơn.
Mình nghĩ là bạn cứ đưa link đầy đủ không vấn đề gì đâu! :)
