CÁC THỦ THUẬT, ỨNG DỤNG DÀNH CHO MÁY ĐÃ HACK.
c2z maker
Công cụ tạo file c2z.rmp dành cho các bạn hay dùng các thủ thuật hack để load các file từ ổ C trước ổ Z.
File này chạy trong RomPatcher.
Ứng dụng cần có PIP 1.3 để chay nếu máy có sẵn thì ko cần cài.
C2Z patch C2ZMaker 1.0-authoring tools make it easy to create from their own patch C2Z - Fixed icon can not be displayed
Software:
This year, in order to highlight the character's own taste! ! !
C2Z is definitely a good thing (but that temper things a little child playing, and some models may be the phenomenon of death, if there is the best to remove it, after all, a stable cell phone to Wang!), He can let you modify many system things!
Q: What is C2Z patch?
A: The purpose of this patch is mandatory phone call until after Z, call C after the same document.
For example, if your phone are:
c: \ resource \ apps \ About.r01 this document (Note: r01 for the English language resource file)
Then it will be higher than the priority level
z: \ resource \ apps \ About.r01
This patch is very useful, Symbian system through deception, use your own system instead of the original paper document.
As the C disk file is readable + writable, so you can easily modify them (provided of course, has been pyronaridine XX)
There are many new patches, this patch needs the support of the advance, such as: the recent E → 3G icon changes * # 0000 # information, such as ah!
Usage:
Software interface is very simple, click inside the menu generation, will see a white interface, the first state to crack open, production will not be prompted to complete it seems. So later, such as (10s or so), by switching out the menu button to see the root directory of E did not
c2z.rmp documents has made it clear that if successful, then copy c2z.rmp to E: \ patches directory, open RomPatcher, applications can be used.
Special Description:
Before the operation is to restart the phone the best, and then open the crack, and then open the software to start production because if we do not this is the case, sometimes it causes to be made in part because of the patch can not be used with the computer side there is also this issue
Cách tắt tiếng chụp ảnh cho N73.
Cách này cũng được test thành công trong trên N82, N81, N95, 6120c, 5700. Dùng cách này chúng ta khỏi mắc công dùng cách của RomPatcher.
1. Mở "Caps Off", nếu dùng RomPatcher thì DisableCaps.
2. Mở X-plore
3. Vào "Z:\Private\10202be9\101F8809.txt"
4. Copy file trên vào "C:\Private\10202be9\101F8809.txt"
5. Edit file "101F8809.txt" bằng Xplore
6. Dòng cuối cùng của file có dạng
0x7 int 1 0 cap_rd=alwayspass
cap_wr=alwaysfail
7. Đổi thành như sau
0x7 int 0 0 cap_rd=alwayspass
cap_wr=alwaysfail
8. Save lại sau đó thoát X-plore
9. Mở "Caps On", nếu dùng RomPatcher thì EnableCaps.
10. Turn off "Warning tones" trong Profile đang sử dụng
11. Restart lại máy.
Tận hưởng đi nào :D
tôi dùng N73 ME làm đúng như vậy nhưng restart máy lại chụp vẫn có tiếng
VIP ơi là VIP, cho chút xíu hướng dẫn sử dụng trước khi dùng đi.
Copy vô đây nè C:/resource/app/.... sau đó khởi động lại coi hậu quả
P/S; Cỡ này Vip đua nhau đi xăm mình nhiều quá :O
tại sao không dùng 2 chương trình Change_Shutdown_image.zip & Shutdown Screens nhỉ?? và hình phải là ".mif"
Phải có tí hdsd thì mọi người mới bít chứ. Mà P520555 ơi, có nhạc nền khởi động không đấy?Chứ có hình nền mà vẫn ten tèn của nokia thì chán lắm.
ủa mà khởi động cái j ?? dùng ra sao?? nhìn cũnt đẹp nè
Tức là lúc khởi động lên nó sẽ thay thế cái hình khởi động mặc định của máy đó.Cách dùng thì xem links trích trên bài 1 nhé!!!
Bạn lên đầu trang dòng 5 và 6 có hướng dẫn chi tiêt cách thay đổi nhạc hiệu khởi động và hình tay nắm.Mod oi là mod.Đọc bài quản lí diễn đàn mà tìm hiểu chủ quan thế à =))
Cách này em thử trên máy N73 ME của em ngon lành, chạy nhanh hơn hẳn. Cách làm như sau:
Tạm dịch:
Download File đính kèm. Copy file MGXDatabasePlugin.rsc vào "C:\Resource\"101ffcd2.txt vào "C:\private\10202be9\", Sau đó khởi động lại máy.
Từ bây jo, chương trình nghe nhạc sẽ chỉ tìm bài hát trong thư mục "E:\sounds\" và Gallery chỉ quét tìm các file ảnh và video trong thư mục "E:\images\""E:\videos\" Vì vậy nên máy của bạn sẽ chạy nhanh như thỏ :p
Tuy nhiên, khi bạn đổi nhạc chuông trong profile, bạn cũng chỉ thấy nhạc chuông trong thư mục "E:\sounds\simple\".
Tác giả đã thử thành công với N95 8gb, N95-1, N82 và 1 vài máy điện thoại khác.
sao mình text trên N73 ko đc???
Patch: Disable Charger Notes
Patch này chép vào E:\Patches dùng để tắt các thông báo (tiếng chuông và đèn màn hình) khi bắt đầu sạc cũng như rút sạc ra khỏi máy. Ứng dụng chạy trên N78 nhé.
; *** Patch: Disable Charger Notes ***
; Author: wadowice
; Date: 18-Apr-09
; Disable notes shown when you:
; -connect the battery charger
; -disconnect the battery charger
; -battery is full
; Why to do it? Because the light and the beep wakes me at night.
; For N78
;SnR:sys\bin\sysap.exe:F8BDF8B504008034:F8BDF8B50400F8BD
; For N81
;SnR:sys\bin\sysap.exe:70B5040080340500:70B5040070BD0500
; For N82
;SnR:sys\bin\sysap.exe:70BD70B504008034:70BD70B5040070BD
; For N90
;SnR:sys\bin\sysap.exe:70BD70B504468034:70BD70B5044670BD
; For others
;SnR:sys\bin\sysap.exe:70B5044680340129:70B5044670BD0129
; For N95
; not possible because SysAp.exe not in ROM
; For N96, N78, 5800
SnR:sys\bin\sysap.exe:F8B5040080340600:F8B50400F8BD0600
Super 0 v1.0 [EN] translation by cupinthemud
Ứng dụng giúp tạo phím tắt cho một số ctrình thông dụng như TTPod, Kougu, Core Player, ...
Yêu cầu:
- Cài đủ bộ Python
- Máy đã hack
- Để cho mày truy cập ổ C trước, các bạn phải dùng Rompatcher apply patch C2Z và để chế độ Auto Apply
- Sau khi cài Restart lại máy
Change MenuCircle Cách thay đổi hình báo hiệu ứng dụng đang chạy ẩn
Các bạn vào Đây để xem hướng dẫn làm.Còn dưới này mình up thêm vài icon nữa cho các bạn lựa chọn.Dow về giải nén thích cái nào đổi tên thành Menu.mif rồi cóp vào C:/resource/apps/. rồi khởi động lại máy.
Cái này chính xác là patch để add phím số 0 thành phím tắt vào các PM ưa thích :) Chứ ko phải cho tất cả các phím đâu nhé, chỉ phím số 0 thôi :p
Patch: Reset On Power Long Press
Patch dùng cho RomPatcher giúp khởi động máy bằng cách nhấn giữ lâu nút nguồn (mặc định việc này là tắt máy)
File này dùng cho 5800, N78, N80, N81, N82, N90, N95 và N96.
; *** Patch: Reset On Power Long Press ***
; Author: wadowice
; Date: 18-Apr-09
; When you press the Power key for a long time, phone switch-off.
; This patch changes it: now phone reset and boot again.
; Selection PowerKey->SwitchOff is still the same.
; Why to do it? Because I need in my testing.
; N80, N81
;SnR:sys\bin\sysap.exe:002804D164220021:002804D164220121
; For N78
;SnR:sys\bin\sysap.exe:04D1421E00212800:04D1012164222800
; For N82
;SnR:sys\bin\sysap.exe:04D1642200213000:04D1642201213000
; For N90
;SnR:sys\bin\sysap.exe:04D1642200213006:04D1642201213006
; For N95
; For 5800
;SnR:sys\bin\sysap.exe:03D1421E2800FDF7:012164222800FDF7
; For N96
SnR:sys\bin\sysap.exe:002803D1421E2800:0020012164222800
Đây là cách cài game Ngage 2.0 trên các máy không được hỗ trợ.
Các máy phải được hack bằng CapsOn/CapsOff nhé. Và dành cho các máy có màn hình 240x320.
Mình chưa test vì máy mình là N95 có hỗ trợ cái này :D
Thực hiện như sau:
1. Install file cài đặt Ngage tại đây cùng với file autostart (file đính kèm)
Nó sẽ báo Symbian OS PIPS không được tìm thấy hay cái gì đó. Cứ nhấn để install đến Finish.
2. Install file pips_s60_1_2_SS (file đính kèm)
3. Bây giờ qua đây down 1 game nào đó về.
4. Copy file 20001079.txt vào c:\private\10202be9\ (file đính kèm)
5. Bật Caps on!!!
6. Install game bất kỳ rồi bắt đầu chơi nhé.
Tác giả đã test trên e65 , 5700xm, n73, n71, e51, 6110, 6210c
Chú ý: Với các máy cũng s60v3 nhưng màn hình khác 240x320 thì thử edit file 20001079.txt như bên dưới nhé, thay đổi các số màu đỏ theo màn hình máy bạn:
Mã:
0x00090002 string "nativewidth" 0
0x00090003 int [COLOR="Red"]240[/COLOR] 0
0x00090004 string "nativeheight" 0
0x00090005 int [COLOR="Red"]320[/COLOR] 0
Chúc các bạn may mắn! ;;)
em làm theo hướng dẫn mà sao khi cài nó game nó lại báo file is corrupted là ao nhỉ bác giúp em với
