CHUYÊN ĐỀ: PHẦN MỀM BẢN ĐỒ IGO
mình dang dùng i GO8 nhưng chỉ có bản đồ EU thôi.không có ở VN.bạn nào ở EU cần thì mình gửi cho.chạy ngon trên các hệ Wm 6.1 6.5 mình đang chạy trên i900.GPS navigace ngon ơ.dung lượng 1.5Gb.
em dùng x1, và đang ở Thụy Điển, em hay phải đi tới các nước Cz, Na uy, Đức, Đan mạch. anh có thể cho em xin cả igo và bản đồ cho những nước này được không. Díky!
toàn thấy giới thiệu cho vui, chẳng thấy link đâu. :(
Bạn tải về dùng nhé: :))
(dùng cho iGO 8.3.x a 8.4.x)
http://rapidshare.com/files/278992471/CzechRep83_TA_2009.06_090722.fbl
http://rapidshare.com/files/279222250/CzechRep83Ceda_2009.06_090730.fbl
http://rapidshare.com/files/279300075/Albania83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188095/Andorra83TA_2009.06_090722.fbl
http://rapidshare.com/files/278876252/Austria83_2009.06_090711_TA.fbl
http://rapidshare.com/files/279300060/Belarus83TA_2009.06_090722.fbl
http://rapidshare.com/files/279202139/Belgium83TA_2009.06_090722.fbl
http://rapidshare.com/files/279300037/BosniaHrz83TA_2009.06_090722.fbl
http://rapidshare.com/files/279190032/BosniaHrz83Navigo_2009.06_090730.fbl
http://rapidshare.com/files/279300017/Bulgaria83TA_2009.06_090722.fbl
http://rapidshare.com/files/279191471/Bulgaria83MMCM_2009.06_090730.fbl
http://rapidshare.com/files/279299691/Croatia83TA_2009.06_090722.fbl
http://rapidshare.com/files/279190739/Croatia83Navigo_2009.06_090730.fbl
http://rapidshare.com/files/279188981/Cyprus83Epsilon_2009.06_090730.fbl
http://rapidshare.com/files/279199041/Denmark83TA_2009.06_090722.fbl
http://rapidshare.com/files/279299460/Estonia83TA_2009.06_090722.fbl
http://rapidshare.com/files/279196075/Estonia83Regio_2009.06_090730.fbl
http://rapidshare.com/files/279233902/Finland83TA_2009.06_090722.fbl
http://rapidshare.com/files/279723622/France83TA_2009.06_090722.fbl
http://rapidshare.com/files/279707942/Germany83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188052/Gibraltar83TA_2009.06_090722.fbl
http://rapidshare.com/files/279299043/Greece83TA_2009.06_090722.fbl
http://rapidshare.com/files/279219700/Greece83Epsilon_2009.06_090730.fbl
http://rapidshare.com/files/279297592/Hungary83TA_2009.06_090722.fbl
http://rapidshare.com/files/279200571/Hungary83TopMap_2009.06_090811.fbl
http://rapidshare.com/files/279193599/Ireland83TA_2009.06_090722.fbl
http://rapidshare.com/files/279692978/Italy83TA_2009.06_090722.fbl
http://rapidshare.com/files/279296947/Latvia83TA_2009.06_090722.fbl
http://rapidshare.com/files/279207152/Latvia83Regio_2009.06_090730.fbl
http://rapidshare.com/files/279188068/Liechtenstein83TA_2009.06_090722.fbl
http://rapidshare.com/files/279296806/Lithuania83TA_2009.06_090722.fbl
http://rapidshare.com/files/279192389/Lithuania83Regio_2009.06_090730.fbl
http://rapidshare.com/files/279188406/Luxembourg83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188192/Malta83TA_2009.06_090722.fbl
http://rapidshare.com/files/279296499/Moldova83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188062/Monaco83TA_2009.06_090722.fbl
http://rapidshare.com/files/279296490/Montenegro83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188130/Montenegro83Contrast_2009.06_090730.fbl
http://rapidshare.com/files/279209827/Netherlands83TA_2009.06_090722.fbl
http://rapidshare.com/files/279224942/Norway83TA_2009.06_090722.fbl
http://rapidshare.com/files/279296481/Poland83TA_2009.06_090722.fbl
http://rapidshare.com/files/279247062/Poland83Emapa_2009.06_090730.fbl
http://rapidshare.com/files/279227550/Portugal83TA_2009.06_090722.fbl
http://rapidshare.com/files/279294511/Romania83TA_2009.06_090722.fbl
http://rapidshare.com/files/279205451/Romania83TopMap_2009.06_090730.fbl
http://rapidshare.com/files/279214627/Russia83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188078/SanMarino83TA_2009.06_090722.fbl
http://rapidshare.com/files/279294430/Serbia83TA_2009.06_090722.fbl
http://rapidshare.com/files/279189477/Serbia83Contrast_2009.06_090730.fbl
http://rapidshare.com/files/279294419/Slovakia83TA_2009.06_090722.fbl
http://rapidshare.com/files/279197524/Slovakia83Ceda_2009.06_090730.fbl
http://rapidshare.com/files/279194761/Slovakia83XAHAX_2008.10_090310.fbl
http://rapidshare.com/files/279293936/Slovenia83_TA_2009.06_090722.fbl
http://rapidshare.com/files/279212241/Slovenia83Monolit_2009.06_090730.fbl
http://rapidshare.com/files/279668677/Spain83TA_2009.06_090722.fbl
http://rapidshare.com/files/279242531/Sweden83TA_2009.06_090722.fbl
http://rapidshare.com/files/279203770/Switzerland83TA_2009.06_090722.fbl
http://rapidshare.com/files/279293207/Turkey83_TA_2009.06_090722.fbl
http://rapidshare.com/files/279230078/Turkey83Basarsoft_2009.06_090730.fbl
http://rapidshare.com/files/279291426/Ukraine83TA__2009.06_090722.fbl
http://rapidshare.com/files/279238085/Ukraine83CarteBlanche_2009.06_090730.fbl
http://rapidshare.com/files/279680328/UnitedKingdom83TA_2009.06_090722.fbl
http://rapidshare.com/files/279188048/Vatican83TA_2009.06_090722.fbl
nhưng vẫn thiếu cái software igo để chạy. em rất cần mà chẳng down về được. dù sao cũng rất cảm ơn bác, bên này đã không biết tiếng mà lại không biết tí công nghệ nào thì khổ lắm. ra đường ngơ ngơ như bò đội nón...cảm ơn bác nhiều nhưng tiện thể bác cho xin luôn cái soft chạy cái bản đồ đó nhé.=D>
iGO 8 R3 series - 8.3.4.102680
dùng cho Window Mobile
http://rapidshare.com/files/272923617/iGO8.3.4.102680.Mreyes.htclive.es.rar
dow về, bung nén, chạy .exe để cài, và máy báo lỗi " program application cannot be found. please insert original application SD card". vậy em phải làm sao đây ?
một điều nữa, nghe nói phải chỉnh lại file .sys cho phù hợp với từng máy. vậy máy em là x1 thì chỉnh lại như thế nào để có thể chạy được?:-??
Bạn vào bài trên cùng của mình theo link dưới down về dùng ko cần cài đặt gì
http://pdaviet.net/showthread.php?t=49645
+Lối trên như bạn nói là do file sys sai phải chỉnh lại: (ct theo link trên ko cần chỉnh)
bạn phải sửa lại cho đúng tên Memory Card như trong máy của bạn
vd đang la SD Card phải đổi thành Storage Card
mình đã dùng thử, và phải nói rằng đây là một soft... cực hay. chỉ có một vài điều nhỏ mình bị mắc phải. thứ nhất là cứ được một lúc màn hình tự động tắt đi rồi sau đó sáng trở lại, vài lần như vậy thì mình thấy không thu được sóng vệ tinh nữa. thứ hai là ( vừa là ưu điểm nhưng cũng là nhược điểm) vì không phải cài đặt nên không thể đưa ra màn hình today hay tạo phím tắt cho phần mềm này được. còn nói chung thì hoạt động tốt. hy vọng bạn sớm cho ra phiên bản có giọng nữ để anh em lái xe đường dài đỡ buồn =D>.một lần nữa cảm ơn nhiều.
bạn vào Menu/cài đặt/thiết đặt: mục quản lý pin bạn chỉnh: LUÔN SÁNG
là OK
muốn đưa vào programs ban dùng ct Resco file explorer
Giọng nữ mình muốn làm lắm nhưng lực bất tòng tâm, vi ko tìm đâu ra được người đọc!
Đây là file sys.txt cần phải sưa (chỗ chữ ĐỎ)
[project]
name="igo8_pda"
name="UI_igo8_da"
[folders]
app="%SDCARD%/iGO8.3"
Sửa thành: app="Tên memory card/tên thư mục ct Igo"
VD: app="storage card/iGO8" (Các phần khác ko quan trọng)
[interface]
skin="ui_igo8"
skin="ui_igo8_da"
laneinfo_signpost_enabled=1
vga=1
maxzoom2d=6000000
show_exit=1
show_tmc_eventlist=1
[project]
name="igo8_pda"
name="UI_igo8_da"
[folders]
[interface]
skin="ui_igo8"
skin="ui_igo8_da"
vga=1
maxzoom2d=6000000
show_exit=1
bạn có thể chỉ rõ hơn giúp mình không. mình không tìm thấy file sys.txt trong soft của bạn. và khi chỉnh lại như vậy có tác dụng gì? bởi vì hiện tượng tắt màn hình mình đã làm theo bạn chỉ và ok rồi. thank !
ah mình viết bài này cho người dùng bản iGO khác ko phải bản của mình cho, vì sau này có thêm 1 vài bản mới hơn phải sửa lại file sys.txt thì mới dùng được.
Bạn đã dùng được cả 3D chứ? (có hiện đủ các tòa nhà ở các tp lớn)
mình chưa thấy các tòa nhà, có lẽ mình mới chỉ test thử ở khu vực mình sống( một thị trấn không lớn). nhưng như vậy cũng hay lắm rồi, vừa đỡ tốn tiền vô mạng vừa đỡ tốn pin. khi nào có gì mới mẻ bạn thông báo cho anh em biết với nhé.
Một nước đầy đủ gồm có:
VD: Italia trong thư mục
CONTENT/ BUILDING (Italia.3dc + Italia.3dl)
CONTENT/ MAP (Italia.fbl)
CONTENT/ POI (Italia.poi)
CONTENT/ DEM (Europe_NASA.dem)
thì mới hiện đủ 3D
ngoài ra còn có SPEEDCAM có chung cho cả châu Âu
thì mới hiện đủ 3D
bạn có thể cho mình xin link tải đầy đủ những thứ đó dành cho khu vực châu âu được không ? mình mới chỉ down được phần bản đồ thôi( map.fbl) chứ đâu có biết về vụ mấy cái building hay poi gì đó đâu. link phụ kiện trong mấy bài trước của bạn ngỏm hết rồi.
Bạn vào link nay để lấy về, bạn vào mục Sorted by country (includes Map, POI and 3D) trong đó 1 nước có đầy đủ MAP POI 3D
http://forum.ppcwarez.org/viewtopic.php?f=256&t=79772
Pass: PPCWAREZ.ORG
(có thể link ko vào được, bạn vào lại vào lúc khác)
Mọi người cho mình hỏi, mình có cái thiết bị GPS (không phải mobile) thì làm sao update được nhỉ. Mình đang ở US, thử copy mấy cái bản đồ ở vào SD card mà vẫn không chạy được :(.
Thiết bị GPS của bạn là gì ko hiểu!
để sử dụng được navigation cac bài trên đã nói rồi nhưng mình nói sơ cho bạn hiệu
cac thiêt bị:
thiết bị thu tín hiệu GPS
thiết bị chạy các phần mêm navigation (DT, PDA, PNA...)
2 thiết bị trên được nối với nhau bằng cáp hoặc bằng bluetooth, hoặc tích hợp trong của các thiết bị trên
sau đó bạn mới dùng các phần mên navigation cài vào mới sử dụng được.
chúc vui!
các bạn cho mình hỏi chút.cung la igo 8 trên iphone khi đi bộ thi nó có chấm giống bước chân theo bước mình đi.nhưng sao trên WM lại không có nhỉ.có ai biết phải copy phần nào sang không chỉ mình với.
