23/07/08 -=® panosha ® =- Shine On 0.6 WWE Diamond ROM
Mình đang dùng rom này. Chạy cực mượt và nhanh
This ROM is based on official HTC WWE 1.93.465.2, OS 5.2.19965(build 19965.1.2.3) ROM, release date 10/07/08 and does not include radio (works fine with 1.00.25.05).
First you must flash HardSPL Developer Edition from here thahks to cmonex.
After unzipping the file you have downloaded, you must run from your desktop PC the ROMUpdateUtility.exe with your device synchronizing and the battery above the 50%. Follow the instructions on the screen.
The ROM is fast, stable, with .net CF 3.5, with some registry tweaks and modifications.
Big importance in the reduction of memory leakage.
You can find moreover programs in the end of post.
The device starts with 114 from 120 MB storage and 66 from 111 MB programs memory.
Download filefactory: http://www.filefactory.com/file/5a515c/n/panosha_Shine_On_0_6_Diamond_WWE_ROM_zip
Download megaupload: http://www.megaupload.com/?d=WRVRSLM8
Download rapidshare: http://rapidshare.com/files/131709985/panosha_Shine_On_0.6_Diamond_WWE_ROM.zip.html
IN
Manila Call History Tab
Force High Resolution v1.65
Wheather Database Editor 1.1 thanks to andreas.falke
OUT
Opera Mobile
Windows Live
Cyberon Voice Speed Dial
HTC Phone skin (you can enable it)*
HTC Zip
HTC Voice Recorder
RSS Hub
HTC MP3 Trimmer
Adobe Reader
Microsoft Update
Office One Note
Transcriber
Welcome Center
Sample pictures
Most Sounds
Registry Tweaks & Modifications
My new splash screen
.net CF 3.5
Stop ActiveSync when unplug USB cable
Comm Manager thanks to Nadavi
Removed: startup sound
Disable the security warning when installing non-certified application
Album OK close application
* If you want restoring HTC Phone skin because you need video calls, make the following change with a registry editor. Always remember, needs 9 ΜΒ memory and slow down menu speed.
HKEY_LOCAL_MACHINE/Security/Phone/Skin ---> Enabled
Cái weather bị lỗi 0 độ C các bạn phải chỉnh lại registry
HKEY_CURRENT_USER\Software\HTC\Manila\
Weather.Serv erURLOverride: http://weather.not2advanced.com/htcw...Devs&locCode=%%ls&version= 1&device=innovation
xóa 1 cái % đi
Credited to Panosha xda-developer
[20 Jul - Build 0.95] Public Beta: bElite ROM by bepe [WWE | GER | FRA | ITA]
Base ROM
Diamond HTCWWE 1.37.456.2
ROM date 06/19/08
Should be the latest and most stable ROM
Windows Mobile
AKU: 1.3.1
Build: 20270
Should be the latest final build
Boot up memory
RAM: 61.17 MB
Storage: 103.71 MB
That is without activating TouchFLO 3D
Editions
Premium: All standard apps
Link: http://rapidshare.com/files/130975632/Diamond_bElite_Premium_0.95_0409_by_bepe.rar
Basic: No TF3D, Audiomanager, EZInput, XT9
Link: http://rapidshare.com/files/130974121/Diamond_bElite_Basic_0.95_0409_by_bepe.rar
Credited to Bepe - xda-developers.
Rom của panosha chạy cực ngon.
Có gi không đúng mong các mod sửa hộ.
![60970439hg5.jpg](http://img301.imageshack.us/img301/7151/60970439hg5.jpg)
IN
OUT
Opera Mobile
Windows Live
HTC Zip
HTC Voice Recorder
RSS Hub
HTC MP3 Trimmer
Adobe Reader
Microsoft Update
Office One Note
Transcriber
Welcome Center
Sample pictures
Most Sounds
.net CF 3.5
xóa 1 cái % đi
Base ROM
ROM date 06/19/08
Windows Mobile
AKU: 1.3.1
Build: 20270
Boot up memory
RAM: 61.17 MB
Storage: 103.71 MB
Editions
