Mình thấy trên wiki đã có nhiều người thành công với cách cứu máy như sau:
(nếu ko hiểu cách làm thì pm cho mình)
Before you start, or while you are waiting for Platform Builder (PB) to download. It will take a while. What you want to have ready is to have SSPL_HERM.exe on your micro sd. You will need this for when you get the opportunity to actually use the file explorer to execute the program (SSPL_HERM.exe). I know it feels impossible. I know what you have gone through, but this should work. Also you need to be able to put the phone in KITL Mode. Apparently not all phones can, so chek it out before you start.
Following is a compilation of instructions from GBO and Soregg and a dash of me on getting your phone to work using the Microsoft Platform Builder.
Originally Posted by gbo
I've unbrick my phone!! Type 2 i think (stuck on windows screen).
I've used the superdave's method with Platform Builder. So, the steps:
- Download Windows CE 5.0 Trial Edition. It's a 2.6Mb file but others components will be downloaded during install (around 2 Gb for me, so be patient!). Choose to install ARMV4I processor platform (not the x86 selected by default).
1.
- Run Platform Builder, File menu -> New Platform
Select "SAMSUNG SMDK2410: ARMV4I"
Select emulator also.
Select Custom template and Finish. (forget the screen description)
- Build OS menu -> check "Copy files to release directory after build"
- Build OS menu -> check "Make run-time image after build"
2.
- Build OS menu -> Open Release Directory.
- reminder, the folder should be something like xxxx\RelDir\smdk2410_ARMV4I_Release
3.
- Before next step, Make sure in PB menu, Target>connectivity, download=emulator (set to 256MB and select "pda" as skin), transport=usb and debug=none
- In Platform Builder, Target menu -> Attach device
4.
- Build OS menu -> click "Build and Sysgen"
One more time, be patient, tyhe compilation may take 20min.
5.
After compilation successfull:
Copy ANY 3 DLL's from this directory and paste in another (i.e. your Desktop).
Rename them as stk_service.dll, ril.dll and rilgsm.dll
Copy the renamed DLL's back in the Release Directory
6.
- Target menu -> Release Directory Modules -> Add the 3 DLL's
7.
- Run your Hermes in KITL debug mode (COM MANAGER + POWER + RESET)
You most likely will recieve an error message telling you that you do not have enough ram. Just wait about ten seconds and it should start moving along.
- If it does not start after like twenty seconds then In
Platform Builder, Target menu -> Detach device
then keep the phone plugged in and reset it. after the reset go into KITL Mode again and
- Target menu -> Attach device - again and it should work. If not, repeat untill it does.
- For my case, I select target>detach device, "reboot pda to KITL" and target attach device, several time and finall my bricked pda boots up.
You will see after a couple of minutes that the phone will begin to wake up and come to life. Be patient. This is very important during the whole process.
you will see where it asks you to tap on screen to setup your phone. Do so. If no response just be Patient. It will slowly do so. Then you will see where it asks you to calibrate the screen and then to set the date and time. It really is of no use to set the time and date yet. just follow the prompts until you are done in the initial setup. For me I had to wait for the extended ROM to install.
_ After everything finishes installing try and see if the you can go through Start => Programs => File Explorer and activate SSPL_HERM.exe
KEEP THE PHONE PLUGGED IN !!!!!!!
I at this point I flashed the 1.18 HTC ROM - It installed, but still without the Radio. Still "No GSM". But it booted up and worked fine. Obviously the phone didn't work since there was no Radio installed.
The next thing I did was install the Radio.
Now you have to download a Radio Only Flash.
I used - 1.27.00.00 -
http://rapidshare.com/files/18091588...1.27.00.00.exe
Uh Oh! is that a 0% on the screen and the 1%? WOOHOO! You are on your way!!
It will take a while for the Radio to load. probably like 15-25 minutes.
After all this It should work.
I don't know if you have to reflash the ROM before installing the Radio. I did and it worked for me. I think that it might be best to do so.
I think even with the SSPL_HERM.exe you should use the original ROM that came with your Phone.
Good luck
Đây là 1 cách kha hay đấy chứ. Nếu ko load đc tool thì mình sẽ up lên, mình giữu nguyên lời của tác giả để ko bị sai lệch khi làm.
cảm ơn
