Note: This feature currently requires accessing the site using the built-in Safari browser.
Hiện tại trang web đang trong quá hình chuyển đổi và tái cấu trúc lại chuyên mục nên có thể một vài chức năng chưa hoàn thiện, một số bài viết và chuyên mục sẽ thay đổi. Nếu sự thay đổi này làm bạn phiền lòng, mong bạn thông cảm. Chúng tôi luôn hoan nghênh mọi ý kiến đóng góp để chúng tôi hoàn thiện và phát triển. Cảm ơn
Core OverHeat by DigitalWorks IA, 240x320 ML J2me (7 Mb)
Game đua xe. Đọc kỹ hướng dẫn bằng tiếng Anh nha!
Core OverHeat by DigitalWorks IA is a 3D Racing Game based on Java MicroEdition (MIDP:2.0,CLDC:1.1). After our first production "BurnIt 3D" we decided to create a new game better than previous fulled-in features and addictive GamePlay.So, we embedded all the features that a Racing-Games Lover needs in order to get bored ever.This time we have to encounter 9 Artificial Intelligent internal players, doing everything to get the first position from you. In the game Actions are realistics and are been written in a Log Report such as player's actions, in order to be able to watch in detail game's progress.In addition, the player has the ability to create 9 different Game-Progress Profiles, that if he wants to play a new game, he wont lose the progress of an older. In the end we dont forget to embed the choice MultiPlayer Over Bluetooth.The Player has also the ability to choose between 18 cars that are not available from the first side and 8 different Race-Areas A new feature, is the Remote-Play called as BlueJoy. So you can use a Java-Enabled Mobile to remote control the mobile device that Runs the game.So connecting the Mobile Device over TV-OUT on the Television and having the second Device as a Joystick you can better enjoy the game. Infos: With the main Game there is also a small program that called Blue-Joy Client. Install the BlueJoy in Mobile Device that you will use as a Joystick and run it. Enable the Bluetooth both of Devices, run Game to other Device and goto Configuration Menu enable the Blue-Joy that will be used from 8-15 seconds to be Connected with the other Mobile Device. If you will be asked by the Devices for Bluetooth connection you have to choice "Yes" both of them. When the Choice Blue-Joy shows CONNECTED, then you are ready to remote control the Game. So Lets Play. So Start a New Game, goto Car Dealers and buy a new car, Tune-it as much as you can and dont forget to save some money in order to be able to Join the Daily Race Events. After Race check for more Tune-Ups, Refuel your car with GAS & NOS if needed and then Join to Events again.You can also spectate other players while they play in an Event by two ways. First way watching the Race Event Specs and secondly watching 8 Cameras that cover all Race Area... Of course Games with these features especialy Java are RAM-Hungry so to Play Normal you must ensure that you have more than 18MB Free Memory. To do that close any running tasks and also disable the Active StandBy Icons from the settings Menu.A Second tip restart the phone and keep hold Pencil Button(Shift) while System Loading... Good Luck! In the End we Announce you that our Team is working hard in order to create the OnLine Version of Core OverHeat. Very soon you will be able to download the Core OverHeat Client and get connect to the Race-Server in order to play your favorite game against Real Players all over the World.
