Custom Firmwares cho P990i
savatage2
Ai sài P9 có thể tải về bản CFW này xài thử
= MOD List =
SIS Installer Mod
Add to Contact (Call Log MOD)
Alarm Patch mod
Appications Folder in Control Panel + CP Exit Button
Contact mod for P990 V1.0 by dongxanh
File Manager Icons Mod By Zeegy
'Flightmode' to 'Offline' mod
Hardware Button [@] MOD
Java Icon Removed
Menu Acceleration
Message Mod v4.1 (Final) by dongxanh
Opera 5tabs mod
UIQ Technology startup & shutdown
YM Smilies on SMS
Default theme: Car Designz 1
Exit Mod:
Calendar
Calculator
Media Player
Notes
Opera Mobile
Picture Gallery
Speed Dial
Tasks
Time
Video
WLan
Auto install applications every hard reset:
SwissManager Pro
Caps Switch 1.1.27 (in Control Panel)
Attachment Replaced [26-11-2010]:
- Added Popup Menu by squallvai
- Removed incorrect Files & Folder in Z:resourceresource
Em đã làm theo đúng những gì trong trang
http://www.aioboards.com/f78/p990i-custom-firmwares-squallvai-334178/
yêu cầu, chuyễn CDA thành GW1 nhưng khi tiến hành update rồi quăng cái file FILE_275469777 vào thì nó chỉ chạy được tầm 45% là báo lỗi! tháo ra bấm nguồn lên là nó chốp chốp cái màn hình -> không cách chi cho nó load hết được!
Hy vọng mốt có ng mod được CFW P1 chạy trên P9 ;;):-?
Bản CFW Vol 2 cho P9
= MODS LIST =
Two Apps Added to ROM:
Torch
Walkman 2 with WP3 Skin
Disabled Apps:
ApplicationShop
PlayNow
RSS Feeds
Online
Payment Menu in Control panel
Transitions Menu in Control Panel
Remove All media Files in Drive C After Hard Reset, Benefits:
- Gained Free Space in Drive C
- Remove All Images, including ClipArt & Frames
- Remove All Sound, exept Sony Ericsson.mid
- Remove All MMS Template
Added New Mods:
Dialpad Skin
Sound Mod Full 1.1 by Swmail
Video Recorder Increased from 15 fps to 22 fps
Speed Up Opera Standart
SIS Installer Mod
Alarm Patch mod
Java Icon Removed
Menu Acceleration
Opera 5tabs mod
YM Smilies on SMS
Default theme: Green Grass by squallvai
Exit Mod:
Calendar
Calculator
Media Player
Notes
Opera Mobile
Picture Gallery
Quick Offce
Speed Dial
Sound Recorder
Tasks
Time
Video
WLan
Auto Install Applications every hard reset:
SwissManager Pro
Cách up:
Cần
Seus bản mới nhất
Chuyển CDA của máy về CDA 162007/1 R6E28
Cài
Cài vào máy xong chạy seus cho chương trình nhận máy và tiến hành download bản FW mới nhất về máy, cứ để nó down load hoàn tất và chuyển sang quá trình flash được 1 lúc copy file FILE_275469777 quăng vào thư mục c:\Program Files\Sony Ericsson\Update Service\db\13740270\blob_fs\
lưu đè lên file đã có và chờ cho nó flash tiếp (nếu quăng file này lúc nó đang download sẽ báo lỗi và không cho flash) khoảng 1 lúc sau nó sẽ báo lỗi yêu cầu mình rút cable ra thử lại, cứ rút ra rồi mở nguồn nếu máy báo lỗi hãy hard reset là máy sẽ boot vào bình thường và hoàn tất quá trình cài.
Nhận xét:
Em đã thử trên 2 máy P9 khác nhau, 1 của em và 1 của bạn em kết quả máy em khi flash xong -> mở nguồn màn hình chốp liên hồi reset liên tục, cắm sạc nó cũng chốp!làm đi làm lại hoài vẫn bị (em đã flash tới flash lui ít nhất 4 lần mà vẫn ko được)=> bó tay
Máy bạn em thì chỉ cần 1 lần là được, không bị chốp màn hình, ko bị reset liên tục=> ok xài ko thấy lỗi nào
Kết luận
chắc tùy máy hên xui :));;)
Link
http://www.mediafire.com/file/lflbdb4cfzl3s6b/[P990i] Custom Firmwares Vol.2 by squallvai.zip
chào bạn NokuaN70,mình xài Nokia 6708 HDH Symbian 7.0 UIQ V2.1v hay bị lỗi màn hình và không biết cài đặt các ứng dụng cho máy, máy lại không kết nối được với PC, nếu bạn đã từng nghiên cứu về dòng máy này hãy hướng dẫn giúp mình nha, cảm ơn bạn nhiều. Mình tên Mân sdt 0947821282, bạn cứ mail qua cho mình cũng được :thanhmandt@gmail.com, bạn giúp mình ha,came ơn nhiều.
