Danh sách phím tắt hữu dụng trên máy Macbook !
Taki7610
Unlock_GSM
Danh sách phím tắt hữu dụng trên máy Macbook - Anh em tham khảo nhé !​
Startup
Mã:
"Press X during startup" = Force Mac OS X startup
"Press Option-Command-Shift-Delete during startup" = Bypass primary startup volume and seek a different startup volume (such as a CD or external disk)
"Press C during startup" = Start up from a CD that has a system folder
"Press N during startup" = Attempt to start up from a compatible network server (NetBoot)
"Press T during startup" = Start up in FireWire Target Disk mode
"Press Shift during startup" = start up in Safe Boot mode and temporarily disable login items and non-essential kernel extension files (Mac OS X 10.2 and later)
"Press Command-V during startup" = Start up in Verbose mode
"Press Command-S during startup" = Start up in Single-User mode
Finder window
Mã:
"Command-W" = Close Window
"Option-Command-W" = Close all Windows
"Command-Right Arrow" = Expand folder (list view)
"Option-Command-Right Arrow" = Expand folder and nested subfolders (list view)
"Command-Left Arrow" = Collapse Folder (list view)
"Option-Command-Up Arrow" = Open parent folder and close current window
Menu Commands
Mã:
"Shift-Command-Q" = Apple Menu Log out
"Shift-Option-Command-Q" = Apple Menu Log out immediately
"Shift-Command-Delete" = Finder Menu Empty Trash
"Option-Shift-Command-Delete" = Finder Menu Empty Trash without dialog
"Command-H" = Finder Menu Hide Finder
"Option-Command-H" = Finder Menu Hide Others
"Command-N" = File Menu New Finder window
"Shift-Command-N" = File Menu New Folder
"Command-O" = File Menu Open
"Command-S" = File Menu Save
"Shift-Command-S" = File Menu Save as
"Command-P" = File Menu Print
"Command-W" = File Menu Close Window
"Option-Command-W" = File Menu Close all Windows
"Command-I" = File Menu Get Info
"Option-Command-I" = File Menu Show Attributes Inspector
"Command-D" = File Menu Duplicate
"Command-L" = File Menu Make Alias
"Command-R" = File Menu Show original
"Command-T" = File Menu Add to Favorites
"Command-Delete" = File Menu Move to Trash
"Command-E" = File Menu Eject
"Command-F" = File Menu Find
"Command-Z" = Edit Menu Undo
"Command-X" = Edit Menu Cut
"Command-C" = Edit Menu Copy
"Command-V" = Edit Menu Paste
"Command-A" = Edit Menu Select All
"Command-1" = View Menu View as Icons
"Command-2" = View Menu View as List
"Command-3" = View Menu View as Columns
"Command-B" = View Menu Hide Toolbar
"Command-J" = View Menu Show View Options
"Command - [" = Go Menu Back
"Command - ]" = Go Menu Forward
"Shift-Command-C" = Go Menu Computer
"Shift-Command-H" = Go Menu Home
"Shift-Command-I" = Go Menu iDisk
"Shift-Command-A" = Go Menu Applications
"Shift-Command-F" = Go Menu Favorites
"Shift-Command-G" = Go Menu Goto Folder
"Command-K" = Go Menu Connect to Server
"Command-M" = Window Menu Minimize Window
"Command-?" = Help Menu Open Mac Help
"Command-Space" = Open Spotlight (Mac OS X 10.4 or later)
"Command-Alt-Space" = Open Spotlight Guide (Mac OS X 10.4 or later)
"F12" = Opens Dashboard (Mac OS X 10.4 or later)
Universal Access and VoiceOver
Mã:
"Option-Command-* (asterisk)" = Turn on Zoom
"Option-Command-+ (plus)" = Zoom in
"Option-Command-- (minus)" = Zoom out
"Control-Option-Command-* (asterisk)" = Switch to White on Black
"Control-F1" = Turn on Full Keyboard Access
When Full Keyboard Access is turned on, you can use the key combinations listed in the table below from the Finder.
"Control-F2" = Full Keyboard Access Highlight Menu
"Control-F3" = Full Keyboard Access Highlight Dock
"Control-F4" = Full Keyboard Access Highlight Window (active) or next window behind it
"Control-F5" = Full Keyboard Access Highlight Toolbar
"Control-F6" = Full Keyboard Access Highlight Utility window (palette)
"Command-F5 or fn-Command-F5" = Turn VoiceOver on or off (Mac OS X 10.4 or later)
"Control-Option-F8 or fn-Control-Option-F8" = Open VoiceOver Utility (Mac OS X 10.4 or later)
"Control-Option-F7 or fn-Control-option-F7" = Display VoiceOver menu (Mac OS X 10.4 or later)
"Control-Option-; or fn-Control-option-" = Enable/disable VoiceOver Control-Option lock (Mac OS X 10.4 or later)
Mouse Keys
Mã:
"8" = Move Up
"2" = Move Down
"4" = Move Left
"6" = Move Right
"1, 3, 7, 9" = Move Diagonally
"5" = Press Mouse Button
"0" = Hold Mouse Button
". (period on keypad)" = Release Mouse Button (use after pressing 0)
Other Commands
Mã:
"Option-Command-D" = Show/Hide Dock
"Command-Tab" = Switch application
"Command-Up Arrow" = Move up one directory
"Command-Down Arrow" = Move down one directory
"Page Up or Control-Up Arrow" = Move up one page
"Page Down or Control-Down Arrow" = Move down one page
"Option-Drag" = Copy to new location
"Option-Command-Drag" = Make alias in new location
"Command-Drag" = Move to new location without copying
"Command-C" = Show Colors palette in application
"Command-T" = Show Font palette in application
"Command-Shift-3" = Take a picture of the screen
"Command-Shift-4" = Take a picture of the selection
"Command-Shift-4, then press Control while selecting" = Take a picture of the screen, place in Clipboard
"Command-Shift-4, then Spacebar" = Take a picture of the selected window
"Option-Command-esc" = Force Quit
"Control-Eject" = Restart, Sleep, Shutdown dialog box
"Control-Command-Eject" = Quit all applications and restart
"Option-Command-Eject or Option-Command-Power" = Sleep
"Command-click window toolbar button (upper right corner)" = Cycle through available views for the window's toolbar (dependant on the nature of the Finder or application window)
"Command-`" = Cycle through windows in application or Finder (if more than one window is open)
"Function-Delete (PowerBook, iBook only)" = Forward Delete (delete the character to the right of your cursor).
Rebooting, Shutting down, Logging out, or Sleeping :
Mã:
Immediately Reboot Mac OS X
Control + Command + Eject
Immediately Shutdown Mac OS X
Command + Option + Control + Eject
Immediately Log User Out of Mac OS X
Control + Option + Shift + Q
Immediately Put Your Mac to Sleep
Command + Option + Eject (hold the buttons down for 2 seconds)
Immediately Shut Off Your Mac Display
Shift + Control + Eject
Option key's
Mã:
£= option +3
¢ = option + 4
©= option + G
® = option +R
™= option +2
é = option + e + e
è = option + e
ê = option + i then e
ü = option u + u
º = option + )
