kienvp
ứng dụng đọc sách trên mobile
ZXStyles ZXReader v1.4.2 Beta 1 S60v5 SymbianOS9.4 Signed
Mã:
Features:
* Supported encoding: UNICODE, UTF-8, ANSI (WIN-1251);
* Automatic change of portrait / landscape mode when the phone turns;
* Fixing the desired orientation of the screen;
* Sensory management;
* Full Screen;
* Setting the font, including third-party ttf;
* Avto moving pages around;
* Office lighting - brightness is constant;
* Text - carry the words, bonding lines (cut into a line under a specific width before any editor)
* Splitting the screen into multiple active zones, each of which can hang some commands.[/CENTER]
[CENTER]Change Log :[/CENTER]
[CENTER]*Contents. Display the list of titles (title), select the title - go to the beginning.
*New command - Contents
*Fixed problem with hanging instructions on the joystick left and right
*Setting - which disk (c, e) to keep the library configuration, etc.
*Setting - added another set of buttons on the team - now the team can hang up to two buttons
*Fixed problem nerabochesti right soft after visiting imageviewer
*At the command list of links on the page if the page is only one picture - automatic transition to imageviewer
*Setting - the list of preferred character sets (to be used in addition to the library and by changing the encoding). Basically, the need for foreign users. By default encoding for selected users in Russia. The more the selected encoding, the greater the probability of error auto-detect when you add the file.
*At the lowest level of brightness is reduced step team brightness + / --
*Refined processing timer - to avoid triggering the lock, and other visual problems with avtolistanii
*Fixed change encoding fb2
*Modification and / liter. Settings: Time P / L, the size of a / l, type a / l (the page size, rotation). Page and size - as now. Replacement - next page down replaces the current page, a step change - the size of
*Changed charging indicator
*When a / l in infobare will indicate avtolistaniya (triangle pointing down)
*Setting the style for infobara (font, size, color, bold, italic)
*Customize content infobara (menu button, the current page, the number of pages per cent, and the icon / l, time, battery, progress)
*In fb2 not eaten the empty string (tag empty-line)
*For fb2 expanded information about the book - digitization, version history, author of the file
*Added style - Drop Cap. You can select the first letter of the section.
*When unpacking from the zip the resulting file is named: the archive name + file extension from the archive. To avoid kryakozyabov at the Russian name of the file in the archive
*Added two commands, as well as the menu item Go to - back and forth. As you move around the text, not by scrolling / paging, and by going to the page / rate / start / end / Head / search, etc., to remember the chain of transitions, and the team forward / backward - is the movement of the chain.
