Check IMEI cho Nokia.
IMEI của em : 351886013468258
Serial number:351886013468258
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-57
Handset:6681
Product Code:0536412
End of Warranty:19-03-2008
Sold-to Country:VN-VIET NAM
Factory SimLock:N
IMEI của mình : 354855027778389
Cám ơn bạn trước!
Serial number:354855027778389
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-346
Handset:E71
Product Code:0560637
End of Warranty:
Sold-to Country:SG-SINGAPORE
Factory SimLock:N
check dùm mình cái :D
358984017641294
Serial number:358984017641294
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-313
Handset:N82
Product Code:0566177
End of Warranty:
Sold-to Country:MY-MALAYSIA
Factory SimLock:N
:D
Check giúp mình nhé.
359542017831775
Serial number:359542017831775
Warranty:YES
Care Services:
Warranty Class:
Product Type:RM-320
Handset:N95 8GB
Product Code:0550457
End of Warranty:12-12-2009
Factory SimLock:N
Nokia Software Updater - NSU: Nokia Software Updater - NSU Firmware update successful (46) 20.0.016 30.0.018
check hộ mình kon vợ này nhé:
351851016430705
thanks
Serial number:351851016430705
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-133
Handset:N73
Product Code:0529821
End of Warranty:29-02-2008
Factory SimLock:N
358984012732775
Serial number:358984012732775
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-313
Handset:N82
Product Code:0561054
End of Warranty:
Sold-to Country:KH-CAMBODIA
Factory SimLock:N
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-313
Handset:N82
End of Warranty:
Factory SimLock:N
:D
Thanks bạn nhìu :D
mà nó ra như thế thì nghĩa là thế nào vậy bạn? Có ổn ko? Nó là hàng xách tay :D
Serial number:358984011422824
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-313
Handset:N82
Product Code:0551534
End of Warranty:
Sold-to Country:AU-AUSTRALIA
Factory SimLock:N
Bro ơi, cách check này có đúng không vậy?
Máy mình mua chính hãng ở Viễn Thông A, vẫn còn bảo hành đến 30/05/2009 mà.
Kiểm tra lại giúp mình lần nữa nha. Thanks!
Bảo hành thì chắc Viễn Thông Á bảo hành cho bạn thôi chứ Nokia Việt Nam không bảo hành đâu, máy bạn là hàng xách tay mà :D
xin lỗi lại làm phiền bạn nhưng máy m mua lại, người ta cho cái thẻ bh còn hạn đến 28/2/2009. vậy bạn có thể check lại cho m k? hay là mình đã mua phải máy lm giả thẻ bh?
MMMMM number:351851016430705
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-133
Handset:N73
Factory SimLock:N
thanks bạn nhiều.
thanks bạn nhiều.
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-133
Handset:N73
Factory SimLock:N
Thời hạn bảo hành tới 29-02-2008 thôi bạn :D Bị lừa đưa thẻ dỏm rồi :( Xem lại trên thẻ số IMEI có trùng với IMEI của máy không?
Nokia thường ko có hàng nào gọi là hàng "xách tay" hay "hàng ngoài" cả.Chỉ có hàng công ty của nước này hay nước khác thôi. Điều quan trọng là máy dùng có tốt ko? Máy có nguyên bản ko thôi.
Đối với mình 1 cái máy tốt là máy nguyên bản chưa sửa chữa, mọi chức năng sử dụng tốt và bền.
Mọi số imei mình đã check ở trên đều ở server của Nokia Care nên các bạn đừng lo nhầm nhọt gì cả.
IMEI của mình : 358984010881285
Cám ơn bạn trước!
Serial number:358984010881285
Warranty:YES
Care Services:
Warranty Class:
Product Type:RM-313
Handset:N82
Product Code:0551541
End of Warranty:12-03-2009
Factory SimLock:N
02 Jun 2008 03:13:07 User aborted from the Connect Charger dialog (21) 20.0.062
02 Jun 2008 07:16:34 Firmware update successful (46) 10.0.046 20.0.062
27 Jun 2008 12:29:23 Firmware update successful (46) 20.0.062
23 Sep 2008 02:17:57 User aborted firmware update from the Simple Connection lost dialog (151) 20.0.062 30.0.019
23 Sep 2008 06:32:10 Firmware update successful (46) 20.0.062 30.0.019
29 Sep 2008 11:07:44 Firmware update successful (46) 30.0.019
27 Nov 2008 08:46:44 Firmware update successful (46) 30.0.019
imei của minh bạn check hộ nhé, thank
n95 8gb: 359542018077253
Serial number:359542018077253
Warranty:NO
Care Services:
Warranty Class:
Product Type:RM-320
Handset:N95 8GB
Product Code:0557645
End of Warranty:
Factory SimLock:N
buồn quá! Thẻ trùng số Imei, mình cũng k gà lắm về ĐT mà k ngờ bị lừa quả đau. Rút kinh nghiệm cho mọi người mún mua máy cũ còn bh thì xem máy, ghi lại Imei rồi lên nhờ ae check---> an toàn. Bùn quá, nó chém của e 3t2 liền các bác ạ.
xin lỗi vì mình hỏi câu này trong đây,
mình muốn hỏi một chút về N79, mình định mang N79 về VN dùng và muốn chuyển qua code dành cho VN (hiện đang là EURO 3), điều mà mình muốn hỏi là nếu chuyển qua code VN thì có tiếng việt trong đó ko?
và nếu có thể thì cho mình xin luôn code của VN nhé, mình tìm thấy code 0568145, nhưng mà khi tìm trên nokia thì nó báo ko tìm thấy code này
thx much and sorry
thx much and sorry
Bạn vào ĐÂY xem nhé!:D
