Đã có bản Miui mới 26/1/2011 với rất nhiều thay đổi :
Changes:
Phone:
- Add Phone attribution new database, an increase of 7779, amended 6777 records.
- Add new to page number to jump to support sending SMS dialing
- Determine the optimal conditions for the optimization of flip mute
- Optimization of the number of dial-up points above the area, pop-up keyboard
- Optimization of light-sensitive dial / trackball selected sliding contact, will put away the keyboard
- Optimization in point # T9 dialing all the phone does not match
- Repair part of the Chinese characters spelling the wrong question turn
SMS:
- Add message dialog box called Select Edit Nickname
- Add text call the default read nickname information
- Add Click the bulk detailed list of a text message can appear
- Added support for editing commonly used language and the collection of
- Add some text emoticons can be compatible and interoperable NOKIA
- Add in the annex Canada recommended holiday message
- Add recommendation to increase SMS try their luck, random search
- Google sent to the wrong fix merge fixes contacts
- Google opens the wrong fix merge Thread, result in dislocation of the problems fixed message list
- Text messages sent in bulk after a repair does not automatically put away the keyboard and panel issues
- Fix hidden messages when offline, do not hide the problem of flying letters icon
- Message pop-up windows fixed input sometimes can not afford the problems related
- UI updates list of fixes when the message thread, the problem of data misalignment UI
- The content of SMS load thread repair the problem miss
- Select a recommended repair SMS text message -> Message -> Add a contact will only issue FC
- Repair Recommendation SMS forward / group sending, should remain in the SMS interface
- Optimization of the style into a back row SMS Zone
Contacts:
- Sync contacts or call history repair is modified when the call records continue to refresh, reset to the top of the problem
- Contact Birthday not Sync fix the problem
- Under repair Gtalk contact card name truncation
Desktop:
- Optimization of the transition animation to enhance the speed of the desktop scene
- Optimized to enhance the scroll speed folder
- Optimization of high-quality graphics to the lock screen wallpaper
- Optimization further optimize memory, so that large memory machines can have more desktop smooth
- Sometimes editing fixes do not see the preview of the desktop problems
- Control behavior than repair the problem of inconsistent music
- Fix icon name not updating
- More stability fixes the problem and reduce the occurrence of FC
Theme Manager:
- New Year special custom theme
- Fix or set from the desktop wallpaper can choose to modify the problem into the theme of the program
- Topical application of the theme can not fix the problem
- Fixed-line theme of the issue without prompting the download fails
- Fixed part of the local list does not display the default theme issue
- Repair some of the content of the preview page, showing the three points but only a Preview problem
- Content preview page title does not fix the problem correctly
- Repair after wallpaper change, the current wallpaper shows incorrect problem information
- Fix lock screen wallpaper to set the problem can not be selected region
- Unlimited prompt repair no network problem
- No fix due to FC network environment
- Fix theme does not work properly after the backup and recovery problems
- Preview repair online resources are displayed in the charting software in question
- Fix lock screen wallpaper preview of the issue to be stretched
- FC fixed into the font list
Gallery:
- Added support for gif animated, direct view in the picture full-screen view
- New setting item, you can set whether to support the playback gif, image size filter thresholds
- Modify the thumbnail cache file output stream is not caused by a large number of cache flush time loss bug
- Optimization of large-size picture rotation performance, save memory overhead.
Camera:
- Add interface optimization, modify parameters screen prompt icon, click the icon to directly modify options
- Add the volume keys zoom
- Edit Video capture interface
Tham khảo tại :
http://www.miui-dev.com/content.php?56-MIUI-DROP-1.1.26-ON-US
Tải về :
http://www.multiupload.com/2AJYKGR7AT
