duong_tuan_viet
chẳng mấy ai downgrade cả.nếu bạn thấy lỗi thì gỡ bỏ hết phần mềm về nokia rồi cài lại.dùng phoenix flash thử xem mình dùng 5800 thôi nhưng chưa bao giờ flash fail cả.bạn nên xem lại kết nối cáp với máy tính dung cổng usb sau nha.sạc cho đầy pin vào.có lẽ là những cái biết rồi nhưng thử làm xem.Hôm qua mình mới up firmware mới cho N97 bằng JAF, nhưng phiên bản đó bị lỗi nên mình downgrade, nhưng mà down ko được.(
code
HTML:JAF version 1.98.65 beta1 Detected PKEY: 90009C48 P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.27.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\products\RM-505\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\ Scanning ini files... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM-505_21.0.106_prd.core.C01 PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM-505_21.0.106_prd.rofs2.V51 CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM-505_21.0.106_C01_prd.rofs3.fpsx APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM505_507_21.0.106_uda_11_001.uda.fpsx Changing flashing settings... Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM-505_21.0.106_prd.core.C01 PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM-505_21.0.106_prd.rofs2.V51 CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM-505_21.0.106_C01_prd.rofs3.fpsx APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-505\RM505_507_21.0.106_uda_11_001.uda.fpsx Backing up CRT... Detected P-KEY: 90009C48 P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Preparing for downgrade... Detected P-KEY: 90009C48 P-key nokia module version 01.02 Init usb communication... Failed to prepare for downgrade... Detected P-KEY: 90009C48 P-key nokia module version 01.02 Init usb communication... Searching for phone...Found Reading SW version...Error reading rap ver!
