Kojiro
Super V.I.P
Battleships - .swf game
Game đấu tàu chiến.
Bạn chép file .swf vào nơi nào bạn muốn trong thẻ.
Nhấp 2 lần file cần chơi để có thể chơi game. Tốt nhất nên chỉnh sang àmn hình ngang trước khi chơi, nếu chưa chỉnh thì có thể chỉnh khi chơi bằng cách chỉnh của trình chơi file .swf.
- Copy the flash file (swf) to anywhere you like to your memory card
- I don't know how to make shortcut to the application menu, so if you know, tell me, and make a shortcut for it. If you don't know either than you have to double click to the file in a browser to start the game. The best if you rotate the device in landscape screen before you start.
- If you started before rotation of the device, you can rotate the screen in the flashplayer menu. If you are in landscape mode, put it to fullscreen mode.
- Voila, you have a fullscreen-game to your 5800
- Unfortunately You cannot use the flashplayer menu in fullscreen mode you cannot change setting for the flash player or quit. But very simple method for quitting if you push the red button.
I hope this tutorial will help, and you will like the games!
I tested all, and found that if the flash-game is highly video oriented, it will be very slow.
