Cứu con N5800 giúp em với! Die nguồn.
viet18091991
Tối qua em định reset máy lại để giải phóng bộ nhớ ai ngờ tắt rồi mở ko lên lun> Bật nguồn nó chỉ rung 1 cái rùi im re à! Tức quá sáng nay em đem ra up = JAF thì vẫn như bình thường, chỉ khi đến giai đoạn pooling phone thì máy ko hiện lên Nokia Tét Mode mà màn hình chớp tắt vài cái rùi có thông báo như sau:
Init usb communication...
Failed to backup CRT...
Detected P-KEY: 900096C2
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 007.016.022
Elf2flash 08.37.001
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting..................PUBKEYS already sent...
...........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 543, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101_prd.rofs2.V23...
Erasing cmt zone 06560000 - 0915FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-356\RM-356_21.0.101.240.07.rofs3.fpsx...
Erasing cmt zone 09160000 - 09E5FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Sending CMT HASH for SOS+ROFS3
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Ai bít máy em bị gì giúp em với! Dân chơi mà hok lẽ đem ra Care nó kì, với lại em sợ Care quá à!
tháo PIN lắp lại và đổi cổng USB rồi FLASH lại xem sao?
P.s: bệnh này lạ wá
Không biết khi bạn reset pin còn đầy đủ không,dạo này nhiều người up = JAF hay bị die nguồn quá :-??
Sao kỳ vậy :( đó h flash fw 21 của 5800 cũng nhiều rồi có bao h bị bệnh vậy đâu cà :O bạn kiễm tra kỹ lại cổng và dây USB rồi remove J.A.F ra cài lại rồi làm lại lần nữa xem...
Đã là dân chơi thì mua hẳn con mới về mà chơi
cái này mình đã và đang bị chưa cách xử lí ,nghi ngờ là do up bằng jaf. chưa có cách cứu bằng cách flash bằng jaf qua usb.còn box chuyen dụng thì mình chưa thử.
Nếu là dân chơi đúng cách thì tìm cách khắc phục chứ dân chơi 2 lúa thì mới mua con mới ( hoặc dân chơi chỉ được cái đầu ốc ngu si tứ chi phát triển thì mới làm thế)
K có ý gây hấn nhé, chỉ phát biểu ý kiến thui
Ngu si nên mới tự cho mình là dân chơi, ko có ý gây hấn, chỉ phát biểu ý kiến thui
Chủ t0pic này nên vào t0p 5800 mà hỏi.
K nên lạm dụng, cái gì cũng mỗi 1t0pic nhé bạn!
Bạn vào đó để mọi người dùng 5800 mà giúp, chứ lập ngoài như thế rất ư là phiền.
hai bạn bình tình lại nhé,đừng dùng những từ ngữ ko hợp nhau ở đây nhé,mình nhắc 2 bạn đó,đừng phát biểu như vậy nhé
Okie, xin tiếp thu ý kiến đóng góp, mod cũng nên dùng cách nào đó có thể để hạn chế những lời lẽ k hay của mems, nếu mình có bị sao cũng chịu vì đây là web rất hay nên k chỉ riêng mình mà mọi người đều k muốn những cái k tốt xuất hiện ở đây
K bàn luận nữa, thank mod đã đóng góp
Mình flash máy dùm thằng bạn cũng bị tình trạng như thế này. Lần đầu mình flash nó báo như chủ topic chỉ nhấp nháy màn hình vài cái chứ ko có lên chữ test mode. Mình tháo pin ra lắp lại rồi flash lại thì thành công nó hiện lên Test Mode nhưng khi tháo pin gắn vô bấm nguồn khởi động rung 1 cái nhưng màn hình đen thui. Mình thữ tháo sim và gắng 1 sim khác vô thì khởi động vô được xài bình thường ko vấn đề gì nhưng thữ tắt nguồn khởi động lại thì khi tắt nguồn nó cháy đèn ở cả 3 nút xanh trắng đỏ mà ko chịu tắt, bấm bật tắt nguồn cỡ nào cũng ko lên. Thằng bạn đem ra care nó đổi cái main khác ko tốn tiền giờ xài ok rồi nhưng mình ko dám flash nữa vẫn để nguyên cái FM V21.0.25 của main mới đổi.
P/S: hic hic hên là máy của mình không có bị nhưng mà sao dạo này xài hay bị tình trạng tự nhiên bị khởi động lại lúc vô contacts và xem phim online ( xem phim online chắc do đầy Ram nên mới khởi động lại ). 5800 vẫn còn lỗi nhiều quá :(
Lỗi này thì theo mình cứu con 5800 thì dùng JAF và có Pkey chạy lại sẽ hết ngay,đã làm đc 2 con và cứu sống thành công,còn tình hình như trên là do máy sạc ko đầy pin chạy lại nó báo như vậy lắm:p vì ko gặp nên ko biết,chắc do lỗi bộ sưu tậm thôi,các bạn tìm đủ 3 file COR,PPM,CNT có nghĩa là mình chạy toàn bộ lại hết là sẽ đc ngay:))
post lên hướng dẫn cho ae luôn nhé.mình đang nghiên cứu nếu nhưng chưa thành công
Ai bik không loại trừ khả năng này ;;). Cháy em này là coi như xong lun. Có thay cũng cùi hơn trc :))
nếu cháy ic thì máy sẽ không vào được ,nhung6 cái này usb còn nhận.
