CFW C6 ULTIMATE FULL-XMAS for 5233 RM-625 by NGVIETHOA
mấy lỗi kia mình ko rõ nhưng mình vẫn add dc C2Z mà , còn thay đổi eff liên tục ấy , bạn xem và làm lại cái c2z của bạn thử xem
vậy hả buồn thật!thanks để xem lại!
uhm.lỗi 2 phát.khó ghê.mới fix dc killme ,autoinstaller.chán thật
nhiều thứ lằng nhằng wwa.
anh thi xong rồi nhỉ thế thì cứ từ từ mà làm cho ngon hehe!:D
JAF version 1.98.66 beta5
Detected PKEY: 90007BF6
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.29.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Searching for default location of ini...
Checking path: \Products\\
No ini files found...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-625\
Checking path: \Products\RM-625\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_prd.rofs2.V15
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_001_000_U004.uda.fpsx
Detected P-KEY: 90007BF6
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
No write data, skiping write...
Sending RAW loader...
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting............PUBKEYS already sent...
........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 608, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_prd.rofs2.V15...
Erasing cmt zone 02E80000 - 09D5FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_21.1.102_001_000_U004.uda.fpsx...
Erasing cmt zone 09E60000 - 0F47FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: V ICPR72_10w21.3.1
08-09-10
RM-625
(c) Nokia
APESW: V 21.1.102
VariantSW: V 21.1.102
Prodcode: 0597963
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 5 seconds...
Done!
Done!
được rùi.vào xem themee đã.log on rùi.ha ha
hoan hô.mình phục mình wa.
làm dc rùi anh em ạ.tinh chỉnh lại chút rùi up thôi.
up nhanh nhé đại ca để test luôn nhớ sửa lại cái vụ giảm sáng màn hình từ từ và tắt quay ngang mở khóa để tránh lỗi nhé :D
PRESS POWER ON NOW!
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
08-09-10
RM-625
(c) Nokia
APESW: V 21.1.102
Prodcode: 0597963
Done!
Done!
really spam!=))
up đê up đê up đê. Mà sắp up bản nào vậy. Bản mới này có gì ưu việt hơn những bản trước? Nếu có thể được thì giảm được bao nhiêu cái thừa ít khi dùng thì cứ giảm hết! Mấy cái theme thừa xấu xấu bỏ hết! Qua 1 ngày mình thấy bản XMAS này RAM tốt, hơn 60M free khi mình ko làm gì! Ngang ngửa photon!!
trật tự đi làm nhanh vội rồi lại bị thiếu sót này nọ anh đấy mệt thêm cứ từ từ anh ƠI!:D
kiếm 1 bản ổn định rồi dùng luôn, cài miết hư hết máy
ĐÚNG ĐÓA! hư thì ko hư đc!nhưng lỗi nhỏ nhặt vô đâu mất công mất uy tín vs các mod đó!!:p
đây nè
ảnh em nó nè.mod dc òi.
Up em nó đi ngviethoa, đừng để mai là mất nóng bỏng! SO THANKS!
theme moody đẹp lắm! Mình toàn xài nó thôi!
May quá! Vừa nãy ko thấy bác trong list, tưởng mai mới có rồi! Đùng 1 cái tung 2 cái screen ra! Bác thấy bao giờ ổn nhất thì up cho đỡ phải flash nhiều!
