Cách trở lại GB từ HC Update OTA cho Flyer
phamthaitl
Đã có rất nhiều cách trở lại trên diễn đàn này.nhưng tôi không làm đc theo cách nào cả.và sau bao ngày hì hục tìm tòi tôi đã trở về đc.theo cách này.
This procedure applies to both flyers and view
Required downloads
1. First download the Gingerbread RUU for your device from this thread.
2. If you don't have adb and fastboot on your PC
• Get fastboot and adb tool for windows here
• Get Fastboot and adb for linux here
• I don't have a simple bundde for Mac, would welcome a link if anyone has one.
3. Download my universal misc_version and unzip to obtain the misc_version file.
4. Download tacoroot
5. Place both the misc_version and tacoroot.bin files in the same directory as adb
Procedure
1. Check the version number for your gingerbread RUU
In my example I am using this RUU_Flyer_O2_DE_1.40.207.5_Radio_20.35.30.089BU_3809.04.04.21_M_release_188730_signed
The version is the part highlighted in red.
2. Boot your flyer up to android if it's not already on, with usb debugging enabled and connect it to the PC.
3. Run the following adb commands
Code:
adb push tacoroot.bin /data/local/
adb push misc_version /data/local/
adb shell chmod 755 /data/local/tacoroot.bin
adb shell chmod 755 /data/local/misc_version
adb shell /data/local/tacoroot.bin --setup
At this point your device will reboot to recovery
4. Simultaneously press Volume Up, Volume Down and Power
5. Reboot your device
6. Run the following command
Code:
adb shell /data/local/tacoroot.bin --root
Your device will reboot, do not worry if it does not boot fully, it doesn't matter for this procedure, and it is a side effect of this root exploit.
7. Run the following command:
Code:
adb shell /data/local/misc_version -s 1.40.207.5
Số màu đỏ phải thay theo số bản RUU của bạn.của mình là O2_DE nên có thong số 1.40.207.5
8. Reboot to fastboot:
Code:
adb reboot bootloader
9. Relock the bootloader:
Code:
fastboot oem lock
10. Go back to fastboot mode ( lock causes the device to reboot )
11. Run your RUU ( if on linux or mac, see other similar threads from me on how to RUU on those OSes )
Nguồn http://forum.xda-developers.com
bạn nào chưa làm đc hoặc thắc mắc khâu nào cứ hỏi mình biết xẽ chỉ giùm.
Chân thành cám ơn đến.
Manager PhamQuang
Moderator Venusian
Moderator AquaSta
đã nhiệt tình giúp đỡ trong thời gian vừa qua.
hi anh, sau khi trở lại GB thì làm theo các bước của bác Phạm Quang hả anh. Thanks
BẠN ƠI CHO MÌNH XIN LINK MẤY CÁI DƯỚI NÀY VỚI
Required downloads
Required downloads
ban muốn hạ về GB phải k. nếu vậy theo hướng dẫn của bác này là chuẩn nè mình cũng mới vừa hạ về, sau 3 ngày nhắm mắt làm rất ok
http://www.pdaviet.net/showthread.p...f-update-ota-hc-cai-rom-cook-hc-va-tro-lai-gb
Required downloads
HTML:
http://forum.xda-developers.com/showthread.php?t=1062184
HTML:
http://dl.xda-developers.com/attachdl/f546a9afaf5a16c7518e8028c0f26733/50791e1e/6/3/0/6/1/1/android-win-tools.zip
HTML:
http://cloud.github.com/downloads/hyuh/misc_version_universal/misc_version_universal.zip
HTML:
http://hyuh.net/files/tools/tacoroot.bin
Của bạn đây.
đúng rồi bạn.tất cả các hướng dẫn Man PhamQuang đã viết đầy đủ.:D
Hi anh phamthaitl, anh ơi, anh ở Tp.Hcm phải không ạ? Em làm hoài nhưng không được, anh có nhận làm giúp không, em mang máy sang nhờ anh giúp, em cám ơn trước.
mình ở đức cơ.mai bạn online mình chỉ cho.bạn xem máy của mình là xuất sứ ở đâu.tải rom gốc về và các bộ cài trước đi.
mình bị lỗi 132 khi up lại rom GB ship cho em nó, anh em nào khác phục được ko
Lỗi này là do up không đúng dòng rom gốc. Phải xác định máy mua ở nơi nào trên thế giới rồi tìm đúng dong rom đó là được.
Sent from my GT-P7500 using Tapatalk 2
