cho hỏi về RAZER PRO TONE m250 & koss ksc35?
xichdethien
RAZER PRO TONE m250 & koss ksc35 cả 2 có giá tiền đều ngang nhau nhưng xin ý kiến thì nên mua cái nào ,mục đích mình dùng là cho máy PSP .cám ơn
Cái Koss đã được khẳng định từ lâu. Razer thì chưa nghe thấy cái nào có tiếng tăm cả. Tuy nhiên, chưa chắc PSP 'kéo' nổi 2 cái tai nghe trên.
sao PSP lại kéo 0 nổi 2 cái clip on đó?
Pro|Tone m250 Street-Style Clip Earphones. Rubber-coated clip arms combine with high quality metal casings for an aerodynamic secure fit. Ultimate in style, comfort & portability. Solid clips ensure a firm grip during active usage. With light & compact construction, the sleek metal discs cling effortlessly to the curvature of the ears. Powered by Razer s own ProBass Technology. protone m250 send out deeply enhanced bass specifically engineered for digital players. Providing greater sound output and a more accurate music reproduction. Noise isolation is further maximized through ergonomic design. Custom-designed carrying case. Includes a jet-set adaptor for air travel providing total convenience in storage and portability.
Pro|Solutions Pro|Tone™ m250
  • Street-Style Clip Earphones
  • Rubber-coated clip arms combine with high quality metal casings for an aerodynamic secure fit
  • Ultimate in style, comfort & portability. Solid clips ensure a firm grip during active usage
  • With light & compact construction, the sleek metal discs cling effortlessly to the curvature of the ears
  • Powered by Razer’s own ProBass™ Technology
  • protone™ m250 send out deeply enhanced bass specifically engineered for digital players
  • Providing greater sound output and a more accurate music reproduction
  • Noise isolation is further maximized through ergonomic design
  • Custom-designed carrying case
  • Includes a jet-set adaptor for air travel providing total convenience in storage and portability
Razer Pro|Tone m250 Street-Style Clip Earphones.(Có 2 màu, hoặc Đen hoặc Trắng)
Giá: 46$
Bảo hành 6 tháng
Xem chi tiết
Vừa có hàng
Pro|Solutions Pro|Tone™ m250 Technical Specifications
  • Frequency Response: 50 ~ 20,000Hz
  • Dynamic Transducer
  • Impedance: 32 ohms
  • Max Sound Pressure Level (SPL): 105dB
  • Cable Length: 1.15/ 3.77ft
  • 3.5mm connector plug
  • Max Power Rating 50mW
  • Weight 38g (with cable)
Công ty SVHouse
Nhà Phân Phối Các sản phẩm của Hãng Logitech - Altec Lansing - Edifier
Đại lý : LCD - Laptop - Samsung - DELL - Acer - COMPAQ - LG - ViewSonic ..
Phân Phối Máy nghe nhạc Ipod – Apple
Liên Hệ: Hoàng Công Doãn
ĐT: 7710132 –7710151-0983983237
Đ/chỉ: 156 Ngọc Khánh – Ba Đình – Hà Nội
Email: doan_svhouse@yahoo.com
Yahoo ID: doan_svhouse
Website :www.loa.com.vn
Liên hệ trực tiếp để được tư vấn và ưu đãi về giá
Giao hàng tận nơi trong toàn quốc
Mình thấy bác nên dùng koss hay hơn, nếu bác muốn nghe thử và biết thêm thông tin về koss thì có thể liên lạc koolaudio
Tiếng tăm của Razer rất nổi tiếng đó bác ah,nhưng nó trong lĩnh vực game,em thấy m250 nghe được đấy
Koss kcs35 là huyền thoại trong giới clip-on mà. Chưa có cái clip on nào có thể so sáng với KCS 35, nên theo mình bác cứ chọn Kcs35 khỏi lăng tăng những hiệu khác.
sao nhiều người khen koss35 vậy nhỉ,mình nghe nó có ra j đâu,nghe chay thì đúng là ghẻ vô đối,nghe với ehadamp thì còn tạm đc .
bạn nên nghe thử, và sờ thử để cảm nhận độ " Chất " của sản phẩm
cái koss 35 thì thấy nghe nhạc cũng ok lắm, con kia thì chưa thử nhưng giá con 35 hình như khoảng 1,1-1,3 t hay sao đó
Koss hiện đã ngừng sản xuất KSC35, KSC35 hiện giờ trên thị trường có số lượng khá hiếm.
PortaPro có chất âm tương tự KSC35, nhưng PortaPro là kiểu đeo headband vòng qua đầu còn KSC35 là kiểu đeo clip-on móc quanh vành tai ngoài nên âm có phần thoáng hơn PortaPro, nếu bro kiếm được cái clip của KSC35 hoặc clip tương tự thì PortaPro lúc này sẽ tương đương KSC35 :).
Razer là hãng chuyên về các thiết bị game, các sản phẩm tai nghe của họ cũng rất tốt nhưng có tỉ lệ giá thành/hiệu năng không tốt lắm vì giá thành của các sản phẩm tai nghe Razer chủ yếu đội lên cao do có phụ kiện nhiều và thiết kế đẹp.
Khi bro xài KSC35 hoặc PortaPro và các tai nghe kháng trở cao (đa phần trên 60ohm hoặc thiểu số các tai nghe "khó kéo" khác) với PSP thì nên sắm thêm HeadAmp :)
Mới mua con KSC Sportapro nghe kg kém con KSC35 tí nào, hàng nguyên hộp có bảo hành nhìn đỡ chán hơn con KSC quá bèo nhèo về hình thức.
Gì mà Huyền thoại bác ơi.Dòng nào cũng có vài em nổi trội mà.hic bác quảng bá hơi quá lời rui
Bác mua nghe thử thì sẽ biết thôi mà, có ai tự khen cái gì quá đâu. Koss KSC35 tạo ra được thứ âm thanh đầy đặn và giá rất ‘hời’ trong làng tai nghe.
