Check IMEI cho Nokia.
Bạn check giùm mình IMEI: 358633010530034. Cám ơn nhiều
Serial number:358633010530034
Warranty:YES
Care Services:
Warranty Class:
Product Type:RM-208
Handset:E65
Product Code:0515712
End of Warranty:15-05-2009
Sold-to Country:VN-VIET NAM
Factory SimLock:N
Swap information: 03-10-2008 Customer Demand 353263017207363
Oa, bác này đc đổi main, sướng vãi...
chekl dùm mình xem :356790023478544
Serial number:356790023478544
Warranty:YES
Care Services:
Warranty Class:
Product Type:RH-99
Handset:1200
Product Code:0546885
End of Warranty:15-12-2009
Factory SimLock:N
Hix, nhìn cái nick này quen quen.
Check giùm mình tí nha: 356994015265113
Serial number:356994015265113
Warranty:YES
Care Services:
Warranty Class:
Product Type:RM-223
Handset:N81
Product Code:0550094
End of Warranty:02-10-2009
Factory SimLock:N
Bác bớt chút thời gian kiểm tra hộ em con này với IME:358984010070517
Serial number: 358984010070517
Warranty: YES
Care Services:
Warranty Class:
Product Type: RM-313
Handset: N82
Product Code: 0551541
End of Warranty: 20-02-2009
Sold-to Country: VN-VIET NAM
Factory SimLock: N
Repair information
01-09-2008 5202 V9000 Repair handling
04-09-2008 5202 X4402 5469313 Electrically faulty component
08-09-2008 5201 V9000 Repair handling
Online Software Update Attempt History
05 Apr 2008 10:46:04 Nokia Software Updater - NSU Aborted by user User aborted variant package download (24) NA 11.0.117
05 Apr 2008 02:49:05 Nokia Software Updater - NSU Aborted by user User aborted variant package download (24) NA 11.0.117
16 Apr 2008 05:08:39 Nokia Software Updater - NSU Aborted by user User aborted from the Connect Charger dialog (21) NA 20.0.062
16 Apr 2008 05:10:06 Nokia Software Updater - NSU Aborted by user User aborted from the Connect Charger dialog (21) NA 20.0.062
16 Apr 2008 10:15:23 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
16 Apr 2008 10:17:38 Nokia Software Updater - NSU Aborted by user User aborted from the check normal mode dialog (55) NA 20.0.062
16 Apr 2008 11:41:17 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
16 Apr 2008 11:44:40 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
17 Apr 2008 08:45:28 Nokia Software Updater - NSU Aborted by user User aborted from the check normal mode dialog (55) NA 20.0.062
17 Apr 2008 08:46:30 Nokia Software Updater - NSU Aborted by user User aborted from the check normal mode dialog (55) NA 20.0.062
17 Apr 2008 09:09:05 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
18 Apr 2008 10:25:09 Nokia Software Updater - NSU Aborted by user User aborted from the Connect Charger dialog (21) NA 20.0.062
25 Apr 2008 07:17:40 Nokia Software Updater - NSU Aborted by user User aborted variant package download (24) NA 20.0.062
25 Apr 2008 08:42:26 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
08 May 2008 09:59:55 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
19 Jul 2008 06:36:27 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
21 Jul 2008 07:12:39 Nokia Software Updater - NSU Aborted by user User aborted firmware update from the Simple Connection lost dialog (151) 10.0.046 20.0.062
21 Jul 2008 07:56:33 Nokia Software Updater - NSU Failed update attempt User aborted from the updating software failed dialog (43) 10.0.046 20.0.062
24 Sep 2008 07:28:43 Nokia Software Updater - NSU Aborted by user User aborted variant package download (24) NA 30.0.019
24 Sep 2008 07:42:31 Nokia Software Updater - NSU Aborted by user User aborted variant package download (24) NA 30.0.019
24 Sep 2008 08:09:02 Nokia Software Updater - NSU Aborted by user User aborted firmware update from the Connection lost dialog (SIM and Normal mode) 20.0.062 30.0.019
24 Sep 2008 08:18:05 Nokia Software Updater - NSU Successful update Firmware update successful (46) 20.0.062 30.0.019
Warranty: YES
Care Services:
Warranty Class:
Handset: N82
Factory SimLock: N
Repair information
Ối sao của mình nó dài vậy hả......giải thích dùm mình tý.thank you
Check hộ mình với, mình muốn xem thông tin của con N82 của minh! Thanks bạn nhiều nhé: 358984010887084
bác check hộ em imei này với 354855024479700 thanks u bác nhiều!
Serial number:354855024479700
Warranty:YES
Care Services:
Warranty Class:
Product Type:RM-346
Handset:E71
Product Code:0561926
End of Warranty:11-12-2009
Factory SimLock:N
Serial number:358984010887084
Warranty:YES
Care Services:
Warranty Class:
Product Type:RM-313
Handset:N82
Product Code:0551541
End of Warranty:11-03-2009
Factory SimLock:N
Nokia Software Updater - NSU: 04 Oct 2008 03:17:05 Firmware update successful 10.0.046 30.0.019
máy này hình như đợt trc check ở đâu rồi thì phải.:D
bạn check ho minh số imei 353641015478500
Serial number:353641015478500
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-133
Handset:N73
Product Code:0539354
End of Warranty:21-06-2008
Factory SimLock:N
Mới sắm em 6600 nhờ bác Linh check hộ nhé
IMEI: 353766007924748
Serial number: 353766007924748
Warranty: NO
Care Services:
Warranty Class:
Product Type: NHL-10
Handset: 6600
Product Code: 0514017
End of Warranty:
Sold-to Country: TH-THAILAND
Factory SimLock: N
Nhờ bạn Linh kiểm tra con O2 này cho mình với Thanks:|
IMEI: 357553006000845
Bạn xem lại tiêu đề nhé, ở đây chỉ check dòng máy Nokia thôi. Bạn chịu khó tìm thông tin ở chỗ khác.
Bác check hộ em con n70 này với.imeil của em nó là :351863016642668
thank trứoc nha
Serial number:351863016642668
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-84
Handset:N70
Product Code:0539276
End of Warranty:13-06-2008
Factory SimLock:N
Repair information: 12-06-2007 Mechanical faulty component
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-84
Handset:N70
Factory SimLock:N
bac cho em hỏi.con này hết bảo hành rui à.nó dã di bao hành lần nào chưa.thank! tiện thể bác check luôn hộ em con này nha: 359738008655187
Serial number: 359738008655187
Warranty: NO
Care Services:
Warranty Class:
Product Type: RM-133
Handset: N73
Product Code: 0529795
End of Warranty:
Sold-to Country: UA-UKRAINE
Factory SimLock: N
19 Feb 2008 04:09:19 Nokia Software Updater - NSU Aborted by user User aborted from the Connect Charger dialog (21) NA 4.0735.3.0.2
19 Feb 2008 05:01:53 Nokia Software Updater - NSU Successful update Firmware update successful (46) V 3.0638.0.0.30 4.0735.3.0.2
20 Feb 2008 05:44:13 Nokia Software Updater - NSU Successful update Firmware update successful (46) V 4.0735.3.0.2 4.0736.3.2.1 0539343
22 Feb 2008 08:18:00 Nokia Software Updater - NSU Successful update Firmware update successful (46) V 4.0736.3.2.1 4.0736.3.2.1 0539354
06 Mar 2008 02:15:07 Nokia Software Updater - NSU Aborted by user User aborted firmware update from the Connection lost dialog (SIM and Normal mode) V 4.0736.3.2.1 4.0736.3.2.1 0539239
06 Mar 2008 02:23:51 Nokia Software Updater - NSU Successful update Firmware update successful (46) V 4.0736.3.2.1 4.0736.3.2.1 0539239
02 May 2008 09:57:55 Nokia Software Updater - NSU Aborted by user User aborted variant package download (24) NA 4.0736.3.2.1 0539354
14 May 2008 07:59:58 Nokia Software Updater - NSU Aborted by user User aborted firmware update from the Connection lost dialog (Battery and Charger) NA 4.0812.4.2.1 0539354
14 May 2008 09:03:40 Nokia Software Updater - NSU Successful update Firmware update successful (46) V 4.0736.3.2.1 4.0812.4.2.1 0539354
08 Oct 2008 04:49:01 Nokia Software Updater - NSU Successful update Firmware update successful (46) V 4.0812.4.2.1 4.0812.4.2.1 0537289
