Desire S - Cần hướng dẫn root và Recovery
kidphuongit
Desire S - Hướng dẫn S-OFF và root với AnphaRev X - GingerBreak
Need :
1. HTC desire S with S-ON
2. Hboot : 0.98.0000 (this the only 1 supported for now. Please check the Hboot version before you proceed else it might brick your phone)
3. No need for any drivers or anything nor HTC sync
Linux system :
I used Ubuntu 11.04. But this manual would work for all Linux Systems.
1. Go to http://alpharev.nl/x/beta/
2. Click on Download for Linux
3. Now download the package
4. Now go to the location where this package you have downloaded and extract it to find Alpharevx file.
5. Next take your HTC Desire S. Goto Menu>Settings>Applications>development and turn USB debugging mode on.
6. Now connect your phone to the computer and select Charge only mode.
7. Now open terminal and go to location where you have Alpharevx and type ./alpharevx in the terminal.
8. It would detect your phone, show you you serial number and as for Beta key.
9. Now on the http://alpharev.nl/x/beta/ enter this serial along with selecting your model and Hboot version.
10. Press generate to get the beta key.
11. Now copy this key as it is and paste in the terminal and press enter.
12. Within 5 min your phone should be unlocked. You can see your phone restart couple of times during this period and then see that its S Off.
13. You will get a message Complete and option if you want to dowload Clockworkmod recovery.In case cell hangs or any issues. Start again from step 1.
14. I would suugest you say yes to it. It downloads and installs it.
15.Once you get the message that its complete. You can Unplug your phone and enjoy the Power of Android now.
Trên đây là hướng dẫn S-OFF DS, các bác có thể sử dụng Ubuntu chạy trên USB như LiveCD và làm theo hướng dẫn.
Sau khi S-OFF xong các bác sử dụng GingerBreak-v1.20.apk để root nhé. Bác nào chưa rõ ở bước nào có thể hỏi ở đây hoặc qua em làm hộ :p
Vẫn chưa root được đâu bạn.
Nghe đâu AlphaRevX có thể s-off được nhưng chỉ beta thôi, phải chờ 1 thời gian nữa
mình cũng chưa s-off được DS nữa! vẫn đang mò mà ko có kết quả j` hết trơn
Tin vui: AlphaRevX đã public beta:
Supported Devices:
HTC Desire (bravo) 0.93.0001
HTC Desire CDMA (bravoc) 1.06.0000
HTC Wildfire (buzz) 1.01.0001
HTC Aria (liberty) 1.02.0000
HTC Incredible S (vivo) 1.09.0000 and 1.13.0000
HTC Droid Incredible 2 (vivow) 0.97.0000
HTC Desire S (saga) 0.98.0000
Chi tiết tại http://alpharev.nl/x/beta/
Supported Devices:
Em mày mò cả ngày nay mà chưa làm được. Bản trên win thì ko dùng đc rồi. Em gà linux. Bác nào biết làm chỉ em với :(
conds cua em to ,lam theo chu xi .ngon canh dao roi ,dang chay ,rom sensen 3.0 ,ban unity v1.27.0
desire s của mình khi click gencode thì báo lỗi như thế này :
cả khi mình chọn cho incredible s cũng báo lỗi như vậy. Có bác nào thành công hay gặp lỗi tương tự đã khắc phục được thì giúp em với .
Thank all !
Thank all !
Bạn phải điền kí hiệu máy của bạn vào serial number rồi mới bấm Generate key, để lấy key. Sau đó làm theo hướng dẫn ở trên.
