Cập nhật các phần mềm quản lý files S60v3
PadersyncFTP v1.0.9 J2ME -FTP client and file manager- (Update:17.08.09)
PM quản lý file và FTP client
23007d1250507180-padersyncftp-v1-0-9-j2me-ftp-client-file-manager-update-17-08-09-2nv7xqc.png
Xplore 1.34
Cập nhật ngày 02.09 nhưng tìm hoài ko biết fix gì :) Bản trial.
FExplorer Pro v2.00 Final S60v3 S60v5 Symbian9.x Sigend
Bản cập nhật
What is FExplorer Pro?
FExplorer Pro (FEP) is a utility suite for S60 phones and supports 3rd and 5th edition phones. The main feature is of course the astonishing file browser alongside various tools and options that you can use to better manage your phone in general.
File Browser
The file browser is very very extensive to give you complete control over your phone's file system.
It includes everything you will ever need from a file browser similar to Windows File Explorer or Total Commander (for Desktop).
Features include (but are not limited to):
* Searching for files on your phone.
* Creation/Renaming/Deletion of files and folders.
* Enter folders that can't be seen on the Nokia phone browser.
* Three types of file editors (Hex, Binary and Text)
* Attributes changes on files.
* Zip(!)
* Image viewer
And much, much more!
You will only grasp the myriad of options and features in this quaint application once you really start using it on a regular basis.
In addition to the file browser, there are two additional tabs in FExplorer Pro (which can be toggled on/off using the "5" k3y):
Tools
With these tools, you can have a lot of your favorite tools all in one place, and it replaces the need to use other 3rd party applications for each of the functions (for instance Screenshot)
I will give a short overview of what each of these tools does:
Screenshot- Similar to the Antony Pranata's Screenshot for S60, this tool allows you to create screenshots of your phone from anywhere on the phone with various options to handle file saving etc...
Backlight - This will turn your e-mail notification light on/off similar to Best Torch for S60. Very handy as it can turn your phone into a flashlight whenyou most need it Posted Image
Bluetooth manager - This is VERY handy also. It will turn your Bluetooth on/off with a click of a button.
Compress memory - de-fragments memory. You receive the memory available before and after the call to the function too.
Installed applications- more for developers - it generates a file (C:\INSTAPP.TXT) which contains all of the installed applications (by the application manager), their UID and their path.
Dump file list -generates a file (C:\FILESLST.TXT) containing the list of the files and the directory starting at the current position (current directory)
As I mentioned above, now that FExplorer Pro is modulated in this fashion,we will be adding more tools to this list as time passes, which will continuously enhance your FExplorer Pro Posted Image
Phone
More options that you have for your phone in FExplorer Pro are shown above.
Here is a short overview of what each function does:
Phone info - this will give you all of the details that can be obtained about your phone like firmware version, IMEI etc...
Restart - restarts the phone.
Network info - gives you all available information that can be obtained about your network like area id, cell id, network name etc...
Media info - gives you full stats on the installed memory card
note: Options regist3r Don,t Work. press continue
don,t expired
Phiên bản 1.35 cập nhật thêm tính năng xem trước tập tin hình ảnh dưới dạng 1 ảnh nhỏ bên trên tập tin.
Các bạn dùng License thì update lên nhé.
Lonely Cat Games X-plore v1.35 S60v3 S60v5 FULL-MTOi Iphone v2 Style : Nima79 for unhacked phones
PM quản lý file quen thuộc với iphone icons và cho máy chưa hack.
FExplorer v1.21 Beta S60v3 SymbianOS9.x Unsigned
Trình quản lý file quen thuộc bản cập nhật
Xplore 1.40
Bản cập nhật sửa 1 số lỗi nhỏ và thêm hiệu ứg chuyển cửa sổ cho S60v5. Bản trial.
Xplore 1.41
Fix vài lỗi nhỏ: lỗi khi nhấn nút # thành tương tự giữ nút viết chì... còn lại thì KJR ko biết lỗi gì :p
[DOWNLOAD]http://www.lonelycatgames.com/download/xplore/xplore_symbian_lcg_1_41.zip[/DOWNLOAD]​
