CHỦ ĐỀ: CÁC PHẦN MỀM HỖ TRỢ KẾT NỐI WIFI TRÊN PPC
Em hỏi các bác chút: Sau khi em cài : SocketCom WiFi Companion v2.10.4.0
Sau đó em không xài nữa, và đã xóa đi, bây giờ vào WiFi lại không được nữa. ?? bây giờ làm sao các bác ?
Bạn nói rõ không dùng được là sao?Có thể Soft này cần phải Remove hết cả Registry của nó đi nữa.Nếu thế thì bạn nên cài soft SkTool vào,rồi cài lại soft SocketWifi,rồi vào SkTool Remove lại cho sạch hết các Reg xem sao nhé.Thân!
WiFiFoFum
không biết cái này các bác có chưa nửa.nếu có rồi thì xóa dùng em bài này nha.thanks admin
WiFiFoFum v2.2.8
REQUIREMENT :
PC 2003 and Windows Mobile 5 Pocket PC
OVERVIEW :
This is the latest version of WiFiFoFum - the best WiFi scanner and war driving software for Pocket PC 2003 and Windows Mobile 5 Pocket PC and Smartphone editions.
This version makes use of the latest features of .NET CF to give you the highest performance for war driving. With this version you can be confident your GPS logged coordinates for the networks you find are highly accurate, and can rely on a smooth user interface experience.
There is a PC msi installer which will install WiFiFoFum and the Compact Framework 2.0 SP2 into your ActiveSync so you can install and uninstall from your device as you please. Alternatively you can use the CAB version of WiFiFoFum which you can install directly on your device, however you will need to make sure you also have CF 2.0 installed aswell. WM6 has CF 2.0 SP2 built in so it won't be installed again onto WM6 devices.
Features:
List view showing information such was WEP, SSID, MAC, signal strength(RSSI), latitude, longitude and location precision (HDOP)
Radar view conveys distance to access points
Save, load and merge XML files
Export to Google Earth (KLM), text, Wi-scan, Tom Tom POI, MemoryMap and Netstumbler (ns1) formats
Choose between Pocket PC 2003 toolbar or WM5 soft button look and feel
Aggressive scanning mode to find even more access points
New network found pop up blocker
Supports all wired and bluetooth GPS devices that use the NMEA protocol
Compatible with every WiFi card and Pocket PC device available (C-Guys SD card users need to use the NDIS compatible driver)
Scan filters for WEP and ad hoc networks
http://www.4shared.com/file/14620937/7f1eeb6a/WiFiFoFumInstaller.html
(Nguồn của katnaper )
Airscanner Mobile Sniffer v2.5
Phần mềm hỗ trợ các kết nối Wifi trên PPC đã được giới thiệu ra phiên bản mới 2.5.
- Có các phiên bản dành riêng cho các hệ điều hành.
- Tham khảo tại đây.
Anh PhamQuang ơi, em cài cái wifi compagnon trên nền WM2006, wifi lúc có lúc kô, em muốn uninstall kô được, anh có chương trình nào đặc biệt để uninstall thì giới thiệu cho em và mọi người với.
Cám ơn anh
Cám ơn anh
wifi lúc có lúc ko là do sóng chứ đâu phải do phần mềm bạn, nếu bạn muốn remove nó một cách triệt để thì bạn dùng SKTools đi nhé, rất hay đó! :D
Pocketfleet PFScan v1.0
Phần mềm hỗ trợ tìm dễ dàng tìm kiếm mạng Wifi hơn Pocketfleet PFScan phiên bản v1.0.
- Hỗ trợ các hệ điều hành.
Có cách nào để chuyển WIFI của Atom sang chuẩn G không vậy anh em?
Muốn chỉnh cái này tạm thời có cách là chỉnh sửa Reg, tuy nhiên mới thấy có đề cập tới UNI còn các dòng khác thì chưa nói đến, bạn thử sang chuyên đề tìm hiểu về chỉnh sửa Reg xem sao.
Atom theo mình biết thì chỉ có cách làm cho nó support chuẩn G thôi chứ ko chyển sang wifi chuẩn G được, bằng cách dùng SKTools, vào Tune Up>Network, mục WLAN 802.11G support bạn chọn Yes là xong !
Phần mềm này k cần vừng mè gì hả bác, em vào about vẫn thấy báo là unregister.Chạy đc 1 lúc thì nó báo expried time, rõ chán
có chương trình nào dò pas của máy wifi khác k mấy bác ^^
Ko có phần mềm nào c thể làm được việc này trên PPC đâu bạn, dò pass trên laptop còn chưa chắc đã được, vì phải trao đổi một lượng dữ liệu lên tới vài chục GB thì mới mong dò được, nhưng còn tùy vào trình độ hack và một chút may mắn nữa! Do đó làm việc này trên PPC là hòan tòan ko khả thi!
PeekPocket v1.1
Ứng dụng hỗ trợ scan sóng wifi. Đặc biệt là miễn phí, không cần cài đặt. Chép file exe vào thẻ là chạy luôn.
Hỗ trợ các Hệ điều hành và màn hình.
PeekPocket v1.2
Ứng dụng hỗ trợ scan sóng wifi phiên bản mới(bản 1.1 được giới thiệu bởi TM Oxi.Không cần cài đặt,chép file exe vào thẻ là chạy luôn.Hỗ trợ các Hệ điều hành và màn hình.
Pocketfleet PFScan v1.1.3
Phần mềm giúp bạn dễ dàng tìm kiếm các mạng Wifi ở xung quanh bạn. Phiên bản tiếp theo v1.1.3 fix lỗi và cập nhật chức năng.
Hỗ trợ các HDH
Cài đặt và ĐK với s/n đi kèm.
Makayama Pocket Wi-Fi Radar v1.0
Phần mềm mới hỗ trợ tìm và kết nối Wifi cực mạnh. Được quảng cáo là hiện chính xác vị trí điểm Wifi qua màn hình Rada
Hỗ trợ mọi HĐH.
Tham khảo thêm tại đây
Hỗ trợ mọi HĐH.
Mod ơi, không hiện chính xác vị trí / hướng của access point đâu. Cái màn hình radar đó để cho vui thôi. ít ra thì cũng để thể hiện cục nào sóng yếu (xa) mạnh (gần). Chứ mod cài vào, đứng 1 chỗ, xoay 1/2 vòng xem, cái chấm nó cũng đâu có xoay! Chỉnh lại cho anh em khỏi nhầm nha.
Devicescape 1.1.32
Devicescape là một phần mềm miễn phí cho phép smartphone hay PDA tự động kết nối đến Wi-Fi hotspots và mạng tại nhà mà không cần khởi động trình duyệt, vào usernames và passwords,hay là mất công để cài đặt bảo vệ. Chỉ cần bật Wifi và bạn sẽ kết nối Internet hay download,e-mail trong thời gian ngắn.
Hỗ trợ Windows Mobile 5.x/6.x
Đây là phần mềm mình sưu tầm,hay dở gì thì các bạn download,test rồi cho ý kiến nha.Thấy hay làm ơn click THANKS!
DOWNLOAD HERE
HOẶC
ĐÂY
